Port Rom [ MiUi 10.2 Xiaomi.eu v8.12.13 ] für Cubot Max
  • 47 Antworten
h0sch180
h0sch180
Moderator
Teammitglied
2.116
Technischen Werte:
Android Version: 8.1
Linux Unterbau: Android 6.0
Unterstützt sehr viele Sprachen
Installation:
1. Custom Recovery Booten (Power- und Volume+ Taste) ((TWRP))
2. Lösche Dalvik, Cache, System und Data
3. Lösche Internen Speicher
4. Neustart in Recovery
5. Kopiere per USB vom PC die ROM auf das Handy
6. ROM installieren
7. Dalvik löschen
8. Handy neustarten
Installation wenn vorher ein anderes MiUi 10 installiert war:
3. ROM installieren
4. Dalvik löschen
5. Handy neustarten
Update Miui 10 Xiaomi.eu:
3. ROM installieren
4. Dalvik löschen
5. Handy neustarten
Download ROM:
Miui_10_Xiaomi-eu-8.8.23_Cubot_Max.zip
Miui_10_Xiaomi-eu-8.10.11_Cubot_Max.zip
Miui_10_Xiaomi-eu-8.10.18_Cubot_Max.zip
Miui_10_Xiaomi-eu-8.10.25_Cubot_Max.zip
Miui_10_Xiaomi-eu-8.11.22_Cubot_Max.zip
Miui_10_Xiaomi-eu-8.11.29_Cubot_Max.zip
Miui_10_Xiaomi-eu-8.12.6_Cubot_Max.zip
Miui_10_Xiaomi-eu-8.12.13_Cubot_Max.zip
CHANGELOG 8.12.13
Weather
New - Add cloudy and smog animation
Optimize - Optimize large font and screen density related issues
Storage
Fix - Device internal storage could not be encrypted
Launcher
Fix - Default theme Icons bounce
Fix - UI elements on the screen where you entered your custom screen lock were truncated
Lockscreen
Fix - Screen flickers while unlocking.
Fix - Double press power button torch can't be turn on
CHANGELOG 8.12.6
Settings
Optimized - The Apps section of the Settings got a structural revamp.
CHANGELOG 8.11.29
Statusbar
Optimize - Toggle for LTE icon to 4G
Display
Optimize - Optimize automatic brightness behavior for Pie devices
Security Center
New - Facebook cleaner added
CHANGELOG 8.11.22
Statusbar and Quick Settings
New - NFC toggle added
Optimization - LTE icon changed to 4G
MiCloud
Fix - Fixed MiCloud backup
Network Location
Optimization - Optimize network location services
CHANGELOG 8.11.15
Screen Recorder
New - Option to record system sounds
Camera
New - Super-slow motion 960fps for MIX2S, MI8
CHANGELOG 8.11.8
Lock screen, status bar, notification bar.
New notification bar support to display the VPN icon (only supported on non-notch screen models)
Fix - drop-down notification after bar, the battery icon text is not displayed correctly
Calculator
Fix - Calculator converter module floating widget can not be dragged
Camera
New - Super Night mode function (Mi 8 standard / EE version / Mi 8 Pro / Mi MIX 2S)
Settings
Fix - Personal hotspot, when password is modified and click save, hotspot will automatically shut down
File Manager
Fix - Sporadic category page search function causes crash
Fix - Search interface icons display is truncated/cut off
Sound Recorder
Fix - After a pausing recording, notification is not displayed in status bar
CHANGELOG 8.11.1
System
Optimize - Optimize system stability and performance
CHANGELOG 8.10.25
System
Fix - Mi Cloud Backup does not work
Fix - Mi Music controls does not display on lock screen in MIUI 10
Fix - Texts display overlap in device options
Fix - Selected contacts gets deselected automatically on pressing back multiple times
Fix - No notification for some 3rd party apps at Android 9.x (eg. Telegram, Hangouts...)
