meetdaleet
Ehrenmitglied
- 3.724
Hier könnt Ihr eure Erfahrungen mit der PAC-ROM austauschen und die jeweils aktuelle Version finden.
Originalthread:
[Z1] PAC-ROM [JB4.3.1][CM][AOKP][PA][HALO & PIE] - Nightlies & OTA & Custom 1013 - xda-developers
Features:
Download:
https://s.basketbuild.com/devs/pacman/honami/
Changelog:
Reserved - Post #2 - XDA Forums
(Auszug im Spoiler)
Changelog:
1013:
- MEOW-kernel -
Initial version - Default CM kernel features
MEOW-kernel bootlogo
Implement wcnss_service
Use sony illumination_service
Misc mr2 updates
- ROM -
Android 4.3.1
Contacts: Allow hiding frequently contacted lists
SmartDialer: show quick contact on long press
Active Display: Fixes and updates
Blacklist: fix settings
Fix notification shortcuts
Updated PAC-console
Charger: Draw battery percentage over charger screen
Let user know the exact battery capacity
charger: Toggle backlight while in charger mode
charger: support alarm in power off charging
charger: modify usb unplugged shutdown time in power off charging
charger: press power key to turn off charging animation
system/core: Add support for EVRCNW audio format
Camera: Adds longshot commands
Fix black wallpaper issue when home pressed
Performance profiles
Frameworks: Bluetooth and WiFi fixes and updates
AppBar fixes
Partial rewrite of network traffic indicator
Animation Settings: Added more animation speeds
PAC in Black: updated graphics
Fix for the low processes kept bug
Re-implement orientation aware volume buttons at lower level
Fixed touch sounds
Added Chameleon OS Gesture Anywhere
1001 / 1010:
Initial version
1013:
- MEOW-kernel -
Misc mr2 updates
- ROM -
Android 4.3.1
Updated PAC-console
AppBar fixes
Fixed touch sounds
1001 / 1010:
Initial version
XDA: DevDB Informationen
PAC-ROM (nightlies & custom builds), ROM for the Sony Xperia Z1
Contributors/Unterstützer/Mantainer
jeroenqui, Langes
ROM OS Version: 4.4.x KitKat
ROM Kernel: Linux 3.4.x
ROM Firmware erfordert: entsperrten/offenen Bootloader
Basiert auf: CyanogenMod
Versions Information
Status: Nightly
Erstellungsdatum 2013-10-10
Letztes Update 2014-09-08 (Thread)
Letztes Update 2014-10-09 (ROM)
