Gwadro
Dauer-User
- 285
Neue Version 1.2.1 verfügbar:
Release Notes
26/02/2012: v1.2.1
Additions
integrated Run Log viewer, real-time updates
include actions in Run Log
added PureWidget K9 variation package name
Test Element: added Continue-on-Error parameter
Run Log: when tasks stop due to service stopped (e.g. Tasker turned off), log as status ExitKill
Prefs / UI / Item Drag Margin (especially for Adam)
menu scene element items draggable from margin
Menu / More / Developer / Write Device Capabilities
2 new builtin icons: private and public
(currently invisible) preparations for community portal
scene list: destroy menu option for created tasks (not in beginner mode)
action For: items parameter ranges can contain variables e.g. %start:10:%step
scene elements: long-click option: Initial Focus
actions: Variable Query, Enter Key: give initial focus to text box by default
actions Menu/Popup/PopupTaskButtons/EnterKey/VariableQuery: Show Over Keyguard parameter
action Show Scene: extra Display As type: Activity, Full Display, No Title
text scene element: Text Format parameter (see help text)
flag warning for System Lock when device manager not enabled
updating from pre-1.2: set long-click and click action preferences to new defaults
constant border round scene in preview mode (some scenes not visible otherwise...)
workaround for data initialization bug in SVOX
action BeyondPod: added 3 speed-setting commands
listen for BeyondPod playback status intent (for %MTRACK)
action Scene / Test Scene
continue on error parameter for Say/Say To File
Total Screen Control compatibility based on Screebl API
attempted workaround for ICS shell problems (Input category actions etc)
Bugfixes
&,<,> in scene names caused data crash
showing a scene with some elements initially hidden would cause crash
updated ipacks for ICS (fix vibration bug, improve pulldown look)
Variables tab long-click option Clear All was crashing
main screen: dragging up through + button was showing variable tools in non-variable tabs
project tab deletion: fadeout animation was snapping back at end
import files for first time not downloaded by Tasker, wasn't creating relevant import dir
popup task buttons default scene was allowing deletion of buttons
deleting scene: was counting all scene references, not just references to the scene-to-delete
deleting scene: was counting references internal to scene only
elements with a background tab: element contents were overlapping border
text elements with scroll enabled: whole background was scrolling instead of just text
slider scene element: Test Element, Value was returning wrong value
slider scene element: Test Element, Value: pick-up user-set values
'task running' indicator in Task Edit screen: was not turning off correctly with some actions (e.g. Music Play)
action Menu: cloned item layouts weren't being resized on display
action Clear Array: name was not supposed to be optional
Show Scene wasn't working with a builtin menu scene
main screen, bin row wasn't always highlighting properly while dragging
action Due Today: parameter wasn't displaying correctly
state BT Connected: don't trim whitespace from selected name, might prevent detection
errors from scene element list selection mode None
on rotation, scene larger than display wasn't being resized to screen size properly
on rotation,scene element focus was being lost
actions Dpad/Type: variables weren't working for Repeat Count parameter
datadef export: maxversion tags weren't completed, missed icon args version
scene editor could occasionally leave orphan anonymous tasks in the data
scene editor: pasting a copied element was not cloning anon tasks
show scene: if scene was already created of a different type, was failing with errors
show scene: switching an already-showing scene from dialog to overlay was failing
volume set events for %VOLR etc: ignore if previous and current values are the same
Menu action: menu scene wasn't being dismissed if not menu entries had actions assigned
minimize chances of timing issue where new task arrives just as old about to execute
various sizing problems with landscape orientation
attempted fix for honeycomb repeatedly-updating permanent notification problem
Menu scene element: element edit screen: switching from background tab to items tab could cause crash
crash in some instances from timing issues destroying scenes while it's still in process of being shown
attempt to catch elusive crash around map element control and updating
action Element Map Control, when mode Set Zoom allows variable
task with action Show Scene with variable name for scene was getting stuck after showing scene
state Cell Near: getting neighbouring cell data was failing
scene elements actions immediately after Show Scene could cause exception
catch crash from testing wimax state on some devices
try catch crash for unknown reason from language initialization
Show Scene: flash error when trying to show disallowed elements in overlays (instead of crashing...)
possible crash initializing Set Light action
Scene Edit: after deleting a MapView, adding one to the scene was crashing
action Array Pop from global variable to local variable was failing (and possible vice-versa)
Lock scene: initially was too wide for some displays and could cause zoom problems
exporting scene element descriptions: don't include builtin tasks
Text Width Scale % wasn't working correctly for Button / TextEdit elements
actions Read Line / Read Para: wasn't accepting local var for Line/Para parameter
task description export, action labels weren't mentioned
multiple user events for display off or on were handled poorly internally
concurrent modification exception bug was cropping up occasionally
creating, initializing then showing an overlay display was losing the initialization
catch any exception from config and import parsing
undo was crashing when it caused removal of an element which was focused
scene element text stroke event wasn't responding
edit texts were not wrapping for text-based input types
increased TTS timeout to 10 seconds
increased element and scene frame thickness
strip spaces from variable array index expressions (catch %arr(1 ))
changed Roaming Settings action name to Mobile Data Settings
Perform Task: changed %par1 and %par2 parameter labels
scene element button: pad text to avoid going over button side
scene element text: small padding to avoid touching edges
don't trim whitespace from match patterns or their targets for Variable Value and action conditions
all non-array actions except join in the variable category now allow specification of format %arr(1) and %arr(%index)
Changes
volume set events: not reported if at max/min and so didn't change
use trash icon for deletion in menus, instead of red cross
improved look of several builtin scenes (delete existing builtin scene in Scenes tab to regenerate)
project icon now exported with project
Run Log preference control moved to the Run Log viewer
Hide/Destroy Scene: if it doesn't exist, doesn't stop task
slider scene element: allow some extra margin at the side for large thumb icons
scene import/export: include tasks immediately referenced by scene
action Get Voice: workaround for Android not-notifying-on-cancel bug
Menu / Data / Save Definitions -> Menu / More Developer
datadef.xml includes action/state plugins currently on device
datadef.xml parameter definitions include optional stipulation
datadef.xml parameter definitions include default privacy stipulation
use app context for speech/music play, attempted fix wakelock problem some have
record scene, task and project creation dates
task import: importing tasks with same name and creation date as existing, overwrite instead of rejecting
scene list: show created tasks with green text instead of a star icon
menu scene: changed example item
moved datadef.xml (and new capabilities.xml) to meta/ subdir
don't manually recycle bitmaps on ICS+
show state Invert flag in Beginner Mode
autobackups: don't write human-readable version anymore
action Show Scene: relabelled Overlay, Blocking, Full Display to Overlay, Blocking Full Window on ICS+
action CPU: took out import restriction
dialog/activity scenes: with a non-secure keyguard, no need to swipe after interaction
Scene text element: 'Allow Scrolling' parameter is now called 'Vertical Fit Mode' and has an extra 'Reduce Text Size' option
Popup/Popup Task Buttons scene: text squashed to fit by default
default scene background colour is mostly transparent
scene edit: use system wallpaper as background
action CPU: accept variable for governor parameter
element event stroke: increased default Length parameter, was interfering with Tap on same element
cope better with user resizing menu scene item layout scene
TextEdit scene element / action Test Element: use text box value instead of stored value
Release Notes
26/02/2012: v1.2.1
Additions
Bugfixes
Changes
