[Kernel 4.2.2+4.3+4.4] Golden Kernel v1.8 [24.12.]
  • 46 Antworten
Radagast
Radagast
Ehrenmitglied
23.366
Selbst probiert, läuft prima smooth und schnell, der
Golden Kernel
aktuell in der v1.6
der Golden Kernel ist ein Hybrid aus
Amperific's A.S.K.P und boype's Fanc-Kernel ...
Kernel-Features:
1.0/1.2
  • Linux Kernel 3.0.88
  • Linaro optimized
  • Fast charge enabled
  • Proportional Rate Reduction for TCP
  • Updated LowMemoryKiller driver (directly from 3.9 experimental kernel)
  • Added fully functional zCache and ZsmAlloc, backported from 3.4 kernel
  • Make zRam LZ4 decompressor work faster in the same CPU cycles
  • Introduce Dynamic Cache Pressure (now you need the correct binary to compile this kernel)
  • Revise Dynamic Writeback algorithm
  • Deep Sleep tweaks
  • Introduce Timer Slack Controller
  • Dynamic PLL Overclock
  • CPU Unaligned Access (much faster booting time because of better kernel decompression)
  • Add newest Adaptive RED Net Scheduler from 3.4 kernel and make it default.
  • Backport OOM Killing algorithm from 3.8 kernel
  • Backport LowMemoryKiller and Timed GPIO drivers from 3.8 kernel
  • CFS kernel scheduler optimization
  • Predefine minfree and adj values
  • Latest Generic Hotplug Helper from 3.10
  • Added Sampling Down Momentum for dinamically changing the factor for scaling down
  • Tuned SmartassH3 to make more use of low frequencies (it's always recommended "Golden gov")
  • Buffer values updated from Samsung original sources(Triple Buffering, Camera)
  • Writeback tweaked to do the work only when the screen is off
  • New Golden Governor (what Golden governor does)
    • Linked boostpulse interface to this governor
    • GPU optimizations
    • Frame buffer member of project butter
    • More deep sleap tweaks
    • New LMK machine
  • updated HSMMC driver
  • RM CPU topology: multi-core scheduling
  • PGM support (still experimental, the dev of PGM app should add this kernel into his working list)
  • battery life extender (BLX)
  • custom voltage control
  • init.d support
  • selected patches from Google
  • TCP congestion control algorithms: westwood (default), cubic, reno
  • compiled with Google GCC 4.7 toolchain
  • control to set a minimum CPU frequency for screen-on (default: 384 MHz)
  • Optimized ext4 mount options
  • 307MHz to 512MHz GPU as indicated in filename
  • Offering lowered voltages
  • Sound Control with PureAudio values (yeah man, rock your world)
  • SAS controller
  • Fixed wifi! (In 4.2.2 version and 4.3)
  • Updated LZ4 compression from 3.8 drivers
  • Finetuned Golden governor
    • Better performances, better battery life
    • TouchSense+ linked from touchscreen drivers
    • Gamma control with external module (only in 4.2.2 version)
    • System lagfixes
    • Frequencies revisited with entropy control
  • PGM support
  • Elevated SystemUI priority
  • Temperature control
  • zRam module updated from 3.10 kernel
  • Dynamic predefine Undervolt
  • GPU code Improvements
  • LZ4 references to /kernel folder
  • SpeedUp Boost
  • BuiltIn module for WLAN thanks to amperific
  • Finetuned Westwood TC Protocol
  • ION Memory Allocator backported from 3.10 kernel
  • LMK Plus machine ported from 2.3.6.39 kernel (even if it's an old version, it's the most fastest on the market)
  • Removed Google Snappy
  • zsmalloc updated into Golden Governor
  • Finetuned SioPlus shed
  • Updated ROW I/O from 3.10 kernel
1.3/1.5
  • Bug fixes, stable relase
  • New GoldenX governor
    • Added GoldenX GPU control
    • Fixed freq
    • Kernel Samepage Merging enabled by default
    • Added BoostPulse interface
