[ROM][i9505][4.4.4] *30.10.14* Mahdi-Rom [FINAL]
  • 158 Antworten
Unglaublich was für Kleinigkeiten etwas ausmachen können.
Du kannst ja trotzdem noch den kt-Kernel versuchen, da lässt sich bestimmt nochmal einiges rausholen.
Update ist raus.
21.06.2014
-Merged Android 4.4.4 (Security update)
-Theme chooser: upstream fixes/updates from CM
-Added Lockscreen blur
-Quicksettings: added option to show smaller tiles (removed old options for 4/5 tiles)
-Added options for notification-shade-collapse-after-dismiss behaviour
-Added "Turn WiFi off" action to "Open networks" notification
-Hover: options to exclude non-clearable, low priority and topmost app
-Fixed VPN
-Fixed SystemUI battery drain
-Tanslation updates thanks to @c@p, @seilogeo, @toyr99, @Pixelase and @senses!
-Read the detailed changelog for more info
*BUG: On first boot the wallpaper will be black on the lockscreen, after that everything will be normal.
Reaktionen: Janeo
Quote Mahdi786 from xda:
http://forum.xda-developers.com/showpost.php?p=53802232&postcount=1528
New build is up
mahdi-2.7-jflte-20140630.zip | mahdi-2.7-jflte-20140630.zip | by mahdi.rom@gmail.com for Galaxy S4
-Added HeadsUp with blacklist, do not disturb and qs tile
-Hover updates from AOSPA, also added an option to hide from lock screen
-Slim recents: option to show topmost task and other fixes from Slim
-Lots of other framework fixes (read the detailed changelog)
-Updated boot animation thanks to @blazze11
-Settings: fixed battery stats app list
-Settings: Use a seekbar preference to allow setting arbitrary animation scale values
-Launch SuperSU from Settings and hide SuperUser if SupenSU is installed
-Trebuchet: fixed GEL integration
-Mms: Use the nice colorful LetterTileDefaultImages
-Incallui: make navigation bar translucent
-All CM apps merged
-Added option to turn torch off when screen turns off
-Camera: added Transparent Popups menus thanks to @rush25
-Tanslation updates thanks to @c@p, @seilogeo, @toyr99 and @Pixelase
Jflte
-Kernel updated to Linux 3.4.95
-Add hardware tunables (AdaptiveBacklight support, high touch sensitivity)
*Note high touch sensitivity isn't working because I missed one commit in hardware so the option in display settings wont have any effect
**If you find a bug please capture a bug report and pm it to me
Reaktionen: Janeo
Neues Update ist raus.
09.07.2014
*HeadsUp improvments from Slim thanks to @kufikugel
-floating mode
-timeout
-always expanded
-show pending updates as headsup
-snooze function
-option to show headsup call notification
*Quick settings
-heads up tile: add long press to go to heads up settings
-battery saver tile: add long click to go to battery saver settings
-settings tile long press will take you to Customization settings
-Fixed black wallpaper on boot
-Added CM's performance settings
-Removed KernelTweaker and OmniSwitch apps (you can install these manually)
-Added lock screen blur radius option
-Trebuchet: merged with CM
-Searchable settings like in Android L thanks to CM
-Animation scale: fix slider preference min/max
-Fixed ota app links
-Various fixes in Browser, Mms, Dialer and ThemeChooser
-There have been lot more fixes so take some time to read the detailed changelog
-Hammerhead kernel: added multiboot support
**BUG: Setting a custom image on navigation bar back key doesnt stick, for now don't use this option until its fixed
Reaktionen: Janeo
-Updated to 4.4.4_r2
-HeadsUp fixes from Slim and CM
-Privacy Guard notification options
-Added an option to disable hardware navigation buttons
-Settings restructure: distributed features to appropriate places, no more cutomization screen
-Settings: fix force close in security settings when lock screen security is set to none
-Settings: Fine LongPress and hold delay
-Added gesture settings for 1+1
-Trebuchet: merged with CM and added CMHome app for use with Trebuchet (it displays extensions and supports Dash Clock)
Reaktionen: Klausel
Final Build erschienen. Mahdi hat die Entwicklung für das S4 eingestellt, weil er sein S4 verkauft hat. Hier also das vorerst letzte Mahdi-Rom für das S4 (es sei denn im xda-Thread erklärt sich jemand dazu bereit Mahdi weiter zu entwickeln).
