MadMurdoc
Ehrenmitglied
- 6.047
- Themenstarter
- #21
Done.
reneph schrieb:@ssauger: Hast du den Kernel im Einsatz? Auch mal paar Spiele gespielt o.ä., was das Handy länger durchweg belastet? Wie sehr heiß wirds denn? Große Unterschiede bzgl. der Wärme zu anderen Kerneln?
Mir gruselt es etwas, dass franco die Temperatur, ab der die CPU runtergeregelt wird, um satte 20 Grad angehoben hat :S
ssauger schrieb:das sind 6 °C.
derPianist schrieb:Der Kernel läuft exzellent.
Einzig die verstärkte Vibration stört.
via Google Nexus 4
r11:
* Add Thalamus Generic ARM Hotplug Control which means mpdecision will no longer be activated
r10:
* Add USB Fast Charge - to enable: echo 1 > /sys/module/msm_otg/parameters/fast_charge
Changes up to r9:
* Custom ramdisk with my usual tweaks and changes
* Lean kernel = no useless debugging
* Ondemand tweaked for battery life and performance balance
* msm_hsic wakelocks are decreased by a huge margin compared to stock
* No more ramping to 1026MHz when the screen is touched = better battery life
* Added fsync on/off toggle
* Solid battery with no performance loss
* Lots of other small changes not very visible (kernel config, small tweaks etc)
DMX schrieb:Weiß einer schnell aus dem Kopf ob der Kernel standardmäßig fsync an oder aus hat? Und welche App ist denn gut zum Einstellen? TricksterMod?
r14:
* Compiled with more GCC flags for some noticeable performance improvements - placebo or not me and minooch both felt improvements
* Improved Thalamus Hotplug routines timings: Increase sampling time to decrease the number of onlines/offlines; tweak the values for onlining and offlining a single core; instead of staying 2 seconds without offlining cores (after they are either all online or it called boostpulse), they now stay for 5 seconds to reduce onlining/offlining, and it also provides a bigger boost if the device needs that extra burst of performance power for at least those 5 seconds.
* Increased interactive hispeed_freq to 1026MHz
* Tweaked gamma values a little bit by reverting one of Google's previous patches - whites look whiter, yellows and greens are a little bit less strong. Overall in my opinion it looks much more vivid.
