[ROM][KK][KOT49H][HOMEMADE] OmniRom [4.4.2][HONAMI]
  • 48 Antworten
Hen Ry
Hen Ry
Enthusiast
1.672
Wer Omnirom schon vom XZ kennt, hier ist es für das XZ1.
neue Bootanimation mit der Build 20140216
Anbieter
Androguide.fr Follow me on Github
ROM OS Version: 4.4.x KitKat
ROM Kernel: Linux 3.4.x
ROM Firmware Required: Unlocked bootloader
Based On: AOSP
Installation im Recovery
aktuelle Build
omni-4.4.2-20140315-honami-HOMEMADE - Download -> camera fix installieren da die Kamera sonst nicht funktioniert
ältere Builds
omni-4.4.2-20140227-honami-HOMEMADE Download
omni-4.4.2-20140218-honami-HOMEMADE Download
omni-4.4.2-20140216-honami-HOMEMADE Download
omni-4.4.2-20140215-honami-HOMEMADE Download -> Fehler bei "Battery saver mode" -> the process "com.android.systemui" has ended -> diese Version erstmal nicht installieren!!!
omni-4.4.2-20140213-honami-HOMEMADE Download -> in dieser Version gibt es das Problem nicht!!!
omni-4.4.2-20140211-honami-HOMEMADE Download
omni-4.4.2-20140210-honami-HOMEMADE Download
omni-4.4.2-20140209-honami-HOMEMADE Download Build2
omni-4.4.2-20140206-honami-HOMEMADE Download
omni-4.4.2-20140204-honami-HOMEMADE Download
OmniRom's general changelog
alle Changelogs - honami-HOMEMADE
2014-03.15 (Latest)
  • Merged all upstream commits
  • Prepared most things for official support submission (Only some Camera2/framework fixes needed before it's ready)
  • Latest Pimped Kernel with intelli_plug properly working without breaking wifi
  • Re-added the following cherry-picks:
    • Multiwindow
    • Kit-Kat style UI elements
    • Camera button unlock
    • Minimum vibration duration
  • TWRP wieder integriert
2014-02-27
General: Merged latest upstream OmniRom commits
Kernel:
  • added msm_cpu_freq_limit driver
  • merged upstream CM kernel commits/fixes
2014-02-21
Kernel:
  • Added latest intellidemand (v5) governor with eco mode (c26061)
  • Added latest intelliplug driver (2.0) (0a54f9c)
  • Sound Control: add register cache (53cbae)
  • Sound Control: add power amp registers access control as well (8b878a)
  • Sound Control:work around for WCD93xx audio issues (b93c95)
  • enable unaligned capability for ARM (forgot to enable in previous build) (2d6ad3e)
2014-02-20
Kernel:
  • Added Sweep2Wake & DoubleTab2Wake (Experimental/Not working) (1761ca / edae65 / 199920)
  • Added Dynamic Fsync (forgot it yesterday) -> enable it in Settings/Performance/Advanced Settings (79915b)
  • Enabled MSM_MPDECISION (1af56ea)
  • Added new powersuspend driver and disabled early_suspend (8a132)
  • Added LZ4 decompressor module (63aef)
  • Enabled EFFICIENT_UNALIGNED_ACCESS (ace9a8)
  • Ondemand: set MIN_LATENCY_MULTIPLIER to 20 (83c036)
  • Conservative: set MIN_LATENCY_MULTIPLIER to 20 (88bdd1)
  • switch the protection of percpu_counter list to spinlock (310ab6)
(2014-02-18)
Kernel
  • Implemented Faux123's latest Sound Control (v3) -> use the Faux Sound app or set manually (more on that later)
  • Implemented Dynamic Fsync
  • Added GPU Overclock support, up to 600Mhz and with 9 scaling steps
  • Added CPU Overclock up to 2.3Ghz
  • Added Wheatley CPU Governor
  • Added Badass CPU Governor
  • Added Lionheart CPU Governor
  • Added SIO I/O Scheduler
  • Added FIOPS I/O Scheduler
  • Added BFQ I/O Scheduler
  • Switched to XZ (LZMA2) compression -> the kernel now weighs about 3.5mb less than before
  • Added CPU overall_stats
Frameworks
  • Kit-Katified the indeterminate progress bars
