			tobiasth
Philosoph
- 2.559
- Themenstarter
- #481
Marzl85 schrieb:Zieht mal die Notificationbar runter und klickt mal rechts oben LANGE auf das Symbol
Coooool
			2014-02-02 | The draft still exists after forwarding mms to the same sender [yanglv]
2014-02-02 | SystemUI: Fix missing top task in recent panel. [Kiril Mikos]
2014-02-02 | Perform NTP lookup at Mobile data connections [Martin Olsson 4]
2014-02-02 | Manifest: Add qrngd repo [Josue Rivera]2014-01-25 | Squash UMS Commits [2/3] (HEAD, m/kk4.4-caf, github/kk4.4) [Muhammed Nazim]2014-02-02 | jf: update wifi blobs from gpe 4.4.2 (HEAD, m/kk4.4-caf, github/kk4.4) [Dan Pasanen]
2014-02-02 | jf fixme [Shareef Ali]
2014-02-02 | jf: fix init sequence for dsp [Shareef Ali]
2014-02-02 | jf-common: this was a dumb way to run restorecon [dcd]
2014-02-02 | jf-common: these services dont really exist [dcd]
2014-02-02 | jf-common: these lines are duplicated [dcd]
2014-02-02 | jf-common: remove usf* services that dont exist [dcd]
2014-02-02 | jf-common: mount debugfs earlier [dcd]
2014-02-02 | jf-common: init.qcom.rc: remove fm_dl service [Drew Davis]
2014-02-02 | jf-common: fstab is ugly [dcd]
2014-02-02 | jf-common: fix mount debugfs syntax [dcd]
2014-02-02 | jf-common: fix mkdir /efs [dcd]
2014-02-02 | jf-common: dont run init.qcom.ril.sh [dcd]
2014-02-02 | jf-common: bye /persdata [dcd]
2014-02-02 | jf-common: actually build the crda service [Dave Daynard]
2014-02-02 | jf: add missing libCB (needed for renderscript) [Dan Pasanen]
2014-02-02 | jf: add magic samsung kernel cmdline [Dan Pasanen]
2014-02-02 | jf: add libCB [Dan Pasanen]
2014-02-02 | init: remove redundant tcp buffersize props [Dan Pasanen]
2014-02-02 | implement noise suppression for phone calls (1/2) [codeworkx]
2014-02-02 | gps: turn down logging [Dan Pasanen]
2014-02-02 | GpsLocationProvider: look for config file in /etc/gps.<ro.hardware.gps>.conf [Colin Cross]
2014-02-02 | Framework: Super advanced Custom Toggle (1/2) [Jubakuba]
2014-02-02 | frameworks: translation - RU [gwindlord]
2014-02-02 | fix search textfield [kroz]
2014-02-02 | fix number picker blue line and highlight [kroz]
2014-02-02 | Fixed race condition in Spinner.DialogPopup on null reference. [Daniel 2 Olofsson]
2014-02-02 | Fix dest == src bugs in Matrix.cpp. [Mathieu Chartier]
2014-02-02 | fb: unbreak recents animations on thumbnail click or dismiss recents screen [Lars Greiss]
2014-02-02 | fb: Handle navbar heights correct on dpi changes + more (1/2) [Lars Greiss]
2014-02-02 | fb: handle globalmenu in SlimActions not over Powerbutton anymore [Lars Greiss]
2014-02-02 | fb: handle for our navigation bar recentspreload in the button [Lars Greiss]
2014-02-02 | Enable smooth-streaming video-playback [Arne Coucheron]
2014-02-02 | Display message type properly for MMS and SMS [kaiyiz]
2014-02-02 | Change tether regexs [Arne Coucheron]
2014-02-02 | Bluetooth: updates [Dan Pasanen]
2014-02-02 | Base: CS Translation [Keany]
2014-02-02 | AssetManager cookies should be int32_t and not void*. [Narayan Kamath]
