[KERNEL][JB][JDQE39] Air Kernel [Weekly: 19/05/13 | Stable: -]
  • 46 Antworten
Maestro85
Maestro85
Dauer-User
369
19/05/2013
xxxxxxxxxx
Code:
- Based on AOSP Kernel Source (android-msm-mako-3.4-jb-mr1.1)
- the Latest Linux Kernel (Linux Kernel [B]3.4.45[/B])
- Kernel Build with [B]O3[/B] optimization
- Wlan: Prima [B]v3.2.2.3[/B]
- [B]Governor[/B] : [U]Wheatley[/U], Lazy, Interactive, Intellidemand, DanceDance, Ondemand, Conservative, Performance
- [B]Scheduler[/B] : [U]ROW[/U], FIOPS, Noop, Deadline, SIO, Cfq, V(R), BFQ v6
- [B]TCP Advanced Congestion Control[/B]: [U]Westwood[/U], Reno, Bic, Cubic, Highspeed, Hybla, Htcp, Vegas, Veno ,Scalable, Lp, Yeah, Illinois
- [B]CPU Frequency[/B]: 286Mhz, [U]384Mhz[/U], 486Mhz, 594Mhz, 702Mhz, 864Mhz, 1026Mhz, 1188Mhz, 1350Mhz, [U]1512Mhz[/U], 1620Mhz, 1722Mhz
- Support Under Clock and Over Clock
- Support Sweep2Wake
- Support Auto Hotplug Driver (Thanks to _thalamus)
- Userspace Voltage (Thanks to Morfic)
- Under Voltage Default !
- Sound Control (Thanks to Faux123)
- FSync Control (Thanks to franciscofranco)
- Built Toolchain with Linaro gcc 4.7.3-20130415
- USB Fast Charge (Thanks to Chad0989 and motley)
- Tune the Touchscreen filter (Thanks to cst4you)
- Disabled Mpdecision and Thermald in Ramdisk
- Fixed HSIC WakeLock and Wi-Fi
- Optimized CRC32 and ARM RWSEM Algorithm (Thanks to Ezekeel)
- Support NTFS R/W
- More Tweaks and Tune for N4 !
- Etc ...
Weekly #10 (05-19-2013 KST / GMT +9:00)
-Update Linux v3.4.45
-Add Lazy cpufreq governor (Ezekeel)
-Add suspend_frequency in Auto_Hotplug (using TricksterMod App)
-Add Sweep2Wake
-Add PA's Display Color
-Update the latest freezer patch
-Merge the latest 'android-3.4' branch
-Etc...
Weekly #9 (05-11-2013 KST / GMT +9:00)
-Update Linux v3.4.44
-Update wlan: prima v3.2.2.3 and adjust McastBcastFilter value = 3
-Update the latest msm_cpufreq
Weekly #8 (05-05-2013 KST / GMT +9:00)
-Update Linux v3.4.43
-msm: Add suspend_freq userspace module
(module path: /sys/module/mipi_lgit/parameters/suspend_freq
more info: https://github.com/edoko/Air_Kernel-...26e726f1d8231f)
-Added headphone poweramp controls (faux123)
-lowmemorykiller: make default lowmemorykiller debug message useful
-cpufreq_interactive.c: Set hispeed_freq = 1188Mhz and adjust timer slack value
Weekly #7 (04-30-2013 KST / GMT +9:00)
-Build with O3 optimization
-Fix CPU voltages
-Add franco's temp threshold control
-Update interactive and conservative governor from android-3.4 and linux 3.9
-Tune for auto_hotplug, wheatley, interactive and row i/o scheduler
-dynamic fsync: favor true case since most will be using this feature
-aio: convert the ioctx list to radix tree
-Add overall_stats
-ARM: fault: assume no context when IRQs are disabled during data abort.
-and more....
Weekly #6 (21-04-2013 KST / GMT +9:00)
-Rebase !!
-Fix some lags
-Update new AOSP Mako kernel source
-UV -50mV
-etc...
Weekly #5 (17-04-2013 KST / GMT +9:00)
-Enable MODULES in kernel config
-Disable Multi-Core Power Saving Mode(SCHED_MD) // It occur all cores onlines;;
-Update the latest 'ROW I/O Scheduler' from Codeaurora
-hrtimer: Consider preemption when migrating hrtimer cpu_bases
-hrtimer: Prevent enqueue of hrtimer on dead CPU
Weekly #4 (14-04-2013 KST / GMT +9:00)
-Update Linux v3.4.40
-Tune auto_hotplug and some governors(Wheatley, DanceDacne)
-Enable Multi-core Power saving mode(SCHED_MC) (Default value: 2)
-Tune the touchscreen filter (Thanks to cst4you)
-ASoC: add missing updates from CAF (Thanks to faux123)
-Enable retention
Weekly #3 (10-04-2013 KST / GMT +9:00)
-Re-Chagne I/O Scheduler: FIOPS -> ROW
-Add max_online_cpus by motley
-Tune auto hotplug values
-Tune some I/O Schedulers
-Increase Voltage +25mV
-Update 'Sync' from android-3.4
-Update 'netfilter' from android-3.4
-bfq: attempt to fix use-after-free which affects SLUB behavior
-Revert "cpufreq: restrict the max and min freq permissions ..."