Settings
  • Kit-Katified the Tabs indicators
  • Kit-Katified the data usage graph
  • Fixed QuietHours start time
2014-02-16
Settings
(detailed changelog):
  • Merge "Settings: FR translation" into android-4.4 8a82a71
  • Merge "Settings: Update DE-Translation" into android-4.4 311327e
  • [1/2] Settings: SeekBarPreferences tweaks cac47db
  • [2/2] Settings: Add custom periods for data usage measurement 9dce767
  • Settings: add Xperia Settings entry 6ddd195
  • Merge branch 'android-4.4' of https://github.com/omnirom/android_pack a730e0f
  • Base: Kit-Katify the data usage graph 8c7e792
Frameworks Base (detailed changelog):
  • Merge "[1/2] Base: Add custom periods for data usage measurement" int 4393e4f
  • Base: implement separate drawables/selector for Holo Light Seekbars 8642d00
  • [1/3] Base: Battery Saver mode 1b15ca0
  • Merge branch 'android-4.4' into cherry-picks db72487
OmniGears (detailed changelog):
  • Merge "OmniGears: DE translation-update" into android-4.4 640fedc
  • [2/2] OmniGears: SeekBarPreferences tweaks 1c0a163
  • Merge branch 'android-4.4' into cherry-picks 8db45c1
2014-02-15
  • Frameworks: Made UI widgets look like proper kit-kat UI widgets (experimental) -> (4a04c0d)
  • Cherry-picks: Add minimum vibration duration setting (under settings/sound) -> (93e3f0d)
  • Cherry-picks: QS: Reflect location mode in different QS drawables -> (90138c2)
2014-02-13
  • Kernel: built with -O2 and more optimization flags (cc4a472)
  • Kernel: fixed typos in the vidc driver/kernel header (da0eb4a / 4b97d59)
  • Settings: Added XperiaSettings with vibrator control & pen/glove mode enabled (cherry-picked from AOKP, credit goes to championswimmer)
  • Cherry-picks:
    Driving mode (under settings/more)
    Uses TTS to make the device speak for:
    • Allow changing Volume TTS
    • Incoming call
    • new Message from
    • read new message
    • battery fully charged
    • charging start
    • charging stop
    • Clock speak after screen turn on
    • Date speak after screen turn on
    • Which app allowed to speak for Notifications
    • Speak for Music track title (thanks Utkarsh for idea :D)
    • fix audio focus while music playing
    • add less speak notification
  • Cherry-picks:
    Add option to enable Notification Light when screen is on (I58be9646)
  • Cherry-picks:
    Updated Battery Saver Mode to the latest patchset
2014-02-11
  • Kernel: fixed surfaceflinger memory leak (thanks to Kali-)
  • Sound: re-added sound fix (was missing in previous build)
  • Cherry-picks:
    All in One Animation Control
    Allows to configure System, ListView, Scroll, and Keyboard Animations -> (I878e2e84)
  • Cherry-picks:
    Battery Saver mode
    introduce battery saver mode
    this based from what user want or what user do to saving the battery life
    this include:
    1. Automatically switch mobile network into what user choice and also disable mobile data IF wifi connected to an AP
    2. Automatically switch mobile network and disable mobile data IF battery low (battery level can configure)
    3. Reduce screen brightness based low battery (this feature will disabled if Auto brightness mode enabled)
    4. Not changing network IF on Call or Usb tether enabled or WifiAP enabled
    5. Not changing network IF there is Download/upload progress
    6. Support For Both GSM and CDMA devices (need someone to test for CDMA devices)
    7. every condition has an option :D
