memphis77
Scheint jetzt langsam los zu gehen mit den alternativ roms.
Habe den Thread mal kopiert und die Installation übersetzt:
[FEB-24][honami][BETA][1.3.0] AOSB Project - The End of The Line !
Introduction About AOSB Project KitKat Edition
AOSB Project based on CyanogenMod the best stable source
AOSB is the new face of ProBAM ROM , We have been blown up ProBAM
Live Chart
Full Album !
The Team
codexc AOSB chief and original founder
Team Members
What the features included?:
AOSB Project Features:
What is Android Open Source Blitz Project?
it is a custom ROM developed as free and open source software based on the official releases of Android by CyanogenMod,
AOSB (ProBAM) ROM have been the pinnacle of perfection employing the best of all the Best ROMs in a Package which makes sense!.. While the latest one doesn’t incorporate a slew of features.
Whats new in CyanogenMod 11
On 6 November 2013 the CyanogenMod team started pushing the code of CyanogenMod 11, based on Android 4.4 KitKat .
Whats new in Android 4.4.x
http://codexc.com/blog/2013/12/whats...4-1-and-4-4-2/
Changelog
Find our latest Full change logs
Find our latest GitHub change logs
Recent Changes in v1.3.0
Code:
Update to Android 4.4.2_r2 (KVT49L) Multi-user support for phones and tablets Sound: Volume panel timeout Sound: Live Volume Steps Sound: Add battery level around unlock ring Sound: add support for translucent volume panel RecentApp: force clear caches on longclick RecentApp: Improve UI Rotation and animation NavBar: Handle navbar heights correct on dpi changes NavBar: Fix landscape mode on tablet flo/grouper NavBar: add landscape height options for tablets Update to SuperSU v1.93 Port: Omni New Battery Saver mode included what user do to saving the battery life SystemUI: time-context headers to the notification header time-context evening time SystemUI: Fix Quick pull SystemUI: Fix notification header disappearing on tablets SystemUI: fix volume panel more button transparency SystemUI: Make text color orange if BatteryMeter <15% SystemUI: improve DessertCaseDream immersive mode exit SystemUI: Fix Screenshot rotation SystemUI: Fix led pulse for samsung devices Fix Xposed Backup Folder Location on dirty flash Expanded Desktop : Fix Left handed navbar during landscape mode LS Notifications: enable pocket mode and show always if activated Browser: Implement client-side incognito mode Settings: Multi-user support toggle in settings -> security Settings: ProgressBar Accelerate and Interpolator Settings: ProgressBar enable MirrorMode and Reversed if activated Settings: ProgressBar Add reset default option Settings: Wakelock Blocker Settings: add CPU info overlay Settings: AOSB Full Simplified Chinese translations Settings: Build.prop Mods: Do some prereq’s before showing options Settings: Automatically switch mobile network into what user choice and also disable mobile data IF wifi connected to an AP Settings: Automatically switch mobile network and disable mobile data IF battery low (battery level can configure) Settings: Support For Both GSM and CDMA devices Screen Recorder: check for supported video encoder resolutions. Screen Recorder: Fix lag ! Add ContentLoadingProgressBar support from AOSP Contacts: Add support for import contacts to local phone storage QS: Fix up Wifi Display tile for screencasting and reenable it Dialer: Fix back (clear) icon colors on dark UI Sensor: Enable the motion accelerometer for screen orientation change Settings: statusbar reflect am/pm and clock color Base: large fixes Zygote descriptor leakage problem Camera2: tweak volume key zoom and cleanup Camera2: Fix Power Shutter Exception Camera2: add option to prevend autofocus cancel if preview stopped Camera2: actually fix ArrayAdapter on MoreSettingsPopup Camera2: AOSB Updated Simplified Chinese translations Mms: Fix timestamps layout_width Mms: Shrink the minimum bubble size Mms: Locate the timestamps outside of bubbles Mms: Remove send message gravity for RtL Mms: Allow text input field to expand up to 9 lines Mms: Fix received thumbnail size Mms: improved mms bubbles TRDS: Dark Mms again OmniSwitch: Update Chinese translations and other Languages by aosb team InCallUI: add decline and answer incoming call action on notifications PhoneWindowManager: add ability to use EdgeGestureService for system gestures. Move lockscreen buttons options to one place Move all battery saver options in one place Add more new APNs Offical support for d2lte unified device Offical support for jflte unified device Offical support for hlte unified device
Installation instructions so If installing for the first time:
To install this ROM you will need to have an unlocked boot loader and a custom Recovery such as TWRP or ClockWorkMod installed
User Friendly Developer
If you like my work please consider a donation!
