Rosa Elefant
Gast
Hui:
Einiges Interessantes dabei.
Hat eigentlich jemand Probleme mit den Beta-GApps festgestellt oder kann man die einigermaßen zuverlässig nutzen?
2014-06-22 | Unify Motorola msm8960 devices [Jon Kagan]
2014-06-22 | msm: fix in-tree compilation for perf_trace_counters [Bryan Huntsman]
2014-06-22 | Add moto_msm8960dt (Moto X) [Jon Kagan]
2014-06-22 | Add Falcon (Moto G) [Jon Kagan]
2014-06-21 | We now use in-kernel mpdecision [Flemmard]
2014-06-21 | Update posteffect [Shantur Rathore]
2014-06-21 | Squash CM upstream [Jon Kagan]2014-06-17 | futex: Make lookup_pi_state more robust (HEAD, m/kk4.4-caf, github/kk4.4) [Thomas Gleixner]
2014-06-21 | sepolicy: updates for 4.4.3 gps hal and mpdecision [dhacker29]2014-06-17 | Revert "d2lte: update blobs" (HEAD, m/kk4.4-caf, github/kk4.4) [Nick Lovell]2014-06-16 | jflte: fix the auto brighness curve (HEAD, m/kk4.4-caf, github/kk4.4) [Drew Davis]2014-06-15 | sony: common: update extract file script (HEAD, m/kk4.4-caf, github/kk4.4) [Giulio Cervera]2014-06-14 | Adreno driver cleanup (HEAD, m/kk4.4-caf, github/kk4.4) [Chirayu Desai]2014-06-14 | Adreno driver cleanup (HEAD, m/kk4.4-caf, github/kk4.4) [Chirayu Desai]2014-06-16 | bluedroid: Disable AVRCP 1.5 by default (HEAD, m/kk4.4-caf, github/kk4.4-caf) [Ethan Chen]2014-06-17 | Backport "Recycle old V8 wrapper objects on navigations" [Mikhail Naganov]
2014-06-21 | pyramid: update wifi firmware, update vendor-blobs.mk [Flemmard]
2014-06-21 | pyramid : update some chromatix libs [Flemmard]
2014-06-21 | pyramid: update libacdbloader [Flemmard]
2014-06-21 | pyramid: update chromatix [Flemmard]
2014-06-21 | pyramid: update acdb/alsa libs from VilleC2 [Flemmard]
2014-06-21 | pyramid: remove default camera [Flemmard]
2014-06-21 | proprietary-files: Remove uneeded lib [dhacker29]
2014-06-21 | proprietary-files: Organize by usage [dhacker29]
2014-06-21 | mm-omxcore is built by media-caf [Flemmard]
2014-06-21 | Initial commit of pyramid cm-10.2 [Flemmard]2014-06-20 | hammerhead: update blobs for 4.4.4 (HEAD, m/kk4.4-caf, github/kk4.4) [Lars Greiss]2014-06-22 | Squah props (HEAD, m/kk4.4-caf, github/kk4.4) [Jon Kagan]2014-06-22 | n7100: add camera blob from 4.4 release (HEAD, m/kk4.4-caf, github/kk4.4) [Dimitris Mantzouranis]
2014-06-21 | htcbatt: Fix charging issue [Shantur Rathore]
2014-06-21 | Hexed correct horizontal and vertical view angles [Shantur Rathore]
2014-06-21 | Hexed correct focal length for s5k3h1 [Shantur Rathore]
2014-06-21 | Hacked hal to fix continuous autofocus [Shantur Rathore]
2014-06-21 | Fix autofocus [Shantur Rathore]
2014-06-21 | Create thermald.conf symlink in /etc as well [namagi]
2014-06-21 | camera: new JB HAL [Flemmard]
2014-06-21 | Add support for i9500 [Arun Manohar Manoharan]
2014-06-21 | Add pyramid support [Dimitris Mantzouranis]
2014-06-20 | wpa_supplicant: disable p2p [Christopher R. Palmer]
2014-06-20 | update to 4.4.4 [Lars Greiss]
2014-06-20 | Update fingerprint for xt1033 to 4.4.3 [dhacker29]
2014-06-20 | staging: binder: add vm_fault handler [Vinayak Menon]
2014-06-20 | Staging: android: binder: More offset validation. [Arve Hjønnevåg]
2014-06-20 | root: Updates from caf/stock 4.4.3 [dhacker29]
