Steveria
Enthusiast
- 413
Gapps sind die auch neu?
Frameworks: EdgeGestureService give abbility to reduce the left and right trigger site on IME keyboard
Frameworks: SlimPie give user ability to reduce trigger heights if IME is active
Frameworks: TRDS fix possible UI freeze on auto mode change
Frameworks: Respect and handle shorcut custom icon resources
Frameworks: Add support for QC's time_daemon
Frameworks: fix sdk build
Frameworks: Keyguard: Ensure that a widget and page is attached before attaching the ChallengeLayout.OnBouncerStateChangedListener
Frameworks: Revert "Make sure to turn off led after pulse()"
Bootable recovery: Load RTC offset on Qualcomm Krait chips, fixes the broken time & date
Dialer: Add WhitePages Canada reverse lookup provider
WhitePages API: Only reload page if the first load has the UUID for the cookie
Telephony: fix reverese lookup gms logic detection
General: Again a lot translation updates. Tons of new translations will follow soon (italian and german eg)
General: A lot small fixes
Device specific: Again a lot small fixes and upstream. For device specific changes see the attached changelog in the download folder of your device
Gapps: Update to latest google apps
Gapps: PlayStore and YouTube TRDS compatibility
IXerxes schrieb:Habe den Stock Kernel noch drauf. Sollte ich einen anderen nehmen?
IXerxes schrieb:weiß zufällig noch jemand wie ich das weiß wegbekomme? Das blau von der 4.3.1 war sehr angenehm.
IXerxes schrieb:Die blaue apk
IXerxes schrieb:Das ist total kompliziert. Habe das xposed drauf. Auch die 2.4.1. Trotzdem lässt er mich keine Module installieren weil er kein framework hat.