Powered by
Latest Stable Release
Download now !!
Follow us to keep in touch ::
G+:
https://plus.google.com/+ProBamNet
Facebook:
https://www.facebook.com/AOSB.Project
Twitter:
https://twitter.com/CodeXperts
AOSB on YouTube
Offical website
AOSB Project
Source on github
GitHub
CM Gerrit
Build AOSB from source
source
About the developer
Hany alsamman, an Experienced Web Developer.
Thanks and Credits for :
CyanogenMod Team!!!
All Open Source Projects !
Live Chart
Full Album !
The Team
Team Members
- New Port of MultiWindow and Exclusive Customization and Fixes and Improvement
- 949706abd7c50fbd702a50a8022aec7dd5a740db
- 6334e802e9108fb6faeee1ce879b0d56fb76cb14
- 8dadba3d5a8d0a47fed8a6a39490fdf2896ee0c0
- 3b46e7bf203a59b53364032b1172870952dabb36
- OTA Support
- AOSB Exclusive Feature: Custom SmoothProgressBar
- AOKP Navigation bar menu in settings for all devices now
- AOKP Animation Control
- ListView Animation
- Keyboard Animation
- Scrolling Animation
- AOKP Custom Navigation Ring
- AOKP Custom Navigation Bar
- ChameleonOS Gesture Anywhere
- ChameleonOS Screen Recording
- ChameleonOS Screen Recorder: add ability to record audio from mic
- Omni Batter Saver Mode
- Omni Audio Themes Settings
- OmniSwitch App
- Omni allow disabling call end sound
- Omni Audio : Stereo widening
- Omni Audio : Center frequency for Bass Boost
- AOSPAL LockScreen Notifications
- AOSPAL Lockscreen Blur
- Slim CRT animation: add scale down
- Slim IME options
- Slim DarkUI (system wide in black)
- Add Music Tile
- Flip to Mute/Reject Call
- Advanced BatteryBar
- Chainfire SU App
- User selectable camera click sound (disable camera sound)
- Quicktile row option:set 3,4,5 tiles per row
- LTE toggle support and Configurable up to user (LTE or 4G)
- Add Wifi name to notification drawer and option to enable/disable
- Frameworks: notification drawer background
- wide support for chinese language
- wide support for dutch language
- MediaScanner behavior on boot
- HALO
- HALO MODS
- HALO: make windows move able and scale able
- Mobile Network Battery Saver Mode
- Configurable up to user (LTE or 4G)
- Advanced Battery Bar
- FB sync abbility to connect facebook contacts into contacts app
- App sidebar
- IME switcher notification
- Navigation bar with custom dimensions
- Screen video recording
- Configurable init.d
- Build PropModder
- Incoming calls dialog
- RAM bar with custom colors
- Builtin Xposed Framework
- Xposed : Per-App Layout
- Network usage stats
- ChameleonOS Active display (s-view alternative)
- AD: Display Time out
- AD: Turn Off Display
- AD: Threshold to proximity
- AD: Sort notifications by newest to oldest
- AD: HUGE Fixes
- mms: iOS features
- mms: Emoji and Smiley support
- samsung kernel super charged
- advanced low battery indicator options
- Custom Carrier Label
- NavBar: Left NavBar feature
- NavBar: NavBar landscape height options
Changelog
Code:
- kopiere die rom aufs Handy.
- update recovery, ( nur wenn noch nicht 4.4. drauf)
- Boot ins recovery
- Back up machen
- Enter recovery
- mach einen full wipe "inklusive system und data"
- entfällt
- installiere ROM
- installiere GAPPS (wenn gewünscht) - download link here
- Reboot - der erste reboot kann bis zu zwei minuten dauern
- es wird empfohlen nach dem ersten reboot noch einen durchzuführen
Powered by
Download now !!
G+:
Facebook:
Twitter:
AOSB on YouTube
Offical website
AOSB Project
Source on github
GitHub
CM Gerrit
source
About the developer
CyanogenMod Team!!!
