[KERNEL][AOSP] Linear 2.9 [07.08.2014]
  • 10 Antworten
Bödi
Bödi
Philosoph
6.180
XDA-Thread
A C H T U N G ::
Flashen auf eigene Gefahr - nur für AOSP-Roms, nicht für CAF-/CM-basierte Roms geeignet!
Der Dev dieses Kernels erhebt für sich den Anspruch, möglichst nahe am Google-Kernel für KitKat zu bleiben und setzt somit auf einen stabilen und weitgehend akkuschonenden Kernel.
Features:
  • Based on android-msm-hammerhead-3.4-kitkat-mr2
  • Stock mpdecision
  • Build with Linaro GCC 4.9.1-2014.06 toolchain optimized for Cortex-A15
  • LCD_KCAL: Color Control driver
  • Faux Sound Control
  • Voltage Control
  • Kexec-Hardboot support
  • Gamma Control
  • USB Fast Charge
  • Sweep2wake, doubletap2wake, sweep2sleep,
  • Prevent touches during phone calls, fullscreen option
  • wake timeout
  • Option to disable touch wake with power button
  • SIO and FIOPS i/o schedulers
  • network speed tweak
  • exFAT support
  • ntfs support enabled
  • stereo call recording support
  • Fixed some warning
  • Always on rgb led support
  • Reduce minimum panel brightness
  • kgsl: Report GPU frequency correctly
  • ...and more on my git..
Changelog:
Linear 2.6 - Jul 23, 2014
Linear Configuration file: set your kernel (credit to flar2)
disable s2w/dt2w after timeout
disable timeout by default
Revert "slimbus: overclock root freq
Linear 2.5 - Jul 19, 2014
Build with Linaro GCC 4.9.1-2014.07 Cortex-A15
Add option for sweep2sleep only
fullscreen option
Make power button also disable irq_wake in touch driver
fix unbalanced irq_wake
arm/dts: hammerhead: Optimize panel init/uninit sequence
Linear 2.4 - Jul 17, 2014
exFAT support
fs: exfat: Update to v1.2.8
msm: thermal: Update to speed up bootup time
softirq: reduce latencies
add gpu simple governor
Linear 2.3 - Jul 11, 2014
ARM: dts: msm: increase adsp heap size for msm8974
arm/dt: msm8974: Increase "ib" values for VIDC DDR bandwidth request
net: loopback: set default mtu to 64K
ARM: dts: msm: Increase OCMEM BW request for video decode
prevent touches during phone calls while screen is off and s2w or dt2w are enabled
revert lge: remove console enabler function call
Linear 2.2 - Jul 9, 2014
Linux 3.40: clean source, close to stock
block: deadline: Optimize for non-rotational
Linaro GCC 4.9.1: fix compilation warnings
bcmdhd: reducir wakelocks
block: row: add magic values
optimized ARM RWSEM algorithm
Revert ofast
ARM: Use -mcpu=cortex-a15 when targeting MSM Krait CPUs
Added sweep2wake, doubletap2wake, sweep2sleep
sound: hack faux sound
Increase size charging percentage Indicator
Linear 2.1 - Jul 1, 2014
Ofast optimization level
Percentage indicator charge when phone is off
ARM/dt: set values minimum panel brightness to 4
mm: push readahead to 512kB
various fixes
Linear 2.0 - Jun 27, 2014
fix miui compatibility
msm_thermal.c:improvement
Input: Send events one packet at a time
mdss: dsi: Resolving memory leak in parse dsi commands
leds: leds-qpnp: Set proper flash duration
msm: Improve qpnp-vibrator scheduling
deadline: Allow 0ms deadline latency, increase the read speed
deadline: enable default
Linear 1.9 - Jun 23, 2014
Linux 3.4.94
Add SIO and FIOPS i/o schedulers
fiops: enable default
Reduce minimum panel brightness to 3
msm: kgsl: Allow GPU start to run in a high priority queue
msm: kgsl: Add an input handler to power up the GPU on a touch event
msm: kgsl: Fix nice level for higher priority GPU start thread
msm: kgsl: Schedule adreno_start in a high priority workqueue
Installation:
  • Aktuelle Rom erneut flashen, falls gerade ein anderer Custom Kernel installiert ist
  • Kernel flashen - kein Wipe notwendig (auch nicht Wipe Cache oder Wipe Dalvik Cache)
  • Reboot
Support:
Wenn euch der Kernel gut gefällt unterstützt den Dev doch bitte mit einer kleinen Spende bei seiner Arbeit!