2014-06-20 | root: Fix permissions on dev/hw_random so qrngd starts [dhacker29]
2014-06-20 | Revert "Vpn: Setup routes." [Lars Greiss]
2014-06-20 | proprietary-files: Use stock libqsap_sdk.so [dhacker29]
2014-06-20 | proprietary-files: Update xt1033 specific libs for 4.4.3 [dhacker29]
2014-06-20 | proprietary-files: Update to 4.4.3 KXB21.14-L1.32, except camera [dhacker29]
2014-06-20 | proprietary-files: Organize by usage [dhacker29]
2014-06-20 | prctl: adds the capable(CAP_SYS_NICE) check to PR_SET_TIMERSLACK_PID. [Ruchi Kandoi]
2014-06-20 | power: Enable CPU boost hint [dhacker29]
2014-06-20 | overlay: Update power_profile from stock 4.4.3 [dhacker29]
2014-06-20 | m8: Remove composition property [Dan Pasanen]2014-06-20 | releasetools: set metadata for xt1033 rild (HEAD, m/kk4.4-caf, github/kk4.4) [dhacker29]
2014-06-20 | m8: increase ui responsiveness [Steve Kondik]
2014-06-20 | m8: enable eject sdcard [Dan Pasanen]
2014-06-20 | Keyguard: update correctly track title and info if screen turns on [Lars Greiss]
2014-06-20 | Keyguard: don't try to fetch the badgeIcon if remoteClientPackage == null [Lars Greiss]
2014-06-20 | init: Update fingerprint to 4.4.3 for xt1034 [dhacker29]2014-06-22 | Disable QCOM_WLAN_SDK until I figure out moto's changes (HEAD, m/kk4.4-caf, github/kk4.4) [dhacker29]
2014-06-20 | gps: caf LNX.LA.3.5.2.2_rb1 and use blobs from bacon [dhacker29]
2014-06-20 | Fix extract files logic [dhacker29]2014-06-21 | Move legacy GPS HAL to needed devices (HEAD, m/kk4.4-caf, github/kk4.4) [dhacker29]
2014-06-20 | drivers: staging: prima: kk_2.7-stable [Dave Daynard]
2014-06-20 | cfg80211: Allow use_mfp to be specified with the connect command [Jouni Malinen]
2014-06-20 | cfg80211: Advertise maximum associated STAs in AP mode [Jouni Malinen]
2014-06-20 | audio: Disable offload for now [dhacker29]
2014-06-20 | audio config updates [dhacker29]
2014-06-20 | Add EventLog event for logging of attempts to call java.lang.Object.getClass [Mikhail Naganov]
2014-06-19 | minui: remove overlay support for MDSS_V5 for now and add support for MDP_V3_0_4. (HEAD, m/kk4.4-caf, github/kk4.4) [Lars Greiss]2014-06-17 | "KTU84P" [The Android Automerger]
2014-06-19 | ASoC: soc-compress: Serialise compressed ops [Charles Keepax]
2014-06-19 | ASoC: soc-compress: Initialise delayed work to power down audio [Charles Keepax]
2014-06-19 | ASoC: soc-compress: Add support for not memory mapped DSPs [Charles Keepax]
2014-06-19 | ASoC: soc-compress: Add missing brackets around else [Charles Keepax]
2014-06-19 | ASoc: fix compilation error [Eric Laurent]
2014-06-19 | ASoC: compress: Only mute playback streams [Mark Brown]
2014-06-19 | ASoC: compress - fix code alignment [Vinod Koul]
2014-06-19 | ASoC: compress: Cancel delayed power down if needed [Charles Keepax]
2014-06-19 | ASoC: compress - add support for metadata apis [Jeeja KP]
2014-06-19 | ASoC: add definations for compressed operations [Vinod Koul]
2014-06-19 | ASoC: add compress stream support [Namarta Kohli]
2014-06-19 | ALSA: core: don't return uninitialized snd_compr_tstamp [Richard Fitzgerald]
2014-06-19 | ALSA: compress - move the buffer check [Vinod Koul]
2014-06-19 | ALSA: compress: fix compilation error [Eric Laurent]
