Cpt
Dauer-User
- 1.252
Mit picture2SD zu finden im Xposed Menü
test this guys
brightnesstest.zip | brightnesstest.zip | by danvdh for Galaxy S4
New
<integer-array name="config_autoBrightnessLevels">
<item>40</item> (lux)
<item>200</item>
<item>450</item>
<item>1400</item>
<item>2000</item>
</integer-array>
<integer-array name="config_autoBrightnessLcdBacklightValues">
<item>20</item> (Brightness value 1-255)
<item>40</item>
<item>60</item>
<item>100</item>
<item>255</item>
<item>255</item>
compare to the the right array on this page
as you can see, I just bumped the first value by 5, and the third by 15, all others others by 10 except for the max of course. seems to look good now, btw that extra value is always needed, so no questioning me on that![]()
-Lockscreen unlock ring in now centered (Great one Samsung/Google!) This is now fixed for you guys, the problem was in keyguard.apk and I fixed the derp they shipped.
-Updated google play services
-Enabled touchkey light control for ART users, simply type SU in terminal and then type touchkeys
-Updated google search (Pure Nexus build only)
-Reverted themed email in favor of stock email (Pure Nexus build only)
-Uploaded 2 extra builds compiled with another kernel for you guys with "battery issues" to try out, not all hardware is made equal and some might have a better experience, all I know is on stock kernel from google the ROM is running perfectly.
-Updated build.prop
*Do not turn my thread into a kernel thread, this is a ROM development thread and I'm 100% certain I've done all I can on the ROM side of things, it's very stable and most battery issues are your issue or your phone not agreeing with a certain kernel setup, it's all about finding the balance that works for you
budy schrieb:Nee kann ich nicht sagen, ich nutze nur einen älteren Kernel die Builds nach dem 9.06 haben bei mir immer "msm_hsic_host" wakelooks.
beicuxhaven schrieb:Zumindest sollte man per Hand FORMAT SYSTEM / Wipe DALVIK / WIPE CACHE machen....
unsuwe schrieb:Hallo,
Format System? Wird hier nicht alles auf der internen SD gelöscht?
Gruß Uwe