    8. Restore all network configuration if Smart Radio disabled
    9. Add Time Range to start Smart Radio
    10. allow device without mobile data support, to using this feature
    11. fix inconsistent battery low level
    12. rewrite to better performance
    13. modified the controller to support battery saver mode
    14. add bluetooth, gps, wifi, and mobile data (if support) to be disabled while power saving activated
    15. fix build QuickSettings because of LocationController change
    (I9d86ef14)
2014-02-10
  • Toolchain: Built with Linaro gcc 4.7 toolchain (from the 13.11 linaro release cycle) -> (2c92020)
  • Kernel: fixed a typo in the vidc driver causing the entropysel variable to be untyped (not committed yet)
  • Kernel: added quite a few optimization compiler flags (not committed yet)
  • Ramdisk: added OmniHonami bootlogo -> (79dcb98)
  • Camera: enabled all picture sizes up to 20.7mp & enabled the qualcomm/honami-specific scene-modes, iso levels, etc... -> (ee7cc9e)
  • Recovery: fixed TWRP and switched to it (the only bug is that a mouse cursor appears :confused:) -> (ec3d4bc)
  • Cherry-picks:
    Add Battery Flip tile:
    Front tile stay like default
    Back tile :
    1. temperature
    2. voltage
    3. condition
    (l28cdefc6)
  • Cherry-picks:
    Implement camera button with unlock feature. (thanks [MENTION=3160680]DAddYE[/MENTION] :good:) -> (I503d670c)
2014-02-09 (build 2)
2014-02-09
  • Fixed signal loss when making outgoing phone calls
  • Fixed DSPManager FC's
  • Fixed volume issues (still buggy with the included 'Music' app - a.k.a Apollo - but works fine in Google Play Music)
2014-02-06
  • Fixed audio
  • Fixed kernel panics/random reboots
  • Fixed camera flash (the torch QS tile still doesn't work, though)
  • Use touch-enabled CWM recovery instead of the previously broken TWRP
  • Enabled Multi-Window (Experimental, the patchset is a WIP)
2014-02-04
  • Initial release
Bekannte Fehler
  • alle CM Bugs
Features
  • Umklappbare Quick-Settings
  • Roadrunner-Modus
  • Multi-Window
  • Daydream-Verbesserungen
  • Integrierte Performance-Steuerung
  • Multi-Workspace
  • Anpassbare Farben
  • Phase Beam mit 3D-Tiefeneffekt
  • Incoming call the non-intrusive way -> Ankommende Anrufe werden am unteren Bildschirmrand angezeigt
  • Quick Launch Shortcuts
  • Screenshots
  • Screen Record
  • Active Display -> App-Benachrichtigungen werden auf dem Sperrbildschirm angezeigt, Zeitintervall 3, 5, 8, 10, 15 oder 25 Sekunden kann eingestellt werden
  • Memory Indicator -> Anzeige über verbrauchten Arbeitsspeicher in der Ansicht von “Zuletzt genutzte Apps”
  • App-Ops -> Datenschutz/Firewall
  • Immersive Mode -> systemweite Vollbildansicht
  • Update-Funktion -> lädt nur die Dateien herunter, die sich verändert haben, dadurch reduziert sich die Größe des Downloads, nur mit integriertem TWRP möglich
  • ListView - Animations hier mal Screenrecordings aufgenommen
  • OmniSwitch - siehe Screenshots
    • Enable/Disable
    • Start on boot
    • Animate overlay
    • Icon size
    • Opacity
    • Show/Hide memory usage
    • Show/Hide app name
    • Action buttons
    • Enable/Disable drag handle
    • Position of drag handle
    • Color of drag handle
    • Opacity of drag handle
    • Auto hide
    • Set favourites
    • Set favourites position
Unoffiziellel Features -> Dies sind Funktionen, die nicht in den offiziellen Omniroms eingebaut werden.
