[ROM][i9505][4.4.4] *30.10.14* Mahdi-Rom [FINAL]
  • 158 Antworten
Janeo
Janeo
ICH ÜBERNEHME KEINE VERANTWORTUNG FÜR DIE RICHTIGKEIT DIESER ANGABEN - FLASHEN/INSTALLATION AUF EIGENE GEFAHR, DIE GARANTIE DEINES HANDYS ERLISCHT
XDA-Thread
ROM Features
Sound
-DSP Manager
-Ascending ringtone
-Quiet hours
-Less frequent notification sounds
-Control volume adjust sound
-Launch music app on headset connect
-Control safe headset volume
-Power connect notification control
-Apollo as Default Music App
Display
-Advanced auto brightness control
-Full rotation control including lockscreen
-Screen record with audio
-CRT options
-Notification LED Control
-Battery LED Control
-Wake up device on plugin/unplug
Security
-Variable size pattern unlock
-Lockscreen Vibrate
-Slide Lock Delay
-Home Unlock
-Toggle dots/error pattern visibility
-Pin keypad shuffler
-Lock before unlock
-Privacy guard
-Blacklist
Languages & input
-Auto keyboard rotation
-Disable fullscreen keyboard
-Selector notification
-Volume key cursor control
Developer options
-Advanced reboot
-ADB over network
-Development shortcut in recent apps list
-Show cpu info
-Change device hostname
Customization menu
Theme chooser
-CM's theme chooser
Status bar settings
-Clock and date customisation
-Battery customisation
-Network speed indicator
-Statusbar brightness control
-Double tap statusbar to sleep
Quick settings
-Full quick settings control
-Color settings
Notification panel
-Shortcuts
-CM's ribbons
-Hide carrier label
-Notification background
-Notification transparency
Recents panel
-Clear all button options
-Circular memory indicator
Buttons control
-Navbar & navring settings
-Power menu settings
-Lock screen settings
-Volume rocker wake
-Volume music control
-Volume adjust preference
Power menu
-Profile switcher
-Immersive mode
-Screenshot
-Screen record
Lock screen
-Active display
-Targets customisation
-Battery level on lock ring
-Maximize widgets option
App sidebar
Halo
The kernel included is stock CM enhanced with:
-Linux v3.4.74
-Sound control (thanks to faux123)
-Voltage control (thanks to faux123)
-Sysfs interface to Enable / Disable Android Logger
-Fast charge
Kernel Features
-Linux v3.4.86
-In kernel mpdecision by showp1984
-In kernel thermal by showp1984
-Tuned ondemand governor
-Intelliactive governor (thanks to faux123)
-Fast charge
-many more patches are included to help save battery and boost performance
Kernel Kontroll-App:
Kcontrol (Play Store)
oder
Trickstermod (Play Store) (nicht alle Funktionen werden unterstützt)
Kernel source: here: GITHUB
Installation
0. Du hast die EFS-Partition gesichert? Dein Handy ist gerootet und ein Recovery ist installiert?
1. Lade die aktuelle Version und gegebenenfalls die aktuellen GApps (Link siehe unten)
2. Du brauchst ein Recovery (meine Empfehlung: CWM neuste Version! PhilZ und TWRP möglicherweise nicht kompatibel!)
3. Mache ein NANDROID-Backup deines ROMS!!!!! (TU ES! UNVERZICHTBAR!)
4.a Neuinstallation: kommend von einem anderen ROM -> Fullwipe Fullwipe:
wipe cache, factory reset
unter: "Mounts&Storage" -> format system
unter: "advanced" -> wipe dalvik cache,
(Bis auf die interne-SD und ext. SD-Karte sind alle deine Daten verloren)
4.b UPDATE: von Mahdi-Rom auf Mahdi-Rom
Wipe cache
(App-Daten bleiben erhalten, interne SD- und ext. SD-Karte bleiben erhalten)
5. Flashe Mahdi-Rom
6. Optional: Flashe Google-Apps
Aktuelle Version
Aktuelle GApps
Changelog
Der ursprüngliche Beitrag von 18:24 Uhr wurde um 18:32 Uhr ergänzt:
Rom läuft bei mir seit 2 Tagen.