mahdi-2.7-jflte-20140727.zip | mahdi-2.7-jflte-20140727.zip | by mahdi.rom@gmail.com for Galaxy S4
-Theme chooser fixes from cm
-Option to show headsup at the bottom thanks to @kufikugel
-Added Smart cover support thanks to @Evisceration
-Add support for checking proximity when waking device
-Fix from cm for offmode charging for devices on kitkat bootloader
Reaktionen: Klausel
Startpost nochmal aktualisiert.
Ist es ok, wenn ich dem Thread-Titel ein
[Entwicklung eingestellt]
voran setze?
Sehr tragisch. Nun weiß ich nicht welches ROM ich in Zukunft nutze.
Wohin wechselt ihr?
Ich bleib erst mal auf der... Sollte es dann mal mit Android L soweit sein, gehe ich vermutlich zurück zur Carbon Rom
Finde es aber auch sehr schade das er aufgehört hat :-(
Reaktionen: Janeo
Ja ist wirklich schade, werde die ROM aber weiterhin nutzen.
Reaktionen: Janeo
Ich bleibe erstmal auch bei mahdi auf dem s4. Habe gestern mal den tag verbracht um mal bisl andere roms zu testen. Aber egal welche ich getestet habe cm11 oder TW roms, keine kommt an mahdi ran. TW alleine schon wegen der schlechteren Performance so finde ich. andere cm11 roms sind halt nicht gut auf deutsch übersetzt. Carbon rom ist gut aber nicht ganz auf deutsch.
Bei mahdi gehe ich zurück auf Version 2.5 vom 01.06.2014. Gefällt mir am besten.
Ich hatte überlegt mahdi mit seinen neuen handy zu folgen. Dieses lasse ich aber jetzt sein da sein neues phone ein oneplus one ist. Dies ist mir persönlich zu groß. Das s4 ist schon Grenzwertig. Für die zukunft gucke mich mich mal nach einem kleineren handy um wenn ich mein s4 irgendwann mal abgeben sollte.
Reaktionen: Janeo
Na das ist mal eine Überraschung!
Mahdi hat Zeit gefunden eine neue Version zu erstellen!
Surprise!! New build is up. I had some time yesterday to merge cm's latest changes to device trees, vendor blobs and kernel (major changes), if you guys are keeping up with cm nightlys you will know already that cm has re-based the kernel on caf, update vendor blobs including gpu drivers and major changes in the device trees. I had some time yesterday night to merge these changes and make build for you guys since others are struggling. I haven't tested it but there's nothing experimental in there.
https://www.androidfilehost.com/?fid=23622183712464014
-Major kernel, device tree and blob updates
-Theme chooser updates from cm
-Apn updates
-Removed lock screen custom color options
-TrafficMeter: fix monitor visibility when wifi or mobile data is disabled
-Smal fix in Mms for theming background
-Blacklist: fix not being able to add wildcards and short numbers
-Big French and Japanese translation update thanks to @The Tox and others
You guys have missed a few builds so refer to this simple changelog to catch up http://files.mahdi-rom.com//ota/changelogsimple.txt
Thanks.
Und gleich noch ein Update hinterher!
New build is up,
https://www.androidfilehost.com/?fid=23622183712464606
-Enable pulsing LED on boot
-Small fixes in external/bluetooth, hardware/audio, frameworks/av and system/core
-Translation merges from CM
Check the OP for the detailed changelog.
Reaktionen: tobiasth
Schon wieder ein Update!