2014-02-02 | Add GSM only network mode [Scott Warner]
2014-02-02 | [ActivityManager]: Fix the activity visibility state not sync between ActivityManager and WindowManager [louis_chang]
2014-02-01 | Update init.g2.rc [arcardinal]
2014-02-01 | Settings: Super advanced Custom Toggle (2/2) [Jubakuba]
2014-02-01 | Revert g2: dexopt system to /cache [arcardinal]
2014-02-01 | Revert g2: add optimization [arcardinal]
2014-02-01 | msm: mdss: release all overlay resources on last fb release [Ujwal Patel]
2014-02-01 | msm: mdss: release all overlay resources if calling process is unknown [Ujwal Patel]
2014-02-01 | msm: mdss: Fix race condition during device shutdown [Ujwal Patel]
2014-02-01 | msm: mdss: fix double sync fence put in buf sync function [Adrian Salido-Moreno]
2014-02-01 | gallery: change typo '&&' to '||' [Leavitt Zhang]2014-02-02 | InCallUI: do not use reflection (HEAD, m/kk4.4-caf, github/kk4.4) [Lars Greiss]2014-02-02 | Resize the image in background (HEAD, m/kk4.4-caf, github/kk4.4) [c_nagarw]
2014-02-01 | Fix Null pointer expection when Phone is in low memory [imran]
2014-02-01 | Camrea2: overlays continuous focus/Cancel autofocus if preview stopped [nicklovell23]
2014-02-01 | Camera2: add option to prevend autofocus cancel if preview stopped [Lars Greiss]2014-02-01 | fix dialog blue divider (HEAD, m/kk4.4-caf, github/kk4.4) [kroz]2014-01-27 | DeskClock: CS Translation (HEAD, m/kk4.4-caf, github/kk4.4) [Keany]2014-01-24 | Dialer: CS translation (HEAD, m/kk4.4-caf, github/kk4.4) [Keany]2014-01-29 | Fix mismatched function arguments in Contact query (HEAD, m/kk4.4-caf, github/kk4.4) [Iago Lopez Galeiras]2014-02-02 | Add WRITE_MEDIA_STORAGE permission (HEAD, m/kk4.4-caf, github/kk4.4) [Muhammed Nazim]
2014-02-01 | Appears black screen fix for a while [jungheang.lee]
2014-02-01 | Add Honami lunch combo [Josue Rivera]
2014-02-01 | Add an option to maintain the focus mode when using touch-to-focus [Ricardo Cerqueira]
2014-01-31 | White emergency dialer [kroz]
2014-01-31 | Update build all branches to include jactive [ktoonsez]
2014-01-31 | Settings: Handle navbar heights correct on dpi changes + more (2/2) [Lars Greiss]
2014-01-31 | Revert "remove qrngd" [Dan Pasanen]
2014-01-31 | restore our history (HEAD, m/kk4.4-caf, github/kk4.4) [Lars Greiss]2014-01-29 | Revert "ARM: Change dmb domain for bionic_atomic_barrier()" (HEAD, m/kk4.4-caf, github/kk4.4) [Lars Greiss]
2014-01-31 | Frameworks: Fix Derp [Jubakuba]
2014-01-31 | d2: update blobs [Dave Daynard]2014-02-02 | roll out RC2 (HEAD, m/kk4.4-caf, github/kk4.4) [Lars Greiss]
2014-01-31 | d2-common: update perms [Dave Daynard]
2014-01-30 | tcp: add a sysctl to config the tcp_default_init_rwnd [JP Abgrall]
2014-01-29 | 'When to daydream' dialog does not follow the JB dialog design guide [Per Allard]
2014-01-29 | Revert "Remove harmful attempts to be helpful in pthread_mutex functions." [Lars Greiss]2014-01-31 | restore our history (HEAD, m/kk4.4-caf, github/kk4.4) [Lars Greiss]
2014-01-29 | GPU:  SOme fix ups and sync with GE 4.4.2 [ktoonsez]
