[ROM][KK][KTU84Q][Honami] AICP - 6.0 - KK 4.4.4_r2 | OFFICIAL NIGHTLIES
  • 4 Antworten
Hen Ry
Hen Ry
Enthusiast
1.672
AICP - Android Ice Cold Project
OFFICIAL AICP NIGHTLY BUILDS
Release version: AICP V 6.0
What's New
Based On Android 4.4.4_r2
AOKP based with heavy modifications
A LOT
Detailed Changelog can be found by the download link!
KERNEL:
Kernel in this rom follows CM source.
Feature list:
Changelog :
-PIE (Thanks PA)
-Identicons
-HeadsUp: support in floating window, timeout options
-Configurable InCallUI
-Add Weather info to notification drawer with options
-Searchable Settings
-Swipe to float for notifications and recents
-Contacts Speed Dial support, other patches
-MMS: custom notification vibrations
-MMS: per conversation settings/ringtones
-Privacy Guard from SlimRoms (Thanks)
-Configurable Proximity check
-DocumentsUI patches
-ActivityManager patches
-F_AV patches
-MIUI style carrier text in statusbar
-AICP stats
-Dialer fixes
-Notification spam filters
-User defined wifi/tether networks
-Heads Up: always in expanded mode, hide on lockscreen
-CM11 Themes patches
-SlimRecents background colors and transparancy
-SlimRecents card/text color
-Dialer: CallRecording
-Incoming call contact details
-OverScroll effects
-6bar signal icon style
-Quick Camera (Longpress power key to open reboot dialog then longpress power key again
to open the camera)
-Volume panel background color and transparancy
-APN updates
-Brightness slider in notification drawer
-WiFi in Power menu
-SlimFileExplorer added (Thanks to Slim)
-SoundRecorder added (Thanks to CM)
-PhotoPhase added (Thanks to CM)
-Mounting options under Storage options
-Move2SD support
-DSP Manager: Add loudness enhancer, few other patches
-Add reverse lookup provider "Das Telefonbuch" (DE).
-Enable SD card format
-MonthCalendarWidget (Thanks to OmniROM)
-Telephony patches
-Fix app removal FC's.
-Disable camera shutter sound
-QuiteHours reworked and fixed, new options added
-AppCircle Sidebar: Add configurable trigger region
-Vibration options: Duration and multiplier
-NavBar: transparency support, cursor keys
Fazit:
Das gefällt mir persönlich besser, viel mehr Einstellmöglichkeiten als org. CM11 Nightly.
- AICP OTA
- Rom Steuerung
- AICP extras
- ListView Animation geht hier besser als mit dem Xposed Modul "XuiMod". Da gibt es Fehler in der Darstellung (unsauberes scrollen) z.B. bei Tapatalk und Facebook.
Reaktionen: Scum
Traut sich hier keiner ran, läuft jetzt schon längere Zeit bei mir, bin sehr zufrieden damit.
Hat sich viele getan seit dieser Release Version: AICP V 6.0 - 09-09-2014.
Sehr viele Einstellmöglichkeiten.
aktuelle Changelogs und hier
An der letzten kam Pie aus ParanoidAndroid hinzu.
Ich werde mal zu gegebener Zeit paar Screenshots machen und noch was darüber schreiben.
Reaktionen: Scum
Also muss sagen, einfach toll. Du hast nicht zu viel versprochen, genial viele Einstellungsmöglichkeiten. Muss aber zugeben, dass ich an der einen oder anderen Seite überfordert bin, was die Einstellungen bewirken. Wäre schön, wenn Du ggf. Einstellungsmöglichkeiten mal alle erklären könntest. Ist ja alles auf Englisch (an alle anderen - nur die besonderen Einstellungsmöglichkeiten - die Rom ist auf deutsch). Weiß nicht ob eine Zusatzapp wie Lokale etwas bringt.
Die Akkuleistung könnte jedoch besser sein, wird sich bestimmt bei mir noch einpendeln.
Ach, auf xda habe ich die Rom gar nicht gesehen, habe ich glatt überlesen :)
Reaktionen: Hen Ry
AICP_OTA ist mittlerweile mit Werbung. Die Übersetzung der App wurde von mir vollendet, es scheiterte bis dahin an den Umlauten die ich dann durch ae, oe, etc. ersetzt habe.
Edit: Werbung wurde wieder entfernt.
Reaktionen: Scum und gense
Aaskereija
Aaskereija
Aaskereija
Sunny
scherzy32
  • th3chos3n
Aaskereija
Aaskereija
