[ROM][I9505][4.4.4] *29.12.14* Slim Kat 9 [FINAL]
  • 2.353 Antworten
7.6 und so ...
Changelog (extra für Rosa Elefant)
2014-08-25 | Settings: Spanish strings for volume panel color [Carlos Solano]
2014-08-25 | Reset the audio stream volume to fix low in-call volume bug [h3llrais3r]
2014-08-25 | f2fs: use radix_tree for ino management [Jaegeuk Kim]
2014-08-25 | f2fs: test before set/clear bits [Jaegeuk Kim]
2014-08-25 | f2fs: skip unnecessary data writes during fsync [Jaegeuk Kim]
2014-08-25 | f2fs: remove redundant lines in allocate_data_block [Dongho Sim]
2014-08-25 | f2fs: reduce searching region of segmap when free section [Chao Yu]
2014-08-25 | f2fs: reduce competition among node page writes [Chao Yu]
2014-08-25 | f2fs: punch the core function for inode management [Jaegeuk Kim]
2014-08-25 | f2fs: invalidate xattr node page when evict inode [Chao Yu]
2014-08-25 | f2fs: fix wrong condition for unlikely [Jaegeuk Kim]
2014-08-25 | f2fs: fix to put root inode in error path of fill_super [Chao Yu]
2014-08-25 | f2fs: fix coding style [Jaegeuk Kim]
2014-08-25 | f2fs: enable in-place-update for fdatasync [Jaegeuk Kim]
2014-08-25 | f2fs: avoid skipping recover_inline_xattr after recover_inline_data [Chao Yu]
2014-08-25 | f2fs: add tracepoint for f2fs_issue_flush [Jaegeuk Kim]
2014-08-25 | f2fs: add tracepoint for f2fs_direct_IO [Chao Yu]
2014-08-25 | f2fs: add nobarrier mount option [Jaegeuk Kim]
2014-08-25 | f2fs: add infra for ino management [Jaegeuk Kim]
2014-08-25 | f2fs: add info of appended or updated data writes [Jaegeuk Kim]
2014-08-25 | f2fs: add f2fs_balance_fs for expand_inode_data [Chao Yu]
2014-08-25 | f2fs: add f2fs_balance_fs for direct IO [Huang Ying]
2014-08-25 | APN type fix for Telenor Serbia [Goran Rakic]
2014-08-25 | apns-conf.xml: update verizon apns [invisiblek]
2014-08-25 | apns-conf: Fix Elisa EE MMS port. [Rudolf Tammekivi]
2014-08-25 | Add TIGO and VOX for Paraguay [Brinly Taylor]
2014-08-25 | Added APN for Tal Iceland, ref CYAN-5026. Note that I am not on that network myself so I have not been able to verify the settings. However, they are taken from the official support site. [Zyg0te]
2014-08-25 | Add APN for Telenet when internationally roaming (MNC=206 MCC=01) [neatchee]
2014-08-24 | Settings: Volume panel background color && transparency [1/2] [dankoman]
2014-08-24 | Changed the configuration to address overload scenarios of the End Users. [Perseus71]
2014-08-23 | Squisher: fix description for device specific LCD Density fix part [andi34]
2014-08-23 | Settings: updated it translation [ezio84-xda]
2014-08-22 | Telephony: PL Translations [yaatzek]2014-08-25 | Bump for 7.6 weekly (HEAD, m/kk4.4-caf, github/kk4.4) [Josue Rivera]
2014-08-22 | Settings: PL Translations, fixes and improvements. [yaatzek]
2014-08-22 | Dialer: PL Translations [yaatzek]2014-08-22 | InCallUI PL Translations (HEAD, m/kk4.4-caf, github/kk4.4) [yaatzek]2014-08-20 | MMS: PL Translations (HEAD, m/kk4.4-caf, github/kk4.4) [yaatzek]2014-08-23 | Automatic translation import (HEAD, m/kk4.4-caf, github/cm-11.0) [Michael Bestas]2014-08-25 | Settings: translation - RU [gwindlord]
