[Kernel] für ICS 4.0.3/4.0.4
  • 467 Antworten
Welcher Kernel läuft bei euch
  • Umfrageteilnehmer
    91
der neue Air 3.8 ist raus,
AIR Kernel: [ICS] AIR Kernel v3.8 for NexusS 3G and 4G
changelog:
v3.8 (03-31-2012 KST / GMT +9:00)
-Added Force AC Fast Charging by chad0989 (Chad Froebel)
-Fixed freezing during calling and sleeping (Thanks to Michael Huang, netarchy, byeonggon)
-Adjusted Bigmem and MFC0, 1 (RAM : 354MB -> 362MB)
-Changed value of dirty_writeback_interval
-Re-added Savagedzen governor
-Disabled some kernel debugs
mal sehen vielleicht passt der momentan besser zu CM9 4.0.4,
da Kalims etwas älter ist.
Reaktionen: sph3re
Aktualisiert, 3.x.x Custom Kernel !!:flapper: :thumbup:
  • [KERNEL] Air Kernel v3.8 [31 MAR 2012] [STABLE] [3.0.26] [SMOOTH|SPEEDY|VOODOO|MOD]
Changelog
Aktualisiert !!:flapper: :thumbup:
  • Umfrage : Welcher Kernel läuft bei euch
Danke nochmal an Handymeister !!!!!
Reaktionen: Adinoid
  • Oxygen Kernel 3.0.26_r2 :thumbsup::thumbsup:
Changelog
As 3.0.23 r1 stable with the below changes:
  • Debugging flags reduced
  • CONFIG_ARM_UNWIND enabled
  • Merged to 3.0.26 from kernel.org
  • Rebased with updates from AOSP (ICS 4.0.4 release) - Nothing ground breaking, just a few bugfixes
  • [Kernel] SimpleKernel 1.20 (stock kernel ICS 4.0.4 + backlight mods + voodoo*) :thumbsup::thumbsup:
Changelog:
SimpleKernel 1.20 (1st April 2012)
  • Updated kernel to stock 4.0.4.
  • Built md4 into kernel instead of as module (required for CIFS)
  • Trinity NS kernel TEUV-ICS -CM9-230312
Mit App NStools CPU Frequenzen einstellen !!!
TEUV-NS-CM9-230312
This is the Trinity NS kernel with 880MHz CPU And 220MHz GPU/BUS clock with BLN, BLD, Voodoo Sound, includes KSM (This kernel is recommended for CM9, been reported to work with aokp).
T11-NS-CM9-230312
This is the Trinity NS kernel with 1100MHz CPU And 220MHz GPU/BUS clock with BLN, BLD, Voodoo Sound, includes KSM (This kernel is recommended for CM9, been reported to work with aokp).
T12-NS-CM9-230312
This is the Trinity NS kernel with 1200MHz CPU And 200MHz GPU/BUS clock with BLN, BLD, Voodoo Sound, includes KSM (This kernel is recommended for CM9, been reported to work with aokp).
T132-NS-CM9-230312
This is the Trinity NS kernel with 1320MHz CPU And 220MHz GPU/BUS clock with BLN, BLD, Voodoo Sound, includes KSM (This kernel is recommended for CM9, been reported to work with aokp).
T144-NS-CM9-230312
This is the Trinity NS kernel with 1440MHz CPU And 240MHz GPU/BUS clock with BLN, BLD, Voodoo Sound, includes KSM (This kernel is recommended for CM9, been reported to work with aokp).
  • [KERNEL][09 FEB] GLaDOS V2.10 + [01 APR] ICS 4.0.4 Test-Kernel
I will update this kernel as long as Google delivers updates for the Nexus S and my time permits.
I compiled a test kernel with the updates made to the stock kernel for 4.0.4. Try it and tell me if you can find anything that is broken.
Läuft der Kernel stabil?
Hatte ihn mal getestet letztens, ja ist stabil. Allerdings bevorzuge ich den Kernel aus meiner Signatur :D
  • CM9 29-MAR default kernel 3.0.25 KalimochoAz
-noch der 4.0.3 Kernel !!!!
GLaDOS-V2.11 ist raus ;)
Hat jemand einen Link/Download des neuen CM9-Kernels (Update kernel commiting google changes for 4.0.4) aus der Nightly vom 5.4.?
  • [KERNEL][04 APR] GLaDOS V2.11
GLaDOS-V2.11
  • Added kernel patches for Android 4.0.4 update.
  • Fixed bug with Touch Wake.
  • The kernel installer no longer modifies the ramdisk for adding init.d support.
  • >> NEW<< RcrdBrt's INK kernel >> NEW<<
INK Kernel
Italian Nexus Kernel
It is based on latest 4.0.4 source and for now I added:
-SLQB memory allocator
-Voodoo Sound
-BLN
-BLX
-BLD (I really like it)
-liveOC
-wheatley (give it a try) and lazy governors
-undervolt INT voltages by default (as I learned from bedalus graphs, INT uv is more efficient and it gives us a bit of more battery).
I merged in it Steve Garon's tweaks branch and Ezekeel's hiddenpart branch and I had a boost in performances.
I unchecked in the config the TV tuners modules, some debug options and unnecessary govs to have a lighter and more powerful kernel.
it's not gonna be an all in one kernel, I let join the project only the features that I think they are good (suggestions however are well accepted). I added also V(r), BFQ and SIO.
My default settings are:
Ondemand 100/1000
BFQ
liveOC 100%
  • [KERNEL][ICS][29-03-12] AniDroid-Hardened (GS|FC|ALOC|Voodoo|BIGM|BLN|BLD|TW|3.1.10)
Beta 9 - Beta 10:
  • USB Fast Charge bug fixed
74819
Firetime
Firetime
Müllstein
  • Müllstein
5 6 7
Firetime
Firetime
