[KERNEL] Linaro Kernel|R64t1
  • 211 Antworten
d4Lux0r
d4Lux0r
Stamm-User
269
NICHT KOMPATIBEL MIT CYANOGENMOD 11 (4.4.4 KitKat)
Status: Stable
Current Stable Version: r64t1
Stable Release Date: 2014-09-30
Last thread update: 02.12.2014
App Support:
Compatible with Nexus 5 gamma reverse engineering
Compatible with franco.kernel Updater (FKU)
Compatible with Faux Sound
Based on Franco Kernel
F2FS-ALL support in the installer, you don't need 2 versions anymore!
This is an AOSP based kernel, so it won't work with CAF based ROMs like CM11
Aroma Installer with selectable options (sound, colors, wake gestures...)
O3 flag, hard ABI, Linaro, VFP and many others Cortex-A15 Optimizations
Tweaks to make it compile with gcc 4.9.2
Fixed most of the warnings
Upstream with Linux kernel 3.4.x
Init.d Support
Battery Life eXtender, LCD_KCAL drivers
FAT usb OTG outomount, for other FS use stickmount app
Turned off many debug and logging option
Added Faux sound, Franco sound is not included, I prefer Faux solution
Sl[AOU]b allocators optimizations and fixes
Lz4 compressed kernel and RamDisk for faster boot (with lz4 r123)
Added sweep2wake, doubletap2wake, sweep2sleep
s2w/dt2w: Powerkey toggle, Prevent touches during phone calls, Timeout option, Bidirectional sweep2sleep, Omnidirectional sweep2wake...
Wake gestures interface (requires this -> http://forum.xda-developers.com/xposed/modules/app-wake-gestures-v1-1-t2768266)
Optional haptic feedback for gestures
Logitech unifying receiver support
ExFat 1.2.9, NFS and F2FS kernel support
lib/string & lib/memcpy: use faser glibc version
Rwsem backported from Linux 3.10
Overclocked slimbus for better audio quality
Mouse/Keyboard Driver support (you need this -> https://play.google.com/store/apps/details?id=remote.hid.keyboard.client)
Audio call recording support (you need this app -> http://forum.xda-developers.com/showthread.php?t=1441643)
Many other fixes you can find in my git
If you want to mount usb OTG this kernel will automount only fat/fat16/fat32 filesystems, for any other file system please use StickMount App
You can find my own compiled toolchain, optimized for Cortex A15 HERE
s2w, dt2w, s2s+dt2w will cause an extra battery drain (~2% per hour)
s2s only will not cause any extra battery drain
F2FS-ALL option: if you select this option the ramdisk will be modified to work with F2FS-ALL ROMs and recoveries on the fly, it means that the kernel boot.img is created on the fly depending on the options chosen in the installer
Don't use F2FS-ALL if you are not going to use a F2FS recovery and ROM, it will not boot
...::: DOWNLOAD :::...
Linaro Kernel - xda-developers DevDB
...::: SOURCE :::...
https://github.com/labodj/hammerhead-linaro
How to flash:
just flash in recovery, no need to wipe anything
Credits:
@franciscofranco @faux123 @kecinzer @renaud @flar2 @show-p1984 @neobuddy89
Kernel supporters donors hall of fame:
- @supguise
- @shaker2k
XDA: DevDB Information
Linaro Kernel, a Kernel for the Google Nexus 5
Contributors
LaboDJ
Kernel Special Features: Kernel based on Franco Kernel compiled with my own compiled Cortex A15 optimized Linaro toolchain, it includes latest linux patches, and other optimizations.
Donations:
https://www.paypal.com/us/cgi-bin/w...63663d3faee8d66f31424b43e9a70645c907a6cbd8fb4
Reaktionen: crunkyy, Bödi und Radagast
Läuft im übrigen recht rund und stabil und auch die Performance stimmt...
Für "faule" Menschen, da man kaum was konfigurieren muss, wie bei franco :)
Ziemlich gut für den Anfang, auch da Faux Sound funktioniert
Ich bin begeistert!
Gesendet von meinem Nexus 5 mit der Android-Hilfe.de App
Denke das nachher noch 12 erscheint, die dürfte nochmals besser werden.
Ist die displayKalibrierung die gleiche wie beim franko kernel?
Sollte sie sein
Mal antesten....
Gestern nachdem das Handy von selber ausging. Wohl gemerkt mit 9std 15min sot. Hab ich es angesteckt und heute morgen ging es nicht mehr an. Hab es nochmal ans ladegerät und da hat es rot geblinkt. Über Nacht hatte ich es am USB. Später ging es doch wieder an. Gott sei dank.
Rot blinkend bedeutet eigentlich total entladen
Bei dem Build scheint es leichte Probleme zu geben.
Hatte ein massives Wakelock mit dem Sound , sodaß der Drain rel. hoch war.
Sollte aber bald auf das R13 von Franco angepasst werden
Als ich rot sah hab ich mich schon geistig aufs öffnen eingestellt um den Akku abzustecken. Komisch war das Handy lade ich normal immer über den USB port vom PC. Am morgen war das Handy gut warm aber kein Saft drin. Erst am ladegerät konnte ich es wieder beleben.
USB hat normal weniger Saft, als eine Ladgerät ... Kann sein das irgendein Prozess im Hintergrund lief, was das Phone leergesaugt hat , trotz USB
R13 draussen
Handy war aus. Da läuft nix im Hintergrund :)
So mit der neuen Version ist der Drain im Standby deutlich verbessert worden ... bei ca. 1 %
Aber anscheinend hat sich der Akkuverbrauch bei Aktivität verschlechtert. Bin zur Zeit bei 1std 20min Dot und schon bei 55% angelangt...
Das klingt nicht gut... Ist das bei noch mehreren so? =)
Trickster funktioniert auch
Reaktionen: sNjke
