Dr.No
Ehrenmitglied
- 7.519
Wer kennt die beliebte Custom Rom PARANOID ANDROID nicht? Das Team meldet sich mit der ersten Stable basierend auf Android10 zurück.
Wer also ein ASUS Zenphone Max Pro M1/M2 sein eigen nennt, für den könnte es interessant sein.
(Quelle)
(pa-blog)
For this initial stable release we will have the following features:
- Included GAPPS inside the zips.
- April 2020 Security Patch Level.
- OTA support (with deltas).
- Adaptive Playback.
- Screen stabilization (Gimbal mode).
- SafetyNet (most devices).
- Built-in screen recorder.
- FOD support (Fingerprint On Display).
- Pulse notifications.
- ParanoidDoze: extended AOD support
- Off-screen gestures.
- Gestures support.
- Vibration adapted UI.
- Extended vibration system (OnePlus devices).
- Alert Slider UI (OnePlus devices).
- OTS: On The Spot, introduce user hint prompt system, uses a snackbar design to prompt the user for changes.
- Pocket Mode, introduces a mode that will detect whenever your device is on the pocket and prevent it from waking.
- Fast Charging indicator (includes OnePlus devices).
- Quick Settings Pull Down with one finger.
- Extended Restart.
- Introduced Settings reset for PA features under Settings → System → Reset Options.
- Double tap to sleep on keyguard (lockscreen) and launcher.
- Volume Long Press to Skip Tracks.
- Volume panel on left for devices with left volume buttons.
- Adjusted statusbar notifications per device.
- Navigation bar customization.
- Improved lockscreen security
- Caffeine tile (thanks LineageOS).
- Extended screenshot support (thanks Pixel Experience).
- Per-app cellular data, vpn and wifi restrictions.
- Three finger swipe down for screenshots.
- Pop-Up camera support.
- Based off CAF LA.UM.8.2.r1-04200-sdm660.0 tag.
(Quelle)
(pa-blog)
