[ROM][N910F][5.1.1] *11.08.15* SOKP R9.0 [SONIC OPEN KANG PROJECT][AIO]
  • 4 Antworten
BustedFly
BustedFly
Stamm-User
184
A premium quality Android OS from Sonic-Developers
DISCLAIMER:
#include
*Click Here To Read More Disclaimers
We would like to thank Google AOSP ,Slim-ROMS ,CyanogenMod for their device trees, hardware repos , frameworks/Settings mods and their code that was incorporated into this project. We also extend our gratitude to the devs whose code that we have incorporated. Proper authorship has been maintained and can be viewed on our repository.
We would also like to credit
My Friends @thereassaad & @worstenbrood
Dolby Developers Team
Zeroinfinity(i love you you are my motivation....)
Koushik Data
aki_007
Rizal Lovigs
ibanez7
RockoDev
Acid
ImbaWind
Developers of HWAUIE ACSEND P6 k3v2oem1 Device
Developrs of Acer E1 Device
Sonic-Developers & Members...
Our Dynamic supporters & Beta-testing Team
If we still miss any one by-mistake Please don't start Thermo-Nuclear War or Ward War -3 in with me In thread Just Push a PM to me we will Add your Name to list if you deserve it ...
Click Here to visit the Detailed List of Credit that we maintain
STATUS BAR :
Clock & Date with custom definable location and styles along with selectable custom colors
Customizable Status bar Battery icon with percentage .
Status Bar Brightness control
Option to Enable & Disable Network Activity Arrows
Double Tap to sleep option on status bar
Status Bar Task Manager
Quick Settings :
26 user Selectable Quick Setting tiles including Ambient Display,Nav Bar ,Slim Actions, Live Display, Gesture Anywhere ,Battery Saver & App circle bar tile.
Switch to Disable & Enable Enlarge view of first row tiles.
Option to Set four Tiles In a row of quick Settings.
Switch to enable/disable vibration on tile touch.
Switch to enable/disable Brightness Slider.
Options to add max 3 actions in Slim Action tile.
Configurable QS Quick Pull down .
Configurable QS Smart Pull down.
Animation Controls:
IME Animations
Over Scrolling Effects
Toast Animations
List View Animations
AOKP System Animations
Option to Enable/Disable Scrolling Cache
Scrolling Modifiers.
Navigation Bar
Switch to Enable/Disable onscreen navigation bar
Navigation Bar buttons large number of buttons provided including Screenshot, power menu, custom application buttons etc.
Navigation bar dimensions
option to select menu location
Switch to enable/disable landscape view of navigation bar.
Hardware Buttons:
Switch to enable/disable hardware key buttons
Buttons back light option
Option to hide/show/auto detect overflow button
Customizable key actions including normal press,long-press, double-tap actions for back,home and menu key.
Power-Menu:
More them 10+ user configurable power menu options this includes bellow mentioned buttons
Screen Shot ,Screen recorder, Advanced reboot, Custom Application, users
PIE Control :
Switch to enable/disable pie control
Configurable various number of buttons including button style and button second layer
User configurable button styles with trigger option , custom color,transparency ,and size
Option to configure menu visibility in pie controls
Display Settings :
User configurable brightness settings along with adaptive brightness .
Display sleep settings from 15 sec to 30 min including 45 sec step.
Daydream
Expanded Desktop with per application configuration
LCD Density Settings
En chased font size slider
Auto Display rotation with all rotations angles including 180 degrees .
Screen Cast
Custom Display options like volume rocker wake ,wake on charger plugged/unplugged .Double tap to wake (supported devices only)
Ambient Display with Advanced Doze options including Doze pulse .
Live Display:
Live Display modes
Color temperature Settings
Switch to enhance colors
Color calibration including RGB sliders
Gesture Anywhere &vApp Circle Bar :
Switch to enable/disable Gesture anywhere & app circle-bar along with tile on QS
Option to set gesture location, trigger width ,height, position
Recents Panel :
Switch to select slim and stock recents panel
Custom background ,text color option in slim recents
option to show/hide topmost task in slim recents
Configurable recents applications size in slim recents
Sounds & Notifications
Interruptions
Enable/disable camera shutter sound
Enable/disable safe headset volume
swap volume buttons when screen is rotated
Volume steps
less frequent notification sounds can be configured from 3sec 5 mins
User configurable per application notifications
Notification lights with custom color options for missed cal ,voice mails etc [only supported devices ]
Battery light with custom color option [only supported devices] for battery low,charging, pulse if battery low, and fully charged lights
Heads Up Notifications with Snooze timer and time out options .
Security & Lockscreen :
Privacy Guard
Smart lock
Double tap to sleep anywhere on lock-screen
Show/hide advanced reboot
Hide quick settings on secured lock-screen
Lock Screen Shortcuts
Other Options :
Dolby Digital and Digital plus as standalone sound controllers.
Layers RRo 2.1 with orion to launch layer manger from Settings
Wake Lock Blocker
Screen Recorder with external audio , video-size, and bit rate options.
Custom application settings menu with privacy guard .Appops settings
Configurable media scanner behavior on boot.
Device partition info on Storage settings.
Option to hide super user indicator.
Disable FC notification
Kill apps back button with configurable time option
Option to show CPU info on Development settings
Custom colors for battery saver and trigger options
Advanced Keyboard options like auto rotation with time out,disable full screen keyboard ,volume key cursor control.
Still list continues .................................For more updated And Detailed List of Features with images visit here
Minimum Requirements To Install SOKP:
Your Device Should be Rooted with Unlocked Boot-loader & Latest Custom recovery Installed.
Recommended Custom Recovery TWRP : Click Here to View TWRP Offical supported devices
Installation Procedure:
(A)If you are making a Fresh Installation(or Coming from any other rom other than SOKP) :
Boot Into Recovery Mode
Wipe Data,System,Cache,Dalvik
Flash provide latest SOKP ROM Zip
Again Wipe Cache and Dalvik
Reboot To System
Now again Reboot into Recovery Mode
Flash latest G-Apps
Wipe Cache and Dalvik....and Reboot To System.
(B)If you are already Running SOKP Rom But You want to Update with latest Version:
Flash provided Updates of SOKP ROM(latest weekly)
Reboot To System.
Reaktionen: McMiller
Habe die Rom auch probiert aber sobald ich meine Apps installiert habe stürzt das Dolby Digital Plus immer ab und es kommt die Meldung Digital Sound Beendet:-(.Schade ansonsten Top
Hab die ROM gerade mal drauf gemacht...Problem wenn ich Telefoniert habe, und will auflegen bleibt das Display schwarz ;-(
Rom hat aktuell sehr viele Probleme.
Ich mache hier mal zu auf bitten von BustedFly, Da die ROM sehr viele Probleme hat und er leider keine Zeit den ROM Thread in deutsch zu pflegen.
der Pulsar