Optimization - Option to select Notifications style (MIUI or Android)
Gallery
New - Frame edit option added to photo edit mode
CHANGELOG 8.10.18
System
Fix - Fixed the problem that the full screen "return" gesture is invalid (10-16)
Fix - Fixed the problem that the page was grayed out after answering the call and hanging up during the QQ voice call (10-16)
Fix - Fixed auto brightness sometimes does not work (10-17)
Fix - Fixed slow boot on Android 9 (10-17)
Optimize - Added notch support the display of notification icons, go to "Settings - Notifications and Status Bar - Show Icons when Notifications" [Except MI8] (10-17)
Settings
Fix - Fixed the problem of setting search failure (10-15)
File manager
Fix - Fixed the problem that the renamed or decrypted file cannot be searched (10-16)
Fix - Fixed a crash when modifying Bluetooth receiving files (10-16)
CHANGELOG 8.10.11
Optimization - Notification Bar shortcut switch editing page, support direct click on/off shortcut switch
Optimization - Notification filter setting page to adapt third-party theme
Fix - Holster mode does not display lock screen interface problem
Fix - Error fingerprint can still unlock successful problem
Fix - The problem that the fingerprint cannot be unlocked during the call
Fix - The flashback problem caused by the group notification in some cases
Fix - The problem that the resident notification is displayed on the lock screen.
Fix - The problem that the fingerprint icon overlaps with the lock screen notification
Clock
Optimization - Ringtone reminder function
Recent Tasks
Fix - The problem of applying screenshots in the split screen state
Danke an die BETA Tester und Unterstützer:
- @kokesilv
Wenn Dir meine ROM's gefallen, darfst du meine Arbeit hier auch gerne honorieren.
Screenshot_2018-09-28-11-06-41-553_lockscreen.png Screenshot_2018-09-28-11-06-47-939_com.miui.home.png Screenshot_2018-09-28-11-07-09-653_com.android.settings.png Screenshot_2018-09-28-11-07-16-755_com.android.settings.png Screenshot_2018-09-28-11-07-53-718_com.android.settings.png Screenshot_2018-09-28-11-08-04-134_com.miui.home.png
Reaktionen: Focuspok, ralle77, wassolldas und 2 andere
sehr gute Arbeit geht perfekt ein ganzes 10
Reaktionen: h0sch180
Ausgezeichnet!
Meiner Meinung nach noch besser geeignet als das MiUi 10 Pro v8.9.11:
1.) deutsche Tastatur mit ä, ö, ü und ß,
2.) noch schickere Bootanimation!
Herzlichen Dank, das behalt ich so ;-)
Reaktionen: kokesilv
Heute Nachmittag hat's mir plötzlich - ohne erkennbare Ursache - den SafetyNet-Status auf rot gestellt. Hab dann später das angebotene Magisk-Update ausgeführt, rebooted, keine Änderung. Im Anhang die beiden Screenshots dazu.
Gibt's da vielleicht einen Patch dazu?
Screenshot_2018-09-29-17-40-30-980_com.topjohnwu.magisk.png Screenshot_2018-09-29-18-51-58-712_com.topjohnwu.magisk.png
@Bavor
Ja, hab ich hier auch, seit irgendwann heute. Denke Google schraubt wiedermal an der API rum. Einfach mal ein paar Tage abwarten.
zu mir wenn es gut funktioniert magisk kannst du xposed in dieses rom legen?
darf ich mal fragen was der Unterschied zwischen der
MiUi 10 Xiaomi.eu und der
MiUi 10 Pro
Rom ist.
Danke und Grüße
Bug1303
PS: vielen lieben Dank für die Tolle Arbeit hier.
Du kannst Dir das so vorstellen:
Miui Pro ist wie Resurrection Remix, also Funktionen ohne Ende, jedoch werden nur wenige Sprachen unterstützt.
