[ROM][I9505][4.4.4] *29.12.14* Slim Kat 9 [FINAL]
  • 2.353 Antworten
Oh, 2.5 wird keine Beta mehr sein:
  • Frameworks base: Return: Custom Carrier Label
  • Frameworks base: Return: UMS support
  • Frameworks base: Handle backup transport registration dynamically
  • Frameworks base: Harden against transiently unavailable backup transports
  • Frameworks base: Slims Hardware Key Rebinding
  • Frameworks base: Speed up the navbar
  • Frameworks base: Make menu unlock configurable
  • Frameworks base: SystemUI: Pimp-up Media Tile (double tap during play)
  • Frameworks base: finally fix carrier lable shows on first boot sometimes
  • Frameworks base: use on virtual POWER_KEY own global menu handling
  • Frameworks base: TRDS change auto detect light conditions method
  • Frameworks base: Add support for ADB over network
  • Frameworks base: Notification : Fix app info long-press
  • Frameworks base: core: Added national roaming info for Jazztel Movil in Spain
  • Frameworks base: core: added national roaming info for Spring Mobil in Sweden...
  • Frameworks base: Initialize pointer members to NULL to avoid illegal reference
  • Frameworks base: MediaFocusControl: Deny audio focus if notification stream is 0
  • Frameworks base: Set Settings.Global.WIFI_SCAN_ALWAYS_AVAILABLE default value
  • Frameworks base: Fix error checking in MemoryFile.
  • Frameworks base: Fixed stylus eraser being rejected by palm rejection
  • Frameworks base: Fixed incorrect calculation of dirty invalidation area
  • Frameworks base: FLAG_PRIVILEGED disappears if privileged app is updated and rebooted
  • Frameworks base: Only send storage intents after boot complete
  • Frameworks base: Remove unused field from AssetManager.
  • Frameworks base: Telephony: Modify code to check that PUK code length is always 8.
  • Settings: fix Display settings FC on manta or devices without crt mode effect
  • Settings: Remove notification pulse and light for devices without LED
  • Settings: Add CPU & RAM info.
  • dalvik/vm: Dalvik startup with a low memory footprint
  • Mms: reload default drawable if it changed during the instance
  • DashClock: Added condensed font option
  • DashClock: Added separator between extensions
  • DashClock: Added text density option
  • DashClock: Fixed touch feedback, broken in an earlier commit Fixed clock metrics for ...
  • DashClock: some TRDS adjustments
  • DashClock: add background color choice + add more colors for text then just ...
  • DashClock: add preference theme to NextAlarmSettingsActivity
  • DashClock: add src api paths back
  • DashClock: make actionbar consisten with KitKat theme and fix
  • DashClock: disable backgroundcolor preference if opacity = 0
  • DashClock: Fix menu overflow button on dslv
  • Updates on display-caf, audio-caf and media-caf
  • Updates on frameworks native
  • Tons of device upstream and device specific fixes (see device changelog in download area for details)
  • Translation updates
Reaktionen: tobiasth, adl, Steveria und eine weitere Person
Google apps stable build ist online!
Stable slimKat Rc1 im Upload!
Reaktionen: Alleshaber
Die neue Version wird "in 2-3 Stunden" online sein. Wird auch jede Woche später.
Reaktionen: Steveria
Jou, es kommen halt auch immer mehr Geräte hinzu :(
Ärgerlich. Die braucht doch niemand!
Sehe ich auch so :thumbsup::flapper:
B2t :thumbup:
Reaktionen: Steveria und tobiasth
2.5 ist da!
Downloads - jfltexx - Slim-jfltexx-4.4.2.build.2.5.RC1-WEEKLY-2513
(Zur Klarstellung: Das ist "2.5 Final", aber "SlimKat RC1".)
Neue GApps werden ausdrücklich empfohlen.
