[KERNEL][JB][JWR66V/JSS15J]Franco Kernel R193
  • 2.031 Antworten
Vielleicht mal vorsichtig die Kontakte der USB Buchse am nexus säubern.. Mit nem Zahnstocher oder was anderem nicht-leitenden eventuelle Beläge abkratzen. Wenn das oder die software nix bringt, fällt mir erstmal nichts weiteres als kaputter Akku/kaputte akkuladeelektronik ein
M3 wurde veröffentlicht:
http://minooch.com/franciscofranco/Nexus4/4.2.2/milestones/zips/franco.Kernel-Milestone.3.zip
Milestone 3:
Improvements from Milestone 2:
* Major focus on several key areas:
- Hotplug driver completely re-coded from scratch with focus on code simplicity and fast code execution rather than complicating what is simple. There are only two states while the screen is on: dual-core under normal operations such as UI interaction and light apps; quad-core under major device stress such as games. The threshold to online all cpus is under /sys/class/misc/mako_hotplug_control/first_level
- Together with the re-coded Hotplug driver I engaged into several custom improvements to Interactive governor. Now the governor tunables are dynamically scaled either your device is a dual-core or a quad-core. This will maximise your battery during normal UI operations while increasing your gaming experience while in quad-core mode. Also changed a lot of code that decides how to ramp the CPU frequencies, in my opinion better than before
- Also reworked the touch boost logic, which ramps the CPU to a higher frequency to ensure maximum UI smoothness. Now its less intrusive in the code and more straight forward
These were the key improvements over M2. Along with these there were a lot of smaller changes across the Kernel. Also includes faux’s GPU governor which reduces heat by not over-utilising higher GPU frequencies when its not needed.
Habe gerade M3 geflasht. Ist es normal das bei Berührung des Display sofort auf 2x1 Ghz getaktet wird? Das erinnert mich irgendwie an Mpdecision.
Ich glaube das war schon länger so. Was mir neu ist, dass nie weniger als 2 Kerne online sind, auch wenn ich on den hotplug Einstellungen auf 1 reduziere..
KWL sind scheinbar weiterhin deaktiviert.. Hat jemand ne Ahnung wie man die manuell wieder aktiviert, ohne den kernel neu zu kompilieren?
Angeblich verbrauchen 2 Kerne auf 384 Mhz nur unwesentlich mehr als ein Kern auf 384 Mhz.
Vielleicht wird sich Franco ja gnädig zeigen und ein toogle für die KWL einbauen, ich glaube es aber nicht.
Ist normal und auch sinnvoll, mit der App kann mans nicht gewollter Weise nicht ändern aber per Script schon.
Ich hatte mit dem M3 gestern 4 Stunden Display-On Zeit (Habe Zeitung gelesen) und noch 40% Restakku. Ich muss wohl nicht erwähnen das da vollzeit zwei Kerne am rödeln waren. Auf den Verbrauch wirkt es sich jedenfalls nicht negativ aus.
Als kleines Beispiel: 1 Kern bei 1000 Mhz verbraucht mehr Strom als zwei Kerne bei 500 Mhz. Die ganze Peripherie der kleine CPU läuft ohnehin, da geht die Milchmädchenrechnung nicht ganz auf.
Und am Rande: Den Franco kann man meiner Ansicht nach nicht selbst kompilieren da er im Git nicht alles public hat was dafür nötig wäre.
Den franco kann man selber compilieren. Gibt nen Fork und einige im franco Thread die das machen.
hells
Ja hab ich vorhin auch gesehen, bin auch schon dabei es selbst zu tun...
Wenn du nicht weiter kommst, kannst mir ne PN schreiben. Vielleicht kann ich weiterhelfen. Ich compiliere zwar nicht den franco, aber vielleicht weiss ich trotzdem weiter ;)
hells
Mit dem Simple GPU Governor und den Standard-Einstellungen (5, 6000) ist meine GPU dauerhaft auf 400 Mhz. Ist das gewollt? Was genau hat es mich den Einstellungen eigentlich auf sich - ich finde kein Doc dazu.
Danke!
Blue
wo kann ich den in der franco app den gpu governor umstellen
bei mir ist da nix
oder ist der simple jetzt default und man kann ur noch den takt ändern?
Der Simple ist standard.
hells
Reaktionen: blue8 und papn2
Schön, nach zig erfolgreichen Nightlies habe ich nun mit m3 einen Bootloop.
Kann ich da einfach mal das Handy erzwungen ausschalten und neu starten oder ist das ein zu hohes Risiko?
Was willst du denn sonst machen? Dafür ist der Hardware Knopf ja da, hoffe nicht das du da jetzt 1 Stunde gewartet hast.
? Bootloop heißt doch quasi, dass es ständig neu startet..kling als wäre der DL korrupt oder du hast irgendwelche UV/OC settings die der m3 nicht mehr verkraftet..
Ab ins recovery und Vorgänger nightly wieder flashen..
Hab ca zehn Minuten gewartet und dann Hard Reset. Jetzt geht alles.... Komisch.
Ein kleiner Versionssprung :D
Chancelog R161:
* Fixes a bug on the CPU load calculator
* Small code optimisations from upstream Linux Kernel
Gut das der CPU load Bug behoben wurde. Ich hatte mich die ganze Zeit gewundert, weshalb das Hotplugging mit den Per-App Power Modes nicht wirklich funktioniert hatte und die Schuld auf den Franco Kernel Updater geschoben.
Das bezieht sich doch auf die letzte nigty oder ist der bug auch in der milestone 3 vorhanden ?
In Milestone 3 ist der Bug noch drin. Franco wird aber einen Hotfix raus bringen und vielleicht M3 ersetzen.
IceDevil
alibiy
alibiy
droidjam
droidjam
droidjam
Caho