Xiaomi.eu ist wie Lineage, nur das wichtigste dafür stabiler, schneller und es werden viel viel mehr Sprachen unterstützt.
Reaktionen: Focuspok, Bavor, kokesilv und eine weitere Person
@ Bug1303
Beide können deutsch. Diese konkrete Unterschiede sind mir aufgefallen:
- Pro hat ein Ausschalt-Menü mit mehr Funktionen, z.B. Neustart in den Recovery-Modus
- EU hat deutsche Tastatur und eine sehr schlichte "europäische" Bootanimation, die vom Pro ist bunter, "chinesischer".
- Pro hat eine viel bessere Wetter-App vorinstalliert, lässt sich aber beim EU problemlos nachinstallieren: Weather Mate (Weather M8)
Unterschiede also nicht wahnsinnig gravierend.
@ alle: Diese ROMs beherrschen das Ein- und Ausschalten per Zeitplan, ein eingestellter Wecker startet das ausgeschaltete Handy! Das konnte noch nicht mal das StockROM!
Bin begeistert!
Reaktionen: h0sch180, Bug1303 und kokesilv
@Bavor
- Das Erweiterte Ein-/Ausschalt-Menü kannst du in den Entwicklereinstellungen vom EU anschalten
- Pro: System Animationen einstellen
- Pro: Schnellzugriffseinstellungen
- Pro: Mehr Benachrichtigungsmöglichkeiten
- Pro: Mehr Einstellungsmöglichkeiten bzgl. Ton & Vibration
usw.
hehe, hab grad 2x Cubot Max vor mir liegen 1x mit Pro und 1x mit EU
Reaktionen: Bug1303 und Bavor
Mmmh, danke, jetzt weiß ich, was ich demnächst mache, da werden ich wohl noch etwas herumspielen müssen!
Hallo, wollte mal zur Kamera was fragen. Kann das sein, dass die Bildqualität unter CrDroid deutlich besser war? Mit MiUi kommen mir die Farben alle so verwaschen vor und stellt meiner Meinung nach auch nicht so richtig scharf.
Hab's gerade mal mit der Open Camera probiert und das sieht deutlich besser aus.
Ich verwende OpenCamera, damit sehen die Bilder ganz gut aus.
Aber ja ich geb Dir Recht mit der Default Camera App ist es schwer ein scharfes Bild zu knipsen.
Ich wollte bei der ROM eine VPN Verbindung einrichten, komme aber nicht aus der Einrichtung der Bildschirmsperre weiter.
Ich kann ein Muster oder Pin einrichten, kann dieses aber nicht abschließen. Das gleiche ist wenn man über Bildschirmsperre & Sicherheit geht. Hier ist keine Eingabe möglich.
Bildschirmsperre geht bei mir ohne Probleme mit Muster oder PIN
Update auf 8.10.11 ist da!!
Reaktionen: Bavor, kokesilv, LHGB und eine weitere Person
Gibt es eine ungarische Sprachschnittstelle? Ist das wirklich eine Oreo-Version? Welche Versionen der manuell installierten APK-Pakete werden benötigt?
Is there a Hungarian language interface? Is this really an Oreo version? Which versions of the manually installed APK packages will be needed?
@h0sch180
das müsste ja dann funktionieren wie bei der Pro-Rom, nur Dalvik, Cache und System löschen.
Vielen Dank
@LHGB
Ja, genauso hab ich aktualisiert.
[doublepost=1539546191,1539545973][/doublepost]@Focuspok
Andere Sprachen als die, die enthalten sind, kann ich leider nicht einbauen.
Framework + GUI ist von Oreo, Basis ist Android 6.
Reaktionen: Focuspok, newfreddy, kokesilv und eine weitere Person
Mit dem Update ist auch die Original-Kamera wieder besser geworden......
Reaktionen: h0sch180 und Bavor
h0sch180
  • h0sch180
davidng
h0sch180
  • h0sch180
h0sch180
h0sch180
