Maki.
Ehrenmitglied
- 957
- Built from CM source
- Service
- Text
- Data
- Call
- Audio
- WiFi
- Google Now
- Bluetooth
- GPS
- MMS
- Video playback
- Audio playback
- Internal/External SDcard mounting
- Camera
- Video recording
- IR Blaster
- NFC
- verwendet KEINE Superwipes
- KEIN (!!) dirty flash über CM12!!
- Wipe data, cache, and dalvik cache
** (für ein Update wird nicht unbedingt ein Wipe benötigt) - Flash ROM
- Flash GAPPS (keine aktuellen GAPPs werden unterstützt!)
- Neustart
- Profit
Mar 28
DO NOT dirty flash over CM-12
* initial build of cm-12.1/Android 5.1. THERE WILL BE BUGS so think before you post dumb stuff
* Most features work, SMS will FC unless you go to settings>privacy>blacklist and turn the blacklisting feature completely off. This will be fixed once the source is merged for it.
* Right now its just klte but i will be rolling out the other variants over the next 24 hrs or so so just check check back every few hours for your build.
Mar 29
* android 5.1_r3
* Fixed Contacts app from FCing when selecting a contact (credits: DevorteX)
* Fixed Google Messanger from not working due to missing sql entry (credits: ktoonsez)
Mar 30
* Fixed issue of package installer FCing at the end of manually installing an app
* A decent amount of updates/cleanup/small bug fixes by all the CM devs
* Synced with source as of 5PM PDT
* Updated gapps link to point to my web server instead of dev host
Mar 31
* Blacklisting numbers is fixed
* Fixed picture messages from crashing google messager
* Any upstream changes at time of compile
April 4
* Fixed lag with incoming and outgoing calls.
* Any and all upstream changes at time of compile.
April 6
* Fixed NFC not working in last build
* Fixed recent apps key being active on lock screen
April 9
* fix for google messanger was refined and merged
* Mute and hold buttons now work in dialer
* Home button will not do anything unless the screen is fully awake
April 16
* Fixed MMS sending and receiving issues
* A good amount of stability updates from upstream
* android 5.1 r5
Mar 29
* android 5.1_r3
Mar 30
Mar 31
April 4
April 6
April 9
April 16
* android 5.1 r5
Team Hydra Github (main): https://github.com/Team-Hydra
CyanogenMod Github: https://github.com/CyanogenMod
XDA: [ROM][PREVIEW] CyanogenMod 12.1 | Android 5.… | Samsung Galaxy S 5 | XDA Forums
G900* Unified-GSM : cm-12.1-20150416-UNOFFICIAL-klte.zip | Browse KLTE Build Archive
GAPPS: : gapps-lpmr1-20150324-signed.zip
BUILD SERVER MIRROR : DOWNLOAD MIRROR
An dieser Stelle möchte ich mich bei einen sehr netten und hilfsbereiten
Kollegen wohak bedanken, der mir die Screenshots zur Verfügung
gestellt hat, da ich kein S5 mehr habe.
[FONT="] Ich übernehme keine Haftung für eventuelle Schäden oder Fehler!! [/FONT]