    • Linked BoostPulse to the touchscreen driver (now the governor can really "sense" a touch and boost the frequency after a specific time threshold)
    • Fixed the Deep Sleep states verification for scaling
  • Added LowBattery Powersave feature for goldenX and interactive governors
  • ROW I/O algorithm revisited from 3.10 kernel
    • ISIX ROW interface for more stability
  • New experimental "Zen" sheduler
  • Re-switched to Linux Kernel 3.0.89
  • Improved touch drivers
  • New Golden I/O Scheduler (what golden sheduler does)
    • Fast latency algorithm
    • Smart screen wakeclock
    • RCU boost and systicl tweaks (now your phone should work like butter)
    • BLD (Battery Low Drain)
  • Wakelock tweaks for WLAN and LTE modem from 3.8 kernel
  • User voltage control
  • Backport interactive patches to interactiveX of 3.4 kernel
  • Lot of logging disabled (fastest phone boot time)
  • Updated GPU Drivers for more smoothness
  • New GoldenX2 governor
    • Better freq. scaling
    • BLS (Battery life saver) when the battery is on >5%
    • Updated idle parameters
    • Finetuned entropy boost
    • Finetuned C4 queue
  • VM, Filesystem, and other governor tweaks
  • Updated Hybla and Illinois TCP Congestion
  • Dynamic Readahead
  • Low Memory Killer from 3.10 Kernel
  • Sysctl Vm Optimizations at boot
  • Fastcharge control
  • DTIM skip override (what DTIM does)
  • Revisited Golden I/O Scheduler and updated its driver to 3.10 kernel
1.6
  • Fixed all freq. scaling on 3.4 kernel
  • Added power.tuna.so into the 4.3 kernel's zip
  • Tweaked GoldenX2 governor (for now the best Golden Gov. than ever)
  • Revisited Hybla TCPC (with totally new values for ipv4 optimizations, probably I'll make a Golden TCP Congestion)
  • Revisited Westwood TCPC
  • Undervolt down to (0-1-2-3-6) (less battery drain with high frequencies)
  • RAB algorithm from experimental 3.11 kernel
  • Tweaked Golden I/O Scheduler (now with the fastest latency on the planet)
  • Updated BLX
  • Revisited PGM support, now It's all on the dev's hands
Downloads
Wipe Dalvik and Cache partition before flashing this kernel
Android 4.2.x
Download Milestone XXF08 - Latest
Download Milestone XXE07
Android 4.3
Download 4.3 XXE07J - Latest
Download 4.3 XXE07J
Sources: https://github.com/Jeeko/Golden_Kernel_4.3
Reaktionen: Alex_R3CONN3R, Don_Ron, owie und 2 andere
Interessante Kombi! Werde ich mir sicher mal angucken...
Wird er auch für 4.2.x weiterentwickelt?
Bislang auch für 4.2.2 ....
Golden Kernel
aktuell in der v1.6
Kann ich voll und ganz so unterschreiben der läuft bei mir auch seit letzter Woche und ist Top:thumbsup::thumbsup:
Scheduler: Gold
Governor: GoldenX2
@BVT
sorry, aber da hat sich bei der Version für 4.3 ein Verschreiber eingeschlichen;
mfG
Gesendet von meinem Galaxy Nexus mit der Android-Hilfe.de App
Hab momentan den Fancy r36 ext am laufen. Was denkt ihr, lohnt sich ein Umstieg bzgl. Akkulaufzeit? Hat die beiden schonmal jemand verglichen? Da ich wieder auf Stock 4.2.2 zurück bin (wegen des WLAN- und AKKU-Bugs von 4.3) und der Fancy für 4.2 leider nicht mehr weiterentwickelt wird, könnte dieser Hybrid eigentlich ganz interessant sein.
Der Fancy kennzeichnet sich ja durch seine Stabilität und Akkuperformance. Wie sieht's bei diesem hier aus?
Patman, da stehe ich wohl auf dem Schlauch, sehe ich nicht :confused:
Ja Fancy ist ein guter Kernel hatte ich auch als r36 ext!! aber der Golden läuft einen zacken smoother und ist bei mir im Akkuverbrauch besser als Fancy. Aber jedes GNEX reagiert doch etwas anders:bored:
@BVT
Die Endungen im Post lauten beide auf 7J;
im Download steht für die Neuere jedoch 8J.
Hoffe, ich hab mich nicht verlesen.
MfG
Edit.
Hab nochmal gekuckt, meine Angabe sollte stimmen.