2014-08-22 | Core PL Translations [yaatzek]
2014-08-21 | stagefright: Set bit_width if ENABLE_AV_ENHANCEMENTS is defined [hany]
2014-08-21 | Revert "audio:Avoid AudioTrackThread if Track creation fails" [Steve Kondik]
2014-08-21 | overlay: Allocate from MM heap as a fallback [Steve Kondik]
2014-08-21 | mm-video: Use multimedia heap on MSM7x30 (720p) too. [Rudolf Tammekivi]
2014-08-21 | media-caf: Fix building for msm7x27a [RonGokhale]2014-08-25 | f2fs: use for_each_set_bit to simplify the code (HEAD, m/kk4.4-caf, github/cm-11.0) [Chao Yu]
2014-08-21 | libstagefright: refactor Legacy LPA makefile [RonGokhale]
2014-08-21 | libstagefright: Enable meta mode for 7x27a video encoder [Mahesh Lanka]
2014-08-21 | libstagefright: Add support for custom LPA buffer size in legacy LPAPlayer [Arne Coucheron]
2014-08-21 | hwc: For FB target check RGB pipe availability before VG pipe [Baldev Kumar Sahu]2014-08-21 | mm-core: Remove obsolete msm7x30 OMX code (HEAD, m/kk4.4-caf, github/kk4.4) [Michael Bestas]
2014-08-21 | hwc: Disable mdp comp if mDownscaleMode is set for external [Baldev Kumar Sahu]
2014-08-21 | drivers/gpu/msm/adreno.c Fix unitialized variable [Josue Rivera]2014-08-18 | DeskClock: PL Translation (HEAD, m/kk4.4-caf, github/kk4.4) [yaatzek]2014-08-23 | Dialer DE translations (HEAD, m/kk4.4-caf, github/kk4.4) [tjengo]
2014-08-21 | display: Cover NO_IOMMU for msm7x30/msm7x27a too [Arne Coucheron]
2014-08-21 | audioflinger: only exchange AUDIO_SOURCE_HOTWORD when using pre-kitkat audio-policy [Michael Gernoth]
2014-08-20 | rhine: Remove unnecessary overlay option [Ethan Chen]2014-08-21 | Revert "Fix decoder EOS handling" (HEAD, m/kk4.4-caf, github/kk4.4-caf) [Steve Kondik]
2014-08-20 | power: Android.mk: Remove TARGET_USES_CPU_BOOST_HINT (HEAD, m/kk4.4-caf, github/kk4.4) [Sultanxda]2014-08-19 | jf: tweak performance profiles (HEAD, m/kk4.4-caf, github/kk4.4) [Drew Davis]
2014-08-20 | perf.profiles: cores online when setting [Tom Hite]
2014-08-20 | LightsWrapper: Use hw_get_module_by_class [Jiangyi]2014-08-20 | Add stepcounter and stepdetector permission xml [Chirayu Desai]
2014-08-20 | CameraWrapper: Use hw_get_module_by_class [Jiangyi]
2014-08-20 | camera: clean up wrapper code [Ethan Chen]
2014-08-20 | camera: Cleanup & remove compiler warnings [Michael Bestas]
2014-08-19 | msm8960-common: simplify isSupported check in cmhw [Dave Daynard]
2014-08-19 | jf: regen defconfig [Dan Pasanen]
2014-08-19 | jf: merge GT-I9505_KK_Opensource_Update9 [Drew Davis]
2014-08-19 | jflte: simplify isSupported check in cmhw [Dave Daynard]
2014-08-19 | Bump for weekly 7.4 [Josue Rivera]
2014-08-18 | SystemUI: PL Translation [yaatzek]2014-08-21 | hal: allow msm8610 to use same functions as msm8226/msm8974 (HEAD, m/kk4.4-caf, github/kk4.4) [Konsta]2014-08-21 | hwc: rotator is not supported on msm7x27a (HEAD, m/kk4.4-caf, github/kk4.4) [RonGokhale]