2014-01-29 | Fix memory leak in ManageApplication [Jun Su]
2014-01-29 | cpufreq: ktoonservativeq: Remove GPU boost when another governor is selected [ktoonsez]
2014-01-29 | Bleed keyguard widget picker list into translucent bars [Veeti Paananen]
2014-01-28 | Show a startup page in incognito mode [Chirayu Desai]
2014-01-28 | Revert "Remove Incognito mode from quick controls since it no longer exists in the browser" [Lars Greiss]2014-02-02 | Add WRITE_MEDIA_STORAGE permission [Muhammed Nazim]
2014-01-28 | Revert "disable incognito mode for now due of missing support" [Lars Greiss]
2014-01-28 | Implement client-side incognito mode [Ricardo Cerqueira]
2014-01-27 | writeback: fix race that cause writeback hung [Junxiao Bi]
2014-01-27 | Use right nv symlink for 8226 [dhacker29]
2014-01-27 | setup-makefiles: Allow for apk and jar blobs [dhacker29]
2014-01-27 | sepolicy: fix denials on msm8226 [dhacker29]
2014-01-27 | scripts: remove unused sensorsqcomwrapper.sh [Emerson Pinter]
2014-01-27 | scripts: remove unused qcamerasrvwrapper [Emerson Pinter]
2014-01-27 | Revert "mm: panic on the first bad page table entry access" [Alexander Martinz]
2014-01-27 | Remove old flags no longer used [dhacker29]
2014-01-27 | Remove disableMenuKeyInLockScreen value from overlays as it's now configurable [Nicholas Flintham]2014-02-02 | Fix USB tethering (HEAD, m/kk4.4-caf, github/kk4.4) [arcardinal]
2014-01-27 | props: msm8226 has qcril in system/vendor/lib [dhacker29]
2014-01-27 | prop: Set PRODUCT_GMS_CLIENTID_BASE to android-motorola [dhacker29]
2014-01-27 | Move TARGET_RECOVERY_PIXEL_FORMAT to family [dhacker29]2014-01-26 | Correct overlay for menu unlock (HEAD, m/kk4.4-caf, github/kk4.4) [Muhammed Nazim]2014-01-26 | Add Hardware key related overlays for rebinding and menu unlock (HEAD, m/kk4.4-caf, github/kk4.4) [Josue Rivera]2014-02-02 | d2-common: remove continuous-picture mode (HEAD, m/kk4.4-caf, github/kk4.4) [Dave Daynard]
2014-01-27 | Move ro.qc.sdk.audio.fluencetype to family [dhacker29]
2014-01-27 | Move QCOM_BSP up to family [dhacker29]
2014-01-27 | Move display variant to family trees [dhacker29]
2014-01-27 | jf: defconfig: disable VMWare Mobile Virtualization Platform [Dan Pasanen]
2014-01-27 | jbd2: optimize jbd2_journal_force_commit [mrg666]
2014-01-27 | Fix path for libqc-opt on msm8226 [dhacker29]
2014-01-27 | Fix order of entries in thermal-engine-8226 [dhacker29]
2014-01-27 | Fix init.qcom.thermal for msm8226 [dhacker29]
2014-01-27 | extract-files: Don't show error if no common/proprietary-files.txt [dhacker29]
2014-01-27 | ext4: speed up truncate/unlink by not using bforget() unless needed [Andrey Sidorov]
2014-01-27 | Disable VMWare Mobile Virtualization Platform for Verizon [ktoonsez]
2014-01-27 | cpuidle: make a single register function for all [Daniel Lezcano]
2014-01-27 | ARM: Use -mcpu=cortex-a15 when targeting MSM Krait CPUs [Stepan Moskovchenko]
2014-01-27 | app/Settings: translation - RU [gwindlord]
2014-01-27 | Add CONTROL_PERMS for mmi-ril-daemon to allow cutback socket [dhacker29]