2014-06-19 | ALSA: compress_core: integer overflow in snd_compr_allocate_buffer() [Dan Carpenter]
2014-06-19 | ALSA: compress_core: fix open flags test in snd_compr_open() [Dan Carpenter]
2014-06-19 | ALSA: compress_core: don't wake up on pause [Vinod Koul]
2014-06-19 | ALSA: compress_core: cleanup pointers on stop [Vinod Koul]
2014-06-19 | ALSA: compress: add support for gapless playback [Jeeja KP]
2014-06-19 | ALSA: Compress - add codec parameter checks [Vinod Koul]
2014-06-17 | Telephony: ES translations [Carlos Solano]
2014-06-17 | Settings: ES translations [Carlos Solano]
2014-06-17 | Revert "d2lte: update blobs" [Nick Lovell]2014-06-23 | Bump to 5.10 for weekly (HEAD, m/kk4.4-caf, github/kk4.4) [Josue Rivera]
2014-06-17 | msm: kgsl: prevent kgsl_get_pagetable from returning a destroyed pt [Jeff Boody]
2014-06-17 | msm: kgsl: Look up the process struct in process_mem_open() [Jordan Crouse]
2014-06-17 | msm: kgsl: hold a process_private refcount in process_mem_print [Jeremy Gebben]
2014-06-17 | msm: kgsl: Fix spinlock recursion in destroy pagetable [Prakash Kamliya]
2014-06-17 | MR2.1 - Version 4.4.4. Here we go! DO NOT MERGE [Bart Sears]
2014-06-17 | media: Refactor and improve robustness of AdaptivePlaybackTest [Lajos Molnar]
2014-06-17 | hardware: consumerir: Increase test pattern length [Alex Ray]
2014-06-17 | hardware: consumerir: Fix time discrepancy [Alex Ray]
2014-06-17 | futex: Validate atomic acquisition in futex_lock_pi_atomic() [Thomas Gleixner]
2014-06-17 | futex: uninitialized warning corrections [Vitaliy Ivanov]
2014-06-17 | futex: prevent requeue pi on same futex [Thomas Gleixner]
2014-06-17 | futex: Prevent attaching to kernel threads [Thomas Gleixner]
2014-06-17 | futex: Always cleanup owner tid in unlock_pi [Thomas Gleixner]
2014-06-17 | futex: Add another early deadlock detection check [Thomas Gleixner]2014-06-22 | init: Support power off charging on kitkat bootloader (HEAD, m/kk4.4-caf, github/cm-11.0) [Arne Coucheron]
2014-06-17 | Fix a concurrency bug in OpenSSLHeartbleedTest. [Alex Klyubin]
2014-06-17 | Disable host side holotests also [Unsuk Jung]
2014-06-17 | CTS test for OpenSSL's early CCS issue (CVE-2014-0224) [Alex Klyubin]
2014-06-17 | CTS test for Heartbleed vulnerability in SSLSocket. [Alex Klyubin]2014-06-20 | m8: Fixed IR device permissions (HEAD, m/kk4.4-caf, github/kk4.4) [Mansour Behabadi]
2014-06-17 | CTS report MUST not display raw performance numbers. bug:13347703 [Nicholas Sauer]
2014-06-17 | Cherry-pick "Export WebCore::forgetV8ObjectForNPObject" [Mikhail Naganov]2014-06-17 | Cherrypick "OpenSSL: add CVE fixes from 1.0.1h" [Torne (Richard Coles)]2014-06-17 | Fix Early CCS bug [Brian Carlstrom]2014-06-16 | audioflinger: Stop resetting compress offload streams (HEAD, m/kk4.4-caf, github/kk4.4-caf) [Steve Kondik]
2014-06-17 | Block access to java.lang.Object.getClass in injected Java objects [Mikhail Naganov]2014-06-17 | Fix Java Bridge wrapper properties cleanup for multi-frame pages (HEAD, android-4.4.4_r1, m/kk4.4-caf, aosp/kitkat-mr2.1-release) [Mikhail Naganov]
2014-06-16 | zram: protect sysfs handler from invalid memory access [Jiang Liu]
2014-06-16 | usb: gadget: Ignore the second set_config from the host [ChandanaKishori Chiluveru]