2014-08-18 | SystemUI FR Translation: fix some translations. [Erwan Finot]
2014-08-18 | Settings FR Translation: fix some word orders and translations. [Benjamin Anselin]2014-08-25 | Telephony DE translations (HEAD, m/kk4.4-caf, github/kk4.4) [tjengo]
2014-08-18 | Revert "msm: scm-pas: Provide a strongly ordered buffer to the secure world" [Dan Pasanen]
2014-08-18 | Revert "msm: scm: Add scm_call_atomic3" [Dan Pasanen]
2014-08-18 | Revert "msm: kgsl: Add separate GPU shader memory mapping" [Dan Pasanen]
2014-08-18 | Revert "iommu/core: pass a user-provided token to fault handlers" [Dan Pasanen]
2014-08-18 | Revert "Execute shader on wakeup from power collapse" [Hareesh Gundu]
2014-08-18 | Revert "ARM: Add support for 64 bit register reads/writes" [Dan Pasanen]
2014-08-18 | Remove DeviceSettings move to device specific [nicklovell23]
2014-08-18 | QuickSettings : Register/unregister cast tile one time [Danesh M]
2014-08-18 | More of the Kernel Tweaking to improve Network and Performance. *Author:perseus71 [nicklovell23]
2014-08-18 | jf: report SW_LID instead of SW_FLIP [Roman Birg]
2014-08-18 | jf: insidesecure vpn: goodbye [Drew Davis]
2014-08-18 | drivers: gpu: s/msm2/msm/ [Dan Pasanen]
2014-08-18 | Core FR Translation: fix some translations. [Erwan Finot]
2014-08-18 | Bring Device Settings to device specific [nicklovell23]
2014-08-17 | props: update libqc-opt location [invisiblek]
2014-08-17 | msm8960-common: Clean up Samsung device inheritance [Ethan Chen]2014-08-17 | qcom-common: Clean up Samsung device inheritance (HEAD, m/kk4.4-caf, github/kk4.4) [Ethan Chen]2014-08-25 | honami: update signature (.133) (HEAD, m/kk4.4-caf, github/kk4.4) [OmarEinea]2014-08-20 | camera: do not use GNU old-style field designators (HEAD, m/kk4.4-caf, github/kk4.4) [synergydev]
2014-08-17 | jflte: use samsung gpe 4.4.4 adreno blobs [invisiblek]
2014-08-17 | jflte: Clean up Samsung device inheritance [Ethan Chen]2014-08-25 | msm8960-common: cleanup some permissions (HEAD, m/kk4.4-caf, github/kk4.4) [jt1134]
2014-08-17 | Increase in call volume [Perseus71]
2014-08-17 | Camera: enable antibanding at all times [Dan Pasanen]
2014-08-16 | Revert "libstagefright: Keep LOOPING/AUTO_LOOPING flag during teardown" [Steve Kondik]
2014-08-16 | panel: samsung-octa: flash hot pink for underruns [Dan Pasanen]
2014-08-16 | msm_fb: display: get mdp bandwidth parameters from board file [Huaibin Yang]2014-08-23 | Bump version (HEAD, m/kk4.4-caf, github/kk4.4) [OmarEinea]
2014-08-16 | jf: mdp: fix mdp bandwidth [Shareef Ali]
2014-08-16 | audioflinger: exchange AUDIO_SOURCE_HOTWORD with AUDIO_SOURCE_VOICE_RECOGNITION for pre-kitkat blobs. [chrmhoffmann]2014-08-25 | FB: Volume panel background color && transparency [2/2] (HEAD, m/kk4.4-caf, github/kk4.4-caf) [dankoman]
Reaktionen: beicuxhaven
Wenn mich nicht alles täuscht ist hier der neue CM Kernel aktiv. Also funktioniert alucard nur mit der neuen CM Version.
