GB Battery program counter to show how much of the battery, and more
  • 0 Antworten
AtnfasHoak
GB Battery program version 1.5
*programming by @atnfas_hoak
Twitter: @atnfas_hoak
GB Battery version 1.0
* Show counter how much of the battery stylishly
* Knowledge of the health of the battery
* Know the temperature of your phone (battery)
* Knowledge of the rate of use of the battery
* Find out which programs are consuming battery charge
* Make sure in case your phone was shipped shipping real or imaginary
* Know what type of charger cable in case the AC or Usb
Support Arabic, English, French, and soon more languages
Supports all versions
GB Battery version 1.2
*Fix the problem does not appear to see the Data battery is used
GB Battery version 1.5
*Add widget Battery
*Now it supports the German language
*Display battery information when pressing the battery widget
*The possibility of knowing changelog
*Fix some problems
download GB Battery 1.5
tomaso7
  • tomaso7
tomaso7
tomaso7
Cecoupeter
Cecoupeter
CircumStrontium
CircumStrontium
CircumStrontium