2014-06-16 | usb: ci13xxx_udc: Do not clear ENDPTSETUPSTAT during USB BUS RESET [Saket Saurabh]
2014-06-16 | usb: android: Skip the work when set_config arrives with same value twice [ChandanaKishori Chiluveru]
2014-06-16 | USB: android: release spinlock before queuing work in android_setup [Tarun Gupta]
2014-06-16 | Telephony: Dialpad key padding [3/3] [dankoman]
2014-06-16 | SystemUI: Update circle battery UI to be in line with CM [gwindlord]
2014-06-16 | Staging: zram: Fix memory leak by refcount mismatch [Rashika Kheria]
2014-06-16 | stagefright: add ClockEstimator API and WindowedLinearFitEstimator [Lajos Molnar]
2014-06-16 | Smooth out AwesomePlayer [Lajos Molnar]
2014-06-16 | Slim Recents: Option to show topmost task [2/2] [Schubi]2014-06-16 | SlimCenter: translation - RU (HEAD, m/kk4.4-caf, github/kk4.4) [gwindlord]
2014-06-16 | Slim Recents: Option to show topmost task [1/2] [Schubi]
2014-06-16 | Slim Recents: Always show topmost task collapsed [Schubi]
2014-06-16 | SlimCenter: ES translations [Carlos Solano]
2014-06-16 | Settings: translation - RU [gwindlord]
2014-06-16 | Settings: ES translations [Carlos Solano]
2014-06-16 | SCSI: megaraid: Use resource_size_t for PCI resources, not long [Ben Collins]
2014-06-16 | Revert "usb: otg: Retry putting the OTG PHY in low power mode." [Dave Daynard]
2014-06-16 | Revert "usb: ehci-msm: enable HCD_OLD_ENUM" [Dave Daynard]
2014-06-16 | Revert "Touchscreen optimizations" [Luis Cruz]
2014-06-16 | Revert "Fixes for GCC error on panel" [Dave Daynard]
2014-06-16 | Revert "drivers: usb: Use Android device as USB keyboard/mouse" [Dave Daynard]
2014-06-16 | Revert "cpufreq: interactive: Optimize sync_freq implementation" [Malcolm Mallardi]
2014-06-16 | QuickRecord: Fix crash on other languages [Jubakuba]
2014-06-16 | powerpc: Fix 64 bit builds with binutils 2.24 [Guenter Roeck]
2014-06-16 | nl80211: Correct the usage of command NL80211_CMD_VENDOR [Sunil Dutt]
2014-06-16 | netfilter: ipv4: defrag: set local_df flag on defragmented skb [Florian Westphal]
2014-06-16 | mlx4_en: don't use napi_synchronize inside mlx4_en_netpoll [Chris Mason]2014-06-15 | [media] media-device: fix infoleak in ioctl media_enum_entities() (HEAD, m/kk4.4-caf, github/cm-11.0) [Salva Peiró]2014-06-19 | Correctly close IME keyboard if Calculator is launched (HEAD, m/kk4.4-caf, github/kk4.4) [Lars Greiss]2014-06-19 | Camera2: add missing 4MP option string (HEAD, m/kk4.4-caf, github/kk4.4) [Devin J. Pohly]2014-06-16 | Dialer: Add Dialpad key padding [1/3] (HEAD, m/kk4.4-caf, github/kk4.4) [dankoman]2014-06-20 | Settings: Change desc for battery charging text color [dankoman]
2014-06-16 | Linux 3.4.94 [Greg Kroah-Hartman]
2014-06-16 | Grant qcom_oncrpc group to system_server [Ricardo Cerqueira]
2014-06-16 | Fix for crash in LocationManagerService [Ashwin Kumar]
2014-06-16 | fb: translation - RU [gwindlord]
2014-06-16 | drivers: staging: update prima to kk_2.7-stable [Dave Daynard]
2014-06-16 | decouple SW FLP and HW FLP overlay flags [Kevin Tang]
2014-06-16 | d2: enable usb host notify [Dave Daynard]
2014-06-16 | cpufreq: Persist cpufreq time in state data across hotplug [Ruchi Kandoi]
2014-06-16 | Combo Provider: Specific location screening [Dante Russo]
