[ROM][i9505][KK Google Ed. 4.4.2] *5.2.14* BoBCaTROM_GE_v1.0 [eingestellt] ??
  • 47 Antworten
Mack75
Mack75
Stamm-User
644
Ich habe hier mal einen neuen Thread aufgemacht, der Euch die BoBCaT ROM GE Edition vorstellt, damit wir nicht alles durcheinander würfeln. Zur Sammy ROM von BoBCaT gehts hier lang. Die Mods bitte ich hier auch mal ein Auge rein zu werfen und Beiträge entsprechen, konsequent und ohne Kommentar zu verschieben.
ONLINE
05 Feb 2014
[GT-I9505][KitKaT Google Ed. 4.4.2]{~BoBCaTROM_GE_v1.0 ~}
Download:
MEGA
WUALA
ROMCOOK
Features/Changelog:
Based on KOT49H by my friend @friedrich420 (thx
) ==> http://forum.xda-developers.com/show....php?t=2555569
• Root Deodexed Zipalign busybox
• Stock Kernel
• Modded settings with link to BoBCaTROM Control application, it include many options:
- Battery Bar
- icon battery is removed if you want to restore or activate the percentage use Gravitybox
- Busybox Manager
- Viper4AndroidFX
- ES File Explorer
- Adaway
- Boot Manager
- Fast Dormancy
- Led Manager
- GPS Fix
- Intelli3G
- Cpu monitor
- Cpu spy
- LogCat
- MD5 Checker
- OTA Update Home with link to WUALA folder for Updates, Extra, Themes (work in progress), link to XDA thread and donation button
- OTA Update Pro, automatic alerts of new release with possibility to download it directly
- Xposed installer + modules
- Xposed per app density (set many options for each app included dpi density)
- Greenify
- You Tube AdAway
- Reboot menu 5way (systemui, normal, soft, recovery, bootloader)
* Gravity Box(Credits @C3C076 and his great application http://forum.xda-developers.com/show....php?t=2554049 )
• Features list:
- CyanogenMod Pie controls
- Expanded Desktop
- Statusbar QuickSettings tile management with tile reordering
- Lockscreen targets
- Statusbar icon coloring
- Statusbar Brightness Control
- Statusbar icon colors
- Additional QuickSettings tiles:
- Sync on/off, WiFi AP on/off, GravityBox shortcut, Torch, Network mode (2G/3G/2G+3G switch), Sleep, QuickRecord,
QuickApp, GPS on/off, Ringer mode, Volume tile, Camera tile, ...
- Quick pulldown - switches to QuickSettings when status bar is pulled down near edges
- Auto-switch to QuickSettings when there are no notifications
- Center clock in statusbar
- Battery indicator style
- Navigation bar tweaks including cursor control keys
- Low battery warning policy
- Disable LED flashing when battery low
- Disable LED while charging
- Advanced power-off menu (reboot, recovery)
- Volume key cursor control
- Skip tracks by volume key long-press while screen off (thanks to rovo89)
- More volume levels for music stream
- Option to control safe headset media volume
- Button for clearing all recent tasks at once
- CRT screen off animation
- Minimal brightness setting
- Autobrightness levels adjustment
- Lockscreen tweaks - show widgets maximized, lockscreen background style (color fill, custom image)
- Lockscreen rotation
- Hardware key actions - menu long-press/double-tap, back long-press, home long-press
- Dithered Holo background
- Option to use solid black Holo background
- Expandable volume panel
- Option to unlink ringtone and notifications volumes
- Notification drawer style (background color, image for portait/landscape, transparency)
- Button backlight modes (default, disabled, always on while screen is on)
- Dialer (Phone) tweaks
- Launcher tweaks
- Screen recording
... more to come
Installation:
- Euer Gerät rooten und ein Custom ROM installieren...
- MACHT EIN EFS Backup!!!
- ladet Euch die ROM runter und prüft die checksum (MD5)
- Startet Euer S4 im Recovery Modus
- Installier die BoBCaTROM mit Full Wipe
- Startet Euer S4 neu
- Installiert Xposed framework und active modules (zu finden unter ==> BoBCaTROM Control )
- Erweiterte Einstellungen wählt Ihr unter GravityBox
- Nochmal Neustart
- FERTIG
Hinweis:
Wie immer gilt, Ihr flasht auf eigene Gefahr, das aufmerksame Lesen dieses und ggf. auch des XDA-Threads gehört dazu. Weder ich, noch AH, noch Apachi/BoBCaT oder sonstige an der ROM mitwirkende übernehmen eine Garantie dafür, dass alles funktioniert.
Nun aber: VIEL SPAß mit der ROM
Reaktionen: BBF-Android, acer2526, stimpy und 8 andere
Reserve 01
Reserve 01
Reserve 01
Der Thread ist doch schon verschoben ;)
Reaktionen: Mack75 und Yoggie
@Mack75
Bitte Links bzw. Verweise auf Links checken... Zur Sammy ROM von BoBCaT gehts hier lang. Da fehlt der Link.
Vielleicht auch entsprechend verlinken.
Reaktionen: Mack75
Rom ist Hammer nur ein paar Kleinigkeiten die mich stören blaue Uhr der man nicht die Farbe ändern kann sowie kleine farbliche Änderungen die ich mir wünschen würde sonst top Arbeit
Noch was wäre schön wenn man Anrufe mit geschlossenen sview cover annehmen könnte..
Reaktionen: Mack75
@ Cuxi: da war das falsche "hier" verlinkt, sind ja mehrere im Text, korrigiert. Was den anderen angeblangt, so ist das nach meinem Verständnis kein Link auf eine App, sondern eine Verknüpfung von Einstellungen und der in der ROM vorhandenen Control-App.
LG und Danke
Milchbeck, mit gravity Alles möglich
... für was brauchts denn 3 reserve Postings??? :rolleyes:
wer weiß schon, was kommen wird. Schau, jetzt sind wir schon auf Seite 2 und ab Seite 10 liest eh keiner mehr aus Seite 1 mit. und nun
Danke
Hi zusammen.
Kann jemand schon was zur Akkuleistung sagen? Mich juckt es in den Fingern zu flashen da man hier keinen Bootloader etc flashen muss.
Wie siehts eigentlich mit dem Modem aus kann man weiterhin einfach z.B das XXUEML9 drauf lassen?
VG OC
Ja schon aber schau dir dann mal die Icons in der statusbar an z. B. Lautlos ect...
Ja das stimmt, ist mir auch aufgefallen.
Und das ist das was mir dann wiederum nicht so gefällt.. Schade dass man nicht die normalen icons aktiveren kann dann wäre es kein Problem gewesen...
Und sview funktioniert nur beschränkt, also keine anrufabnahme möglich..
Kurz ot ist hier jemand der mir hilft die chrome Statusbar Icons für signal in andere aosp Roms zu bringen!? Wer kennt sich mit cm themes aus?
Frag do bei Pas2001 nach, immerhin meinst du wohl seine Arbeit
Ja aber der macht Sammy!
Was mir fehlt ist das ich apps auf die sdkarte verschieben kann. :mad:
