PL50
Dauer-User
- 1.191
franco.kernel
franco.Kernel features:
Downloads:
Milestone 4 (stabile Version): Index of /franciscofranco/Galaxy Nexus
Download Milestone 4 (stabile Version) bei World-of-Nexus
Nightlies: Index of /franciscofranco/Galaxy Nexus/nightlies
franco.Kernel updater app: https://market.android.com/details?id=com.franco.kernel
franco.Kernel updater app from AndroidPit: franco.Kernel updater - Android Apps and Tests - AndroidPIT
franco.Kernel updater app features:
* Downloads the kernel directly from the ftp
* Checks for updates directly from the ftp
* Checks and downloads Imoseyon's kernel (new feature)
* Kernel auto-flash
* Cpu frequencies changer
* Governor changer
* Voltage control interface
* Kernel settings:
* Hotplug enabler
* Color Control - You're able to change GAMMA values and Color Multipliers to achieve the best color profile
* Sound Control - Increase the max volume of your device
* Download special franco.Kernel boot animation
* Wi-fi special mode to boost signal during streaming while on screen off
* Custom download path
* Live calibrated voltages panel
* Disable logger
* SQlite defrag on boot
* Dedicated milestone and nightly kernels changelogs
Source: https://bitbucket.org/franciscofranc...oid-tuna-omap/
F.A.Q:
1. My device rebooted or crashed, how can I help?
A: Get me /proc/last_kmsg or logcat.
2. Battery sucks, my device is not entering deep sleep. FIX PLOX!
A: Fix it yourself, it's an app waking your device up not the kernel's problem
3. Signal is dropping since I flashed the kernel, amg u sucks!
A: The kernel has nothing to do with gsm/cmda signal. Make sure you have the latest radios
4. Do I need to wipe anything when flashing this kernel?
A: No.
5. Does this kernel has X or Y mod?
A: Learn to read, everything you need to know is in the features list, changelog or public repo.
- THIS IS ONLY FOR 4.0.3 or 4.0.4. If you ask if it works on older roms I will shoot you
- Overclock up to 1350mhz
- Custom Voltage Control from Ezekeel
- Completely updated CRC32 library that is used for a lot of core functionaties of the system
- CFS scheduler tweaked for the best user experience
- Stock GPU clock - reason(http://forum.xda-developers.com/show...postcount=4731)
- CFQ I/O scheduler is default
- CFQ I/O scheduler tweaked for flash devices and backported from 3.1
- Ext4 tweaked and patched up for performance
- I/O writeback backported from 3.2
- SLQB memory allocator as default
- USB HOST enabled
- TUN enabled
- ColorControl from Ezekeel
- Command: echo "-10 0 -2" /sys/class/misc/colorcontrol/v1_offsets
- this is just an example, values range between -255 and 255. If you want the values to stick on reboot create an init.d script or use my app
- Hotplug mod added. Works independently of the governor. Shuts down cpu1 on screen_off and wakes it up again on screen_on
- To disable: echo 0 > /sys/module/dsscomp/parameters/hotplug_enabled
- To enable: echo 1 > /sys/module/dsscomp/parameters/hotplug_enabled
- Custom ramdisk included with proper ext4 mounts for performance
- Kernel config stripped out from debug shit (only logcat and dmesg stayed)
- A lot more stuff that can be seen on my repo
- /sys/class/misc/colorcontrol/multiplier
- color multiplier triple (default = factory settings; set with 'echo "2004318071 2004318071 2004318071" > multiplier' for example; if the safety is enabled the color multipliers cannot be raised above the factory settings)
Downloads:
* Kernel auto-flash
* Governor changer
* Kernel settings:
* Hotplug enabler
* Disable logger
F.A.Q:
A: No.