Ich hab das "Entwicklung eingestellt" mal aus dem Thread-Titel entfernt. Für eine eingestellte Entwicklung kommen überraschend häufig Updates :)
New build is up,
https://www.androidfilehost.com/?fid=23622183712466402
-AppOps: fix checking user permissions before enabling/disabling wifi
-Add persistent notification when USB OTG is connected
-Fix slim recent panel defaulting to white on clean flash
-Add reverse lookup provider "Das Telefonbuch" (DE)
-Setup wizard cleaned up, much cleaner experience
-Fixed a bug in quiethours qs tile which caused high battery drain
-APN updates
*Frameworks and settings clean up
-spent some time looking through these projects and cleaned up things
in services, keyguard, systemui and settings
*Lockscreen notifications improvements and fixes
add option to:
-enable/disable if notification is actually dismissed
-force enable low priority notifications
-fixed nullpointers
*Blacklist
fixed:
-not being able to add short numbers
-force close when blacklist button was pressed in in-call ui
*Enabled some options by default on a clean flash and fixed some options which shouldnt have been enabled
default:
-circle battery
-double tap status bar to sleep
-notification count
-quicksettings quick pulldown to the right
diabled:
-screen on led
-flip tiles and vibrate tiles
-recents clear all
-navbar ime cursor
*Removed options:
-custom lockscreen color options
-quiethours auto sms, call bypass
-battery saver led and vibrate option
-Tanslation updates thanks to CM, @seilogeo, @toyr99, @Pixelase, @The Tox, @michaelz93,
@Alberto97 and @jbnitro
-Big Japanese translation update (not sure if your a user on xda but good work)
Enjoy.
Neues update ist raus.
Cm10,cm11 Bugs sind vorhanden. (Bluetooth Probleme...)
Bei mir läuft es rund.
Mahdi786 schrieb:
New is up build, check the changelogs here to see whats changed since 09/03 to 10/01 http://files.mahdi-rom.com//ota/changelogsimple.txt
I don't know what works and what doesn't because I don't own the device any more.
https://www.androidfilehost.com/?fid=95747613655043823
From 10/01 to now
-Theme chooser: Let ThemeService handle all theme processing
-Immersive mode: options to disable navbar or statusbar gesture
-WiFi: show devices behind a firewall that are connected to the WiFi hotspot
-Fixed keyboard emoticons issue
-APNs updates
-Other stuff, read the detailed changelog
-Tanslation updates thanks to [MENTION=4487065]stmay30[/MENTION], [MENTION=5574921]blazze11[/MENTION], @bankai03, [MENTION=5307616]michaelz93[/MENTION] and [MENTION=2596617]senses![/MENTION]
JFLTE
-All device trees, hardware-caf projects up to date with CM
-Major work has been done to GPS
-Kernel updates
Reaktionen: Janeo
Da ich schon mehrere Anfragen hatte wegen früherer Versionen der Mahdi Rom, stelle ich hier noch mal eine Version vom 1.6.2014 rein. Das ist eine Version wo noch alles geht. Problemlose Rom. Viel Spaß damit. Habe mein S4 schon lange nicht mehr (gegen Iphone getauscht) aber bin Android noch gerne verbunden.
https://www.dropbox.com/s/5k016xbxf5kcz2h/mahdi-2.5-jflte-20140601.zip?dl=0
Reaktionen: Janeo
Leider gibt es Probleme mit manchen exposed Modulen.
War bei früheren Versionen nicht.
Und die Funktion die anrufen de Nummer mit Telefonbuch. De u ermitteln klappt leider nicht
Hallo kloppi123
Vielen Dank für das Hochladen der Mahdi Rom vom 01.06.2014 :thumbsup:
Gruss Trispel
habe auch noch beim ausmisten meines PC´s eine Mahdi Version vom 26.05.14 gefunden. Braucht das jemand?
Fifaheld
postmaster
Fifaheld
Darks
Darks
Fifaheld
Fifaheld
Fifaheld