-schnell wie CM11
-keine Abstürze. keine FC
-sehr viele customization options
-läuft 1a mit KT-Kernel
-Akkulaufzeit (Rom installiert, Apps installiert, Backup, neustarts, testen) 3h 45m Display on time und noch 20% Akku
wird mein neues Daily-Rom
Experimental Kernel habe ich noch nicht ausprobiert
ich benutze die Banks GApps
Reaktionen: Klausel, Steveria, sventehf und 6 andere
Klingt sehr interessant. Download läuft. :D
Die hatte ich auch schon im Auge, wollte aber noch bis nächste Woche warten ;)
New build is up
frameworks/base
-Limit QC camera features to post-ICS HALs
-WifiController: fix high perf lock sometimes not respected
-AppOps: track op persistence by name instead of id
-Revert "Frameworks: Forward Port Circle Battery and Landscape Battery
-Revert "QS: Make it possible to show smaller icons (1/2)
-Quicksettings: add option to choose number of tiles per row (1/2)
packages/apps/Settings
-Always show band 0
-Improve app op details layout
-Revert "Settings: Forward Port Circle Battery and Landscape Battery
-Revert "QS: Make it possible to show smaller icons (2/2
-fix Customization settings fc when layout is set to dual pane
-Quicksettings: add option to choose number of tiles per row (2/2)
-fix Home settings fc when layout is set to dual pane
packages/apps/Camera2
-fix long press shutter behavior
-Round camera settings icon margins to 8
-Set the width dynamic to parent from fixed 400px
-Set original camera parameters while switching between modules
-Enable module switcher on resume
-Fix for unsupported resolutions by codec
packages/services/Telephony
-Add option for setting device phone number
dalvik
-DMB Optimisation
-DMB Optimisations for TracingJIT
The main changelog is in the OP, thanks.
Reaktionen: tobiasth und Marzl85
Schöne Rom, ohne Frage, aber der Akku hält mir zu kurz, im Gegensatz zur SlimKat, werde wohl wieder wechseln. :D
Welcher Kernel? Stock oder den Kernel vom Entwickler der Rom?
Der der dabei war.
Ich werde doch nochmal den experimentellen probieren. :)
Gibt übrigens ein Update. ;)
Im Update ist nur ein Kamera fix.
Habe die Rom nun 24h laufen. Muß sagen läuft richtig smooth.... :thumbup:
Gesendet von meinem GT-I9505 mit der Android-Hilfe.de App
New build is up,
device/samsung/jf-common
-Fixup audio policy
-bring back support for samsung HDR
frameworks/base
-ActiveDisplay check for Immersive Mode Enable
-Active display: Respect Quiet Hours
-Quicksettings: Immersive mode tile add improved drawables
-Add time-context headers to the notification header (1/2)
-Fix notification header disappearing on tablets
-Cleanup and enhance notification drawer header
-Re-add auto brightness configuration UI (1/2)
-Add method to PowerManager that allows querying the lowest possible
-privacyguard: Share privacy package name between activity stacks
-Fixed missing shading of statusbar circle battery and network traffic
-Recents circle memory indicator fixes
-GlobalActions.java: fix soft reboot
-roll back all bluetooth changes
-Quicksettings: LocationTile tile improvements by Slim
-Revert "Keyguard: do not show maximized on simpin and several fixes"
-Storage Settings: Allow user to trigger a volume rescan
-Add a custom notification panel header (2/2)
-Fix led pulsespeedoff disable behaviour
-Roll back all bluetooth changes
-Fix exception in BatterySipper.getQuickNameIconForUid
-Recover last location state during on/off switch
-Quicksettings: change reference from GPS to Location
-bring back support for Samsung HDR format
packages/apps/LockClock
-Merged with CM
These projects have been restored to a near aosp state because my nexus were being affected in a negative way, if you have any problems with bluetooth let me know.
external/bluetooth/bluedroid
packages/apps/Bluetooth
CPU auf 1700 mhz
Helligkeit Auto
Kt-Kernel
Durchgehend WLAN an
Ich bin zufrieden :)
hei
Habe ich das richtig verstanden das der Stock Aokp Kernel mit Tool zum einstellen in der Rom ist?
MFG
Stock Kernel, aber in modifizierter Form ....
Mahdi786 schrieb:
Experimental kernel
I named this kernel experimental because it is not stock, this is actually a very stable kernel I use it as my daily driver and I feel that it's much smoother stock, it includes:
-Linux v3.4.74
-Fast charge
also die Rom läuft 1 A mit dem experimental Kernel !
Ich werde heute oder morgen mal flashen und ein paar Tage testen.
Sieht ja schon mal ganz nice aus. ;)
Ist sie auch klar ne Umstellung zu TW Rom is da ;)
Wer weis wie lange ich das S4 noch besitze... Testen werde ich aber
WLAN gegenüber den Sammy ROMs sehr schlecht vom Empfangswert. Komisch.
Versuch mal den kt Kernel der lief bei mir besser mit WLAN
Reaktionen: beicuxhaven
