Hen Ry
Enthusiast
- 1.680
Download [ROM][KitKat][Official][Stable #3][Z] [BeanStalk-4.4.249][19-Dec]
Installation Stock / andere AOSP Roms
Wipe Caches + Data / Factory Reset
Install Rom
Install Gapps
Reboot
XDA
Changelog -> hier alle
Features
alte Builds
BeanStalk-4.4015-20131205
BeanStalk-4.4008-20131129
BeanStalk-4.4001-20131120
Install Rom
Install Gapps
Reboot
XDA
BeanStalk 4.4.200 - 12/19/2013
* Upstream Android 4.4.2
* Fixed variable lock pattern issue. Works as it should now.
* Add lockscreen rotation as an optional rotation setting
* Forward ported power widgets - located in quicksettings and notification drawer menu.
* Ported fixes and additional power widgets
* Option to set active/inactive colors for power widgets
* Option to set headset to launch voice commands
* Allow to disable quicksettings completely
* fix for screenshot animation glitch in portrait
* new busy dlg animation from skyliner
* Quicksettings fliptile when clicking a tile
* AudioEffect: Add a stereo widener effect
* AudioFX: Add center frequency param to bassboost
* update icons and remove cm specific icons.
* allow disabling call end sound
* QS: make dynamic tiles configurable
* Custom lockscreen handle
* Beanstalk shortcut options (this is all slims work, just renamed to beanstalk)
* Custom carrier label
* Added brightness slider (swipe status bar to control brightness when enabled)
* Updated density changer to set density on the fly. No longer requires a reboot!
* Wake on connect/disconnect option
* Numerous fixes and improvements throughout the build
Working
- Boot duh!
- wifi
- bluetooth
- sound
- Almost everything
- you tell me
Not Working
- You Tell Me
Working
- Boot duh!
- wifi
- bluetooth
- sound
- Almost everything
- you tell me
Not Working
- You Tell Me
- CM based
- Insane amount of edits/tweaks/fixes to make this build absolutely fly
- Ultimate battery life through optimizations
- HALO))) 2.0
- Multi Window
- Active Display
- Lockscreen background options (Color fill, Custom image, Transparent)
- Customizable Lockscreen text color
- Lockscreen rotation
- Option to enable all widgets
- Minimize lockscreen challange
- Use widget carousel
- Slider Shortcuts
- Static Lockscreen shortcuts
- Lockscreen button actions
- LCD Density
- Scroll elasticity options
- Default App grip option
- Custom Carrier label
- Dual Pane options
- Customizable boot animation (off, default, set your own bootanimation)
- Custom original BeanStalk Wallpapers by skyliner33v
- Custom BeanStalk bootanimation by skyliner33v
- Status bar color and transparency
- Clock and date options which includes color, location, style
- Signal Styles which include color and text instead of icons, alternate GB signal layout, hide signal icons
- Breathing SMS option
- Battery styles - Includes specific colors and styles. Also includes battery bar
- Do not disturb option
- Show notification count
- Pie controls (need to have lockscreen background set to something other then default to work correctly (dont ask why) )
- Fully customizable navigation bar - Includes style, layout, color, nav rings, pretty much everything you can think of.
- Quick settings color settings, tiles per row, Quick pulldown, text color
- Notification shortcuts, behaviour, drawer style (customizable colors), toggle colors, longpress quicksettings icon to enable/disable toggles
- Keyboard and input method options which include disable full screen keyboard and auto rotate
- Kil app back button with customizable timeout values
- High end graphic effects option
- option to disable/enable vibrate on expand for notifications alerts
- Low battery warning customizable options
- Recents RAM bar fully customizable with color styles
- Clock widget for LockClock including extra options to fully customize every feature of the lockclock
- Build.prop MOD options to enable/disable tweaks as preferred
- Less frequent Notification sounds options
- CRT screen off/on options to specify how the animation shows
- Enable/disable wake up on charge option
- Superuser fully embedded into the build and accessed from settings menu
- CM Performance options and features
- About BeanStalk option with links to github source and facebook for beanstalk. Also links to my twitter and donate.
- option to use a fully themable MMS packages. You can access from mms - settings - theme settings
- Numerous other options hidding throughout the build
alte Builds
![Screenshot_2014-01-20-11-42-49[1].png Screenshot_2014-01-20-11-42-49[1].png](https://www.android-hilfe.de/data/attachments/203/203199-3dd8a03509752237a1b489852e074664.jpg)
![Screenshot_2014-01-20-11-42-55[1].png Screenshot_2014-01-20-11-42-55[1].png](https://www.android-hilfe.de/data/attachments/203/203200-4efb90e21118bff704c44c9b939cae5b.jpg)
![Screenshot_2014-01-22-21-50-18[1].png Screenshot_2014-01-22-21-50-18[1].png](https://www.android-hilfe.de/data/attachments/203/203696-2aded100da778ff01c1bd5948dbd12f5.jpg)
![Screenshot_2014-01-22-21-50-33[1].png Screenshot_2014-01-22-21-50-33[1].png](https://www.android-hilfe.de/data/attachments/203/203697-0ddc0b27e74a63f0fa2bd9508936de8c.jpg)
