Blackjubel
Dauer-User
- 1.134
Beanstalk v7.1.1 UNOFFICIAL Android [7.1.x]
CyanogenMod 14.1 based
PIE
Built in Task Manager switcher
OnTheGo Mode
App Circle bar
System UI Tuner
Quicker system animations
Trimmed down fat and excess bloat
Option to enable all widgets
Numerous extra lockscreen options
LCD Density
Custom original BeanStalk Wallpapers by skyliner33v
Custom BeanStalk bootanimation by skyliner33v
3-minit battery support
Clock and date options
Contextual Header - Original and Polygraphic
Battery styles - Includes specific colors and styles. Also includes battery bar
Do not disturb option
Show notification count
Recent screen options
Customizable navigation bar
Use Omniswitch as default recents
Built-in screen record
Toast animations
App Circle bar
Gesture Anywhere
Disable FC warnings
Disable Immersive message
Force expanded Notifications
Configure scrolling cache
Build.prop MOD options to enable/disable tweaks as preferred
Less frequent Notification sounds options
CRT screen off/on options to specify how the animation shows
Enable/disable wake up on charge option
Superuser fully embedded into the build and accessed from settings menu
CM Performance options and features
Hide superuser icon
Developer options and advanced reboot enabled by default
Numerous cherry-picks and improvements throughout the build.. baked into the
awesomeness of existing CM layout.
Numerous other options hiding throughout the build. For a full list of changes and features, please
be sure to checkout change log below.
* Download ROM und letzte GAPPs.
* Kopiert ROM und GAPPs auf die sdcard.
* Reboot in Recovery(TWRP)
* Full wipe
* Flash ROM und Flash GAPPs.
* Reboot und Genieße BeanStalk .
Download 7.1 ARM GAPPs von HERE - Danke Open Gapps Team.
Download Bank Gapps : HERE Danke DUI Team
ROM DOWNLOAD
" Changelog`s "
BeanStalk source HERE !
Device : HERE
Kernel : HERE
Version Information
Status: beta
Version: 7.1.1
beta Release Date: 2016-10-22
Created 2016-10-22
Last Updated 2016-12-09