Reaktionen: Radagast
@Sherge69: Danke für die Info, dann werde ich ihm mal ne Chance geben!
Ah, Patman, nun sehe ich das auch, ist copy&paste aus den XDA-Thread gewesen ...
Ändere ich morgen, per Tapa wird das wieder nichts :rolleyes:
Danke :thumbup:
Reaktionen: Patman75
Habt ihr mal ein paar Empfehlungen bzgl Einstellungen für mich? Bin jetzt (durch die neue Trex früher als erwartet^^) vom Fancy zum Golden, aber aktuell wirkt das ganze auf mich noch nicht ganz so flüssig...
Dieser Frage schliesse ich mich mal spontan an , bin bei der Slim gerade ebend mal von LK auf Golden gewechselt und iwi überzeugt mich der Wechsel auch noch nicht so ganz.
Also mal speziell an unsere Friends T-REX600 , Jori66 und bmngog ... , seid doch mal bitte so lieb und postet doch mal Eure bisherigen Einstellwerte - Danke schonmal.
Meine eingestellten Werte bisher ... läuft gefühlt bei mir nicht groß anders als der LK
- ALLGEMEINES
westwood
1536
Golden
Min 192000
Max 1036800
Max Bildschirm 384000
Min Bildschirm 192000
Governor auf GoldenX2
- SPEZIFISCHES
WLAN-Hochleistung AN
Inhaltsspezifische Helligkeit AN
Energiesparmodus 0 (AUS)
Dynamisches FSYNC AUS
Temperaturlimit 60°
ZRAM AUS
Ich habe die Standard Einstellung des Kernels
Scheduler: Gold
Governor: GoldenX2
Der ursprüngliche Beitrag von 20:53 Uhr wurde um 20:57 Uhr ergänzt:
Jori hat z.B. Westwood und auf Interactive
Reaktionen: qu4nd und Don_Ron
Meine ...
Was nicht zu sehen ist, wurde nicht geändert ..
Reaktionen: qu4nd
Was ist denn nun besser bei Read Ahead Buffergröße ... niedriger Wert oder eher hochziehend ?? Ich habe wieder die damals vonT-REX und Jori verwiesenen 1536 genommen , wenn ich Deinen 600er Wert dagegen sehe ... ist ja nen Riesenunterschied.
Habe auf XDA mal gelesen, mehr ist schneller, kostet aber auch Akku ... Frage mich nicht, wo genau ich das gelesen habe ...
Daher nehme ich einen Mittelwert ... ;)
Reaktionen: Don_Ron
Hier mal die Werte die Nephilim für den Golden wohl auch nimmt und in seinem Thread empfiehlt ...
Cubic
Golden
Read Ahead Buffer: 1024 (The results for RAB will vary so experiment and find one that works best for you if mine do not yield preferred results.)
GoldenX2
Min: 192mhz
Max: 1036mhz
Max Screen Off: 384mhz (this is to avoid lagging/stuttering of music playback when screen is not on)
Min Screen On: 192mhz
WiFi High Performance: Off
Force Fast Charge: Off
Multicore Power Savings: 2
High Performance Sound: On
Headphone Volume Boost: 1
Dynamic FSYNC: On
Tempature Limit: 75
GPU: 384mhz
ZRAM: Off
Smartreflex: All On (MPU undervolted by 50 across the board) [with any undervolting there is a risk of freezing and/or SOD's, not all devices play nice with lower voltages so if you find that you are encountering issues just return to stock]
Reaktionen: qu4nd und Radagast
ich find den Golden auch erstmal gar nicht übel; läuft noch nicht lang, scheint aber flott und stabil zu sein, Einstellungsoptionen passen super für mich.
Ich fahr momentan mit 192MHz/1,3GHz, sioplus/interactivex, GPU auf 384MHz.
Scheint wie geschmiert zu laufen.
MfG
Edit.
Und natürlich spackt mein Gerät mit 1,5GHz rum, soll heissen, der re-bootet einfach wie von Geister- (Nsa :D?) hand.
Ist immer unheimlich wenn das Smartphone Aktionen anstrebt die man selbst gar nicht auslöst :D.
firsttyphoon
  • firsttyphoon
4 5 6
qu4nd
qu4nd
rotation
Borstole
Radagast
oif
oif
