dickenseck
Stamm-User
- 425
To stop battery drain & prevent screen from waking every few minutes - **only for original Kogan ROM**
(with thanks to hallokitty for this fix)
This happens because the tablet keeps looking for the 3G signal it cannot ever receive. To fix this, go to System/app using Root Explorer from the Market, delete (or rename) phone.apk and TelephonyProvider.apk. You will immediately start getting errors but just use the reset button at the back of the tablet and when you reboot the problem has been solved. If you ever want to restore these apk's (e.g. if you want to use a 3G modem) just flash the phone+telephony zip file below using clockwork mod.
Lt. den xda-developern sollte auch das app: Auto Airplane Mode linderung schaffen.
Hab leider mein tablet nicht mit in der Arbeit um es zu testen...