Kann man den taskmanager ändern
Nein
Reaktionen: arjen robben
Habe gerade die Weekly 7.6 drauf und seit dem bekomme ich kein Netz mehr?
Kann aber nicht am KT-Kernel vom 12.07. liegen oder?
Slim 7.6 basiert auf den neuen CM11 Sources und damit ist der KT raus
Verstehe. Wie verhält sich Slimkat mit AluCard? Empfehlenswert?
ja, empfehlenswert, aber dann den AOSP V2 ab Slim 7.6
Nicht empfehlenswert, da anderer Kernel.
@Steb empfindest du somit den Hauseigenen Kernel von slimkat als sinniger/sparsamer/abgestimmter?
Ich will eigentlich nur einen schön stromsparenden Kernel der mir aber nicht zuviel Power raubt. War mit KTweaker recht zufrieden aber der hat ja erst mal Entwicklungspause
Definitiv ;)
Ich habe viele Kernel getestet, auch den Alucard, und die liefen auf Dauer nie sehr stabil. Und die Energieersparnis bei anderen Kerneln liegt vielleicht bei 0, 1% pro Stunde. Also nicht besonders viel.
Ich rate immer zum mitgelieferten Kernel.
Ok, nur um auf Nummer sicher zu gehen. Ich hab gestern nach dem Weekly Update auf 7.6 das Kernel Cleaner Script geflashed und dann Alucard aufgespielt.
Wenn ich jetzt zurück auf den ursprünglichen Kernel von Slimkat will gehe ich in Recovery, flashe Slimkat und mini Gapps neu und thats it. Richtig?
jepp, slimkat reicht
Ich bleib auch seit längerem bei den mitgelieferten Kernel,.
Zum einen
haben sich die "Köche" schon dabei was gedacht und das Gesamt Paket (System & Kernel) aufeinander abgestimmt.
Zum anderen
Haben die "Extra" Kernel z. T. Sehr viele Einstellungs Möglichkeiten von denen die meisten keine bzw kaum Ahnung haben was die einzelnen settings miteinander bewirken.
Also sollte man gut Ahnung haben was man einstellt, ansonsten FINGER WEG davon.
Ok, dann gebe ich dem originale Kernel mal eine Chance ;)
Wo hätte ich denn zb noch die Möglichkeit trotzdem an Dingen wie CPU Min/Max Geschwindigkeit rumzuschrauben oder USB ma Werte zu ändern?
Bei den Standard Kerneln nicht. Ist aber auch nicht nötig, da die CPU sowieso besser nicht übertaktet werden sollte.
Leute über was redet ihr? Einerseits soll der Akku geschont werden, also muss zwingend ein anderer Kernel her? Andererseits übertakten? Sorry, aber das ist doch irgendwie gegensächlich :rolleyes:
wo steht dass er übertakten will?
Vielleicht soll untertaktet werden, um Akku zu sparen.
(ob's was bringen würde wäre ein anderes Thema)
oops, wird langsam OT
Da haben wir es wieder...
Untertakten alleine bringt nicht wirklich viel
Dazu sollte man UNTER ANDEREM auch die Spannung RICHTIG angleichen.
das ist oft ein probieren und testen...
Bei "nur" Untertakten kann es beim scrollen Beispielsweise beim Browser zu ruckler kommen...
Es geht weiter... Neuerungen in den kommenden Versionen: Lock screen wallpaper
http://forum.xda-developers.com/showthread.php?p=55141083
Der ursprüngliche Beitrag von 18:36 Uhr wurde um 18:37 Uhr ergänzt:
Sowohl als auch ist es, sorry, Blödsinn. Egal was man macht, man handelt sich dadurch Fehler ein und sogar mehr Akku Verbrauch. Aber das ist hier richtig OT! Dafür gibt es Akku threads. ;)
Fifaheld
postmaster
Fifaheld
Fifaheld
Fifaheld
Fifaheld
Darks
Darks
