[ROM][I9505][5.x.x] *27.02.15* Kangapop V2.5
  • 42 Antworten
Also, hier seh ich das es weiter geht.
★KANGAPOP v2.2★
KANGAPOP CHANGELOGS
- 2-13-15
- 2.2
- FIXED LONG PRESS 1 FOR VOICE MAIL
- CLEANED UP AROMA
- ADDED SMS WITH QUICK REPLY & MANY SMS OPTIONS
- ADDED OPTION FOR APP OPS
- ADDED OPTION FOR GLOVE MODE
- ADDED Chronus WEATHER WIDGET (USER REMOVABLE)
- FIXED AROMA ISSUE WHEN CHOOSING NOVA,APEX LAUNCHER
- SOME CLEAN UP
- MISC IMPROVEMENTS
- CLEAN INSTALL ONLY! <- HIGHLY RECOMMENDED
- IF YOU DIRTY FLASH AND HAVE ISSUES CLEAN INSTALL B4 YOU POST!
NEW AROMA OPTION ADDED!
- CHOOSE GLOVE MODE OR DISABLE
- CHOOSE APP OPS OR DISABLE
CHANGELOGS
- 2-19-15
- KP KERNEL TOOL ADDED
- 2-18-15
- 2.4
- UPDATED GOOGY-MAX3 KERNEL TO 1.2.9
- ADDED REBOOT OPTION TO POWERMENU
- ADDED REBOOT TO RECOVERY OPTION TO POWER MENU
- ADDED AUTOSTART CONTROL TO SETTINGS MENU
- CONTROL WHICH PLAYSTORE APPS RUN AT BOOT
- REMOVED EXTENDED REBOOT APP NO LONGER NEEDED
- LOLLiPOP MEMORY LEAK FIX UPDATED
- SCREENSHOTS ADDED! SEE POST #2
- SOME OLDER SCREENSHOTS REDONE
- CLEAN INSTALL ONLY FOR THIS UPDATE!
Kangapop V.2.4
Fifaheld
postmaster
der_Kief
COB93
COB93
Fifaheld
Darks
Darks
