			Blackjubel
Dauer-User
- 1.134
- Themenstarter
- #621
			Blackjubel schrieb:New Build klte.....
Support Fingerprint Hardware
heute noch mal nen update bekommen patch 5
Gerrit Code Review
- Von RR
- Settings :
Frameworks_base :
- Settings: More Lock Screen Weather Color Modifications [2/2]
- Settings: modify Weather icon color settings [2/2]
- Settings: add always quick pulldown option [2/2]
- Settings: Add option to hide lockscreen alarm text [2/2]
- Settings: More Lockscreen Colors [2/2]
- Organize Button options a bit
- Revert "Frameworks: Slim Shortcuts"
- FWB:More Lock Screen Weather Color Modifications [1/2]
- Weather: modify icon color settings [1/2]
- Lockscreen weather Color options [1/2]
- SystemUI: FIX No sim - airplane mode padding
- Increase priority for broadcast intent triggered by HW key
- Rebuild ime list when component enabled is changed.
- Fix dangling ellipsis state
- Do not scan a file which cannot be read
- SharedStorageAgent: Fix onRestore
- Suppress warnings of MultiDexLegacyAndException
- Update trace SQLite operations
- Trace SQLite operations
- Only window position changed, update window crop.
- Handle ActivityNotFoundException for contacts activity
- [ScrollView] Invalid pointerId
- [GridView] Fix the issue that setSelectionFromTop() does not work.
- ExpandableListView: Fix to nofity group collapse event
- Frameworks/base: Fix AdapterViewAnimator.createOrReuseLayoutParams
- [AbsListView] Fix IndexOutOfBoundException issue when handling generi…
- Null Check before accessing to avoid exception when view
- Add MotionEvent flag indicating that the window is obscured
- Sometimes property service is slow to respond.
- AsyncTask: Fix to remove canceled tasks from executor's queue.
- Catch corruptexception during Transaction operation
- [DownloadManager] Enqueue download request might fail and cause NullP…
- dalvik_system_VMDebug.VMDebug_dumpHprofData to dump hprof file, althouth Debug.dumpHprofData defined only throw IOException, but dalvik_system_VMDebug.VMDebug_dumpHprofData will throw NullPointException when file name is null or RuntimeException when no free space, it will caused calling process crash. Root Cause: in ActivityThread.handleDumpHeap, only catch IOException when calling Debug.dumpHprofData(). Solution: 1. if caller is system process, catch RuntimeException to prevent system crash. 2. if caller is non-system process, re-throw RuntimeException back to prcess
- [ActivityManager] handle dumpHeap() but no free space case.
- ChooseTypeAndAccountActivity: Fix the NullPointerException
- Fix to NullPointerException when activity is relaunched
- Frameworks/base: Fix null-pointer access
- Widget: Catch null point exception in AbsListViewAutoScroller
- Fix multi-touch PointerLocation androidui crash issue
- Fix NullPointerException in IntentForwarderActivity#canForward
- ProcessStats: Handle IndexOutOfBoundsException
- base: add always quick pulldown option [1/2]
- Add ANT to the list of toggleable airplane mode radios
- Fix NullPointerException in DhcpPacket.getTransactionId()
- Fix for launching App from Recent Apps on first click
- Release SQLite page cache as much as it can
- Performance Optimization: Align texture dirty rect
- Fix slow wifi connection from QS.
- Add option to hide lockscreen alarm text & cleanup [1/2]
- More Lockscreen Colors [1/2]
- Revert "SystemUI: De-stress status bar #3"
			Blackjubel schrieb:ja hab den vendor vergessen der extra für finger... ist Build gerade neu RR 5.6.4 :blushing:
[doublepost=1456243272,1456240190][/doublepost]So New Build klte RR 5.6.4
Resurrection Remix 5.6.4 Changelog