2014-06-16 | Combo Provider: Get the package name from resource [Dante Russo]
2014-06-16 | Clear cached locations when location providers disabled Bug: 12118307 [David Christie]
2014-06-16 | Bump for Weekly 5.9 [Josue Rivera]
2014-06-16 | auditsc: audit_krule mask accesses need bounds checking [Andy Lutomirski]
2014-06-16 | audio: Increased mute wait for USB Playback [Pavan Chikkala]
2014-06-16 | audio: improve logging. [Sidipotu Ashok]2014-06-20 | [media] media-device: fix infoleak in ioctl media_enum_entities() (HEAD, m/kk4.4-caf, github/kk4.4) [Salva Peiró]
2014-06-16 | audio:Avoid AudioTrackThread if Track creation fails [Divya Narayanan Poojary]2014-06-20 | FB: Add Dialpad key padding [2/3] [dankoman]
2014-06-16 | ahci: Add Device ID for HighPoint RocketRaid 642L [Jérôme Carretero]
2014-06-16 | Add class for identifying slim build type and version [Griffin Millender]
2014-06-15 | fb: translation - RU [gwindlord]2014-06-17 | Sanitize selector Intent when handling intent: scheme. (HEAD, android-4.4.4_r1, m/kk4.4-caf, aosp/kitkat-mr2.1-release) [Marcin Kosiba]2014-06-16 | Audio: Add new format and property for PCM offload (HEAD, m/kk4.4-caf, github/kk4.4-caf) [ApurupaPattapu]
2014-06-15 | Add prop for buildtype [Griffin Millender]
2014-06-14 | repopick: fetch from Slim gerrit [Anthony King]
2014-06-14 | repopick: Don't redirect stdout on --quiet [OmniBot Auto Verifier]
2014-06-14 | repopick: Allow picking batch of commits with the same Change-Id [Dominik Marszk]
2014-06-14 | repopick: Add a way to checkout instead of cherrypick [OmniBot Auto Verifier]
2014-06-14 | Only include SlimIRC on OFFICIAL and WEEKLY builds [Griffin Millender]2014-06-22 | Adreno driver cleanup (HEAD, m/kk4.4-caf, github/kk4.4) [Chirayu Desai]
2014-06-14 | Add repopick script from CM [Pulser]2014-06-17 | DO NOT MERGE Update for version bump (HEAD, android-4.4.4_r1, m/kk4.4-caf, aosp/kitkat-mr2.1-release) [Stuart Scott]
2014-06-13 | Telephony: translation - RU [gwindlord]2014-06-20 | update to 4.4.4 (HEAD, m/kk4.4-caf, github/kk4.4-caf) [Lars Greiss]2014-06-21 | pyramid: bcmdhd: use firmware from hardware/broadcom (HEAD, m/kk4.4-caf, github/kk4.4) [Flemmard]
2014-06-13 | stereo call recording support [Heinz Teutsch]2014-06-22 | Squash WLAN commits (HEAD, m/kk4.4-caf, github/kk4.4) [Jon Kagan]
2014-06-13 | msm: mdss: set pipe to solid fill when releasing it [Adrian Salido-Moreno]
2014-06-13 | msm: mdss: Program unpack pattern for pipes with solidfill [Aravind Venkateswaran]
2014-06-13 | msm: mdss: Notify userspace of idle screen case [Aravind Venkateswaran]
2014-06-13 | msm: mdss: fix race condition between shutdown thread and fb ioctl [Ujwal Patel]
2014-06-13 | msm: mdss: Don't call pan_idle for MSMFB_OVERLAY_PREPARE ioctl [Ramakant Singh]
2014-06-13 | msm: mdss: Clear the previous state of pipe during SOLID_FILL [Sushil Chauhan]
2014-06-13 | msm: mdss: Add update notify for backlight change in static screen [Ping Li]
2014-06-13 | msm: display: reduce display commit prepare waiting time [Ken Zhang]
2014-06-13 | Add dialog to notify user slimIRC is not available on unofficial builds [Griffin Millender]2014-06-21 | Telephony: translation - RU [gwindlord]
