[ROM][Nougat][7.1.2][NJH47F][Official][Weekly] CarbonRom MOO
  • 1 Antworten
Aaskereija
Aaskereija
Inventar
5.601
CarbonROM is an aftermarket firmware based on the Android Open Source Project. We are dedicated to fast, stable, and feature-filled roms, honesty and communication with our users, and openness with our code. We like frequent builds, with the very latest and greatest hardware support and fixes. We strive to not only provide you with the best rom we can build, but also to give back to the Android community and our fellow developers. For us, this is about creating something we can be proud of and hope you will enjoy.
Please feel free to look, build, and use our code at CarbonROM's GitHub... and at CarbonROM Gerrit.
Disclaimer:
While we make every effort to test these builds as much as possible, we are not responsible for anything that may happen to your device, family, pets, or perception of reality. We ask that you do your part to know your device and know how to recover from problems before you flash!
Download:
CarbonRom
Gapps (Pflicht)
Installation:
Features:
-> Based on the stock 3.4 kernel.
-> Using stock camera blobs from .236 release.
-> Passes SafetyNet (enforcing)
-> Everything device specific similar to SuperLamic's LineageOS build
Bugs:
-> WLAN kann Probleme machen
-> You tell me
Credits:
I would like to thank the following people for all their help in development for this device:
-> nailyk
-> tomascus
-> SuperLamic
-> rcstar6696
-> Myself5
and anyone else who has contributed in any way and I may have inadvertently left out. Thanks y'all!​
Contributors
drakonizer
Source Code: CarbonROM · GitHub
ROM OS Version: 7.x Nougat
ROM Kernel: Linux 3.4.x
ROM Firmware Required: Must have flashed stock .236 at least once.
Based On: AOSP + CAF
Version Information
Status: Stable​
Meine Erfahrung zur Rom:
Positiv
  • Stabil
  • Schnell
  • Voll funktionsfähige Kamera! (Abgesehen der Sony features die man durch das öffnen des Bootloaders verliert)
  • Substratum
  • Viele Optionen
  • komplett Deutsch
Negativ
  • WLAN funktioniert nicht richtig und saugt extrem am Akku durch ständiges Suchen
  • Navigation Bar kann nicht ausgeblendet werden
  • Menü Icon fehlt in der NavBar
  • Multi-Screen-Funktion nicht vorhanden
  • Sperrmuster braucht nach einem Neustart ein paar Sekunden bis es reagiert
  • externe SD wird vom Gerät als DF76-3789 angezeigt.
Neutral
  • Magisk funktioniert nur in veralteter Version (v12)
  • Xposed verursacht Bootloop
  • Viper4Android funktioniert nicht aufgrund von Berechtigungsprobleme
  • einige Apps haben ein problem Root zu erlangen
  • Kein PIE Control