In $
In €
Reaktionen: mj084, J.arr und qu4nd
Klingt interessant. Werde ich mir mal genauer anschauen. Danke!
Update auf Version 2.7 >>
http://www.androidfilehost.com/?fid=23578570567720599
hottix schrieb:
Linear 2.7
Add more tcp: westwood, htcp, vegas, veno, illinois
set westwood by default
BFQv7r4 scheduler
update BFQ-v7r5
add ZEN scheduler
Add backlight dimmer option
More gradual levels for backlight dimmer mod (based on [MENTION=340133]MZH[/MENTION]ou module)
Backlight dimmer mod: more gradual transitions
backlight: fix a bug where the screen would be completely dark
backlight: clean the code
backlight: add minimum backlight brightness module param
backlight: scale max current when the brightness level is below 15
Add more linear setting:
CPU MAX frequency
CPU Governor settings
TCP congestion
GPU MAX frequency
more Color Profile
backlight dimmer
Tip: file manager as root browser or root explorer can run scripts without terminal emulator. :)
Reaktionen: qu4nd
Reaktionen: qu4nd
Für alle, die Android L nutzen gibt es jetzt auch eine Kernel Version.
hottix schrieb:
New release .... same features Linear 2.8 KK version
enjoy
:) :cowboy:
Linear 2.8 L-preview
Merge android-msm-hammerhead-3.4-l-preview source code
http://www.androidfilehost.com/?fid=23578570567722382
Bin zur Zeit im Urlaub und weiß nicht genau, wann ich dazu komme, den Eingangspost zu aktualisieren.
Update auf 2.9
hottix schrieb:
Linear 2.9 / 2.9-L
-Ofast optimizations flag
Graphite optimizations
Optimization flags to GPU drivers
Cortex A15 Optimizations
Sound Control: expose direct register manipulations to userspace
Sound Control: Misc clean up for newer WCD9xxx SOCs
Sound Control: let register lock be dependent on different hw revisions
Sound Control: separate locking mechanism for recording and playback
vfp: hardfloat
msm: use of swp{b} is deprecated for ARMv6+
ARM: be strict about FP exceptions in kernel mode
ARM: add support for kernel mode NEON
ARM: crypto: add NEON accelerated XOR implementation
ARM: 7835/2: fix modular build of xor_blocks() with NEON enabled
ARM: only allow kernel mode neon with AEABI
Download: http://www.androidfilehost.com/?fid=23610159112651527
Reaktionen: qu4nd
Er hat einfach mal vom Code_Blue Kernel gepickt und das net in den Credits oder auf github erwähnt (so wie es sich eigentlich gehört).
Es gibt keine Regel dies so zu tun, aber es gilt auf xda praktisch das ungeschriebene "GPL+ Gesetz", dass man dies doch tun sollte;)
[KERNEL] [KK] [L] [Linear 2.9] [Linaro GCC 4.9.1] [08/07] - Post #158 - XDA Forum
Und das der "Dev" nun darauf hin das "Projekt" zumindest auf xda einstellt ist für mich ne kindische Trotzreaktion!
Es hat ihn niemand attackiert, zumindest nicht öffentlich. eng.stk hat ihn lediglich völlig legitim drauf hingewiesen das er schon erwähnen sollte wenn er was pickt (gebührt sich halt so unter Devs)
Reaktionen: AA1973 und qu4nd
OK, das ist nicht in Ordnung. Man weiß aber auch nicht genau, was da per PN passiert ist, also würde ich mir nicht so ein schnelles Urteil erlauben.
Ich werde auf jeden Fall versuchen, regelmäßig im italienischen Forum rein zu schauen und Updates hier zu posten. Und damit zurück zum Thema... :)
Reaktionen: qu4nd
Gute Neuigkeiten!!! Der Dev hat mich auf XDA kontaktiert und mir berichtet, dass er drüber nachdenkt, den Thread dort wieder öffnen zu lassen. Unabhängig davon arbeitet er derzeit auch an einem Update.