  • Multi-Window (experimental)
  • All-in-one Animation Control: allows you to modify all the system animations & interpolators, from keyboard to listviews to scrolling and more
  • Battery Saver Mode: Allows to turn off various battery-consuming features based on time and other events
  • Driving Mode: makes use of TTS to make the device speak for many useful things when drivingf (see changelogs for more info)
  • Xperia Settings: allows using an ordinary pen as a stylus, using the touchscreen with gloves on, and control vibrator intensity
  • Lockscreen sneak-peek: half-way pressed camera button displays the lockscreen and powers off the display again when released
  • Camera button: unlocks the screen and launches the camera
  • Notification light: allow the notification light to blink even when screen is on
  • Battery Flip-Tile: swipe the battery quick setting tile to reveal temperature, voltage and condition
  • Minimum Vibration Duration: allows to define the minimum amount of time the haptic feedback should vibrate
  • Kernel: built with Linaro gcc 4.7 toolchain, -O2 and many optimization flags
Screenshots
2014-02-09 22.10.58.png 2014-02-09 22.11.07.png 2014-02-09 22.11.24.png 2014-02-09 22.11.32.png 2014-02-09 22.11.51.png 2014-02-09 22.12.09.png 2014-02-09 22.13.10.png 2014-02-09 22.13.18.png
2014-02-09 22.42.57.png 2014-02-09 22.33.58.png 2014-02-09 22.35.28.png 2014-02-09 22.36.43.png 2014-02-09 22.49.59.png 2014-02-15 21.19.49.png 2014-02-15 21.14.45.png 2014-02-16 10.04.30.png
Werde die Omni mal testen.
Danke für die Info
LG Robby
Moin Moin, ich wollte einmal fragen wie die Installation von statten läuft bezüglich unlock/locked Bootloader was wird benötigt? Habe derzeit iHackers 2.1 (locked bootloader aber eben unlockbar) drauf und will nun auf diese Rom wechseln, funktioniert dies ohne weiteres sprich factory reset und dann einfach drauf + gapps?
Vielen Dank im Voraus
iHackers v2.1 hatte ich auch schon drauf, aber ich war bei meinem XZ von Omni begeistert.
  • Alles mit Titanium Backup gesichert
  • die 3 Zip Dateien auf die Karte geschoben (Omni.zip, SuperSu.Zip und die Gapps /Full/Mini/Micro), ich habe die
    • Micro Gapps
    • This package is designed for users of legacy devices with small system partitions or those who prefer a minimalistic approach.
    • In this package you will find the Core Base¹, Google Now Launcher, Google Bookmark Sync, and the following Play Store applications:
    • Gmail | Google Calendar (replaces stock/AOSP Calendar) | Google Play services | Google Search | Google Text-to-Speech
  • im Recovery alles gelöscht (Data/Dalvik/Cache)
Ah okay cool dann werd ich's heute mal draufhauen die iHacker Rom ist auch nicht verkehrt doch nach einer Weile stopft sich das Ding voll und wird lahm und läuft erst nach Reboot wieder rund o.O
Danke erstmal :)
Habe mir mal diese Rom installiert finde sie gut
Kurze Frage hat die Rom auch das privacy guard wenn ja wo find i den menu Punkt
unter Nutzer App-Berechtigungen
Danke
Muss dazu sagen das di Rom sehr geschmeidig leuft
Hätten sie mir ein tip wie man sie optimieren kann
Was willst Du noch optimieren?
Lese Dir mal den Changelog durch was da nach jeden neuen Version optimiert wurde.
Dachte man kann noch was mit den Einstellungen was machen
Was willst Du noch einstellen, es gibt doch viele Möglichkeiten?
OK danke
neuer Kernel
Download
Kernel:
laut Androguide.fr wird Kernel in nächste Build integriert
Kernel läuft jetzt bei mir
neuer Kernel 2014-02-21 Kernel Build
Download
Kernel:
  • Reverted dt2wake & sweep2wake for now
Flash ich den Kernel nach der ROM oder?
Und kann ich die so über meine Stock .290 drüberflashen?
Moin
hab ja root und offenen BL. Deshalb meine Frage ob ich die ROM so jetzt drauf brutzeln kann.
Ja, hast Du CWM oder TWRP drauf, die 3 Zip Dateien auf die Karte. Ich hatte im TWRP noch alles gelöscht, Cache, Data, Dalvik.
Ja hab CWM drauf. Kann ich auch zusätzlich dieses DUAL Dingens ;) mitflashen?
Omni reizt mich schon, benutze es auch auf meinem One. Eine Frage habe ich, funktioniert "Added Sweep2Wake & DoubleTab2Wake"?
Sunny
scherzy32
  • th3chos3n
Aaskereija
Aaskereija
HowToBrickMyPhone
HowToBrickMyPhone
HowToBrickMyPhone