Weekly #2 (09-04-2013 KST / GMT +9:00)
-Chagne I/O Scheduler: ROW -> FIOPS
-Disable SmartassV2 governor
-Add faux123's Gamma Control
-Add Accuracy Filter Control by franciscofranco
-Switch do_fsync() to fget_light()
-Revert "wlan: Fix for ARP offload issue"
Weekly #1 (07-04-2013 KST / GMT +9:00)
-First Release
O2
-Version:
Stock CPU Clocks [CPU Clocks (286Mhz~1512Mhz)]
AR
-Version:
U.C (Under Clock) + O.C (Over Clock) Features [Support Under / Over Clock (286Mhz~1722Mhz)]
O2- AR-
[XDA]
Reaktionen: ehrles, ronnsen und Flextrick
Um was für einen Kernel handelt es sich bei dem hier?
Oder ist das auch einer der mit den anderen jetzt mitmischen will?
Wenn ja kann irgendwer schon sagen ob der gut ist, obwohl ich glaube dass es noch nicht so viele getestet haben^^
ist halt schwer sich jetzt noch zu behaupten bei so einer vielfalt an kernel und roms^^
That's true ... :D
Ich hab den hier vorgestellt, weil ich im XDA aufgeschnappt hab, dass der Air Kernel schon beim Galaxy Nexus sehr gut angekommen sein soll.
Von daher, warum auch nicht auf dem N4?
Das habe ich auch gelesen, mal schauen wie der Kernel sich hier entwickelt :)
Hab mir den kernel mal geflasht.
Mit der Chameleon läuft der bisher richtig gut - schauen wir mal den restlichen Tag weiter :)
Gesendet von meinem Nexus 4 mit Tapatalk 2
Habe den Kernel seit gestern auf meinem N4, und bin sehr zufrieden mit damit. Das Nexus läuft sehr weich, und der Akkuverbrauch ist für meine Verhältnisse sehr gut.
Betreibe den Kernen mit dem Carbon-ROM, und werde auf jeden Fall erstmal dabei bleiben. :)
Mittlerweile ist der "Weekly: #3" schon online, bin mal gespannt, ob das Teil genauso gut gut läuft wir der #2er.
Downloads :
--> Weekly Build - #3
<JellyBean 4.2.2>
#3 Link (MS SkyDrive): http://sdrv.ms/Zkxgyh
#3 Mirror Link (MediaFire): http://www.mediafire.com/?dismpid4np0njne
Change Log :
Hab die aktuelle im OP aktualisiert.
Versteh nicht, warum der Dev die Kernel-Version "Weekly" nennt, wenn sie doch täglich (und damit Daily) ne Frischkur bekommt. :confused2:
Und wie schauts aus?
Wifi Problem präsent immer noch? Touch Control Support funktioniert?
Ansonsten hat der Kernel eine Menge überflüssige Govs.
WiFi funktioniert bei mir (Notification Fix). Habe zusätzlich zum Kernel noch Multicast und Broadcast in der Wifi-INI zugelassen :)
Die Governors finde ich persönlich gut, da kann jeder das einstellen, was er möchte. Intellidemand empfinde ich persönlich als gute Balance zwischen Akku und Leistung.
Touch Control scheint (noch) nicht zu funktionieren.
Neues Update. Achtung: Es gibt nun zwei Ausartungen. Eine mit Stock-Taktfrequenz und eine mit UC- bzw. OC-Funktionen/Support.
Mal testen :D:D
Macht es was aus wenn man nominal Chip hat und den Ar Flasht?
Könnte man download Abschnitt im opener mal abändern? Denn mit tapatalk ist es unmöglich etwas down zu loaden :D
Getippt von meinem zivi
Wo sieht man was für einen Chip man hat bzw. wo kann man das einstellen?
https://www.android-hilfe.de/forum/...o-cpu-klasseneinteilung-qualitaet.354562.html
ist im Forum sogar angepinnt...
Edit:
@ronnsen
würde mich sehr stark wundern, wenn irgendein vernünftiger Kernel irgendwelche Probleme mit verschiedenen CPU-Klassen hat. Das würde eigentlich nur gehen, wenn der so stark übertaktet/undervoltet ist, dass "niedrigere" CPUs nicht damit klar kommen, das macht aber eigentlich niemand. Verbessert mich, wenn ich falsch liege.
So schön ist der Kernel nicht, bei mir läuft es alles andere als flüssig. :/
Da lief mein System mit annähernd gleichen Einstellungen mit dem Motley oder Hells flüssiger.
Dito murdoc!
War nicht lange drauf zwei Std oder so.
Ich verfolge den Thread auf xda. Seit Release 4 scheint der Kernel nicht mehr so rund zu laufen.
hells
Wir sind ja mittlerweile bei Release 10 und der läuft super. WiFi Notification Fix ist drin (neuste Prima Treiber) und funktioniert.
Reaktionen: ronnsen
Ja definitiv ein super Kernel geworden. Das System läuft wie Butter und die Verzögerung im WLAN sind bei mir zu 100% verschwunden.
Bester Kernel für mich weiter so.