Ausführliches "Changelog":
Code:
2014-01-26 | SystemUI: Pimp-up Media Tile (1/1) [Jubakuba]
2014-01-26 | Squash UMS Commits [2/3] [Muhammed Nazim]
2014-01-26 | Squash UMS Commits [1/3] [Muhammed Nazim]
2014-01-26 | Set Settings.Global.WIFI_SCAN_ALWAYS_AVAILABLE default value [Oskar Grönqvist]
2014-01-26 | Revert "gcc-wrapper: force python version 2" [Dan Pasanen]
2014-01-26 | Remove unused field from AssetManager. [Narayan Kamath]
2014-01-26 | Remove notification pulse and light for devices without LED [fusionjack]
2014-01-26 | Only send storage intents after boot complete [Johan Redestig]
2014-01-26 | Notification : Fix app info long-press [Danesh Mondegarian]
2014-01-26 | msm: usbaudio: Add check for NULL before dereferencing [Mayank Rana]
2014-01-26 | msm: qdsp6v2: Buffer address for Record and playback is 32-byte aligned. [Asish Bhattacharya]
2014-01-26 | msm8974: Enable USB audio [Steve Kondik]
2014-01-26 | msm8974: Enable new mixer for offload [Steve Kondik]
2014-01-26 | msm8974: Enable deep buffer output as primary [Steve Kondik]
2014-01-26 | msm8974: Add offload properties [Steve Kondik]
2014-01-26 | MediaFocusControl: Deny audio focus if notification stream is 0 [Evan Anderson]
2014-01-26 | Initialize pointer members to NULL to avoid illegal reference [lina.x.pi]
2014-01-26 | Harden against transiently unavailable backup transports [Christopher Tate]
2014-01-26 | Handle backup transport registration dynamically [Christopher Tate]
2014-01-26 | FLAG_PRIVILEGED disappears if privileged app is updated and rebooted [Naofumi Harada]
2014-01-26 | Fix error checking in MemoryFile. [Narayan Kamath]
2014-01-26 | Fixed stylus eraser being rejected by palm rejection [FPtje]
2014-01-26 | Fixed incorrect calculation of dirty invalidation area [Johan Viktorsson]
2014-01-26 | fb: use on virtual POWER_KEY own global menu handling [Lars Greiss]
2014-01-26 | fb: TRDS change auto detect light conditions method [Lars Greiss]
2014-01-26 | fb: finally fix carrier lable shows on first boot sometimes [Lars Greiss]
2014-01-26 | d2: correct overlay for menu unlock [jyates]
2014-01-26 | core: added national roaming info for Spring Mobil in Sweden... [d95andek]
2014-01-26 | core: Added national roaming info for Jazztel Movil in Spain [arnau]
2014-01-26 | ASoC: qdsp6: Add support for gapless audio playback [Ravi Kumar Alamanda]
2014-01-26 | ASoC: qdsp6: Add support for custom topology [Subhash Chandra Bose Naripeddy]
2014-01-26 | ASoC: qdsp6: Add support for audio post processing effects [Ravi Kumar Alamanda]
2014-01-26 | ASoC: msm: Route low latency frontend to in-call music backend [Narsinga Rao Chella]
2014-01-26 | ASoC: msm: qdsp6v2: Set ADM sample rate to 48Khz for ULL [Krishnankutty Kolathappilly]
2014-01-26 | ASoC: msm: qdsp6v2: Set ADM channel to max supported for ULL [Vimal Puthanveed]
2014-01-26 | ASoC: msm: qdsp6v2: Handle SSR for audio playback over BT usecase [Phani Kumar Uppalapati]
2014-01-26 | ASoC: msm: qdsp6v2: fix the crash issues due to NULL pointer [Fred Oh]
2014-01-26 | ASoC: msm: qdsp6v2: Fix APR de-register issues during session close [Phani Kumar Uppalapati]
2014-01-26 | ASoC: msm: qdsp6v2: Don't update state variables for no-wait commands [Phani Kumar Uppalapati]
2014-01-26 | ASoc: msm: qdsp6: Add ultra low latency playback support [Aleksander Holynski]
2014-01-26 | ASoC :msm: Increase Proxy buffering [Amit Shekhar]
2014-01-26 | ASoC: msm: Handle RESET_EVENTS in compress driver [Haynes Mathew George]
2014-01-26 | ASoC: msm: flush if prior and current backends rate not matching [Damir Didjusto]
2014-01-26 | ASoC: msm: Fix playback failure on device switch during ULL playback [Krishnankutty Kolathappilly]
2014-01-26 | ASoC: msm: Enable initial/trailing silence removal [Ravi Kumar Alamanda]
2014-01-26 | ASoC: msm: Do not allow commands during gapless transition. [Krishnankutty Kolathappilly]
2014-01-26 | ASoC: msm: Disable gapless offload playback by default [Krishnankutty Kolathappilly]
2014-01-26 | ASoC: msm: change to enable audio [Haynes Mathew George]
2014-01-26 | ASoC: msm: Add support to enable audio post processing in DSP [Subhash Chandra Bose Naripeddy]
2014-01-26 | ASoC: msm: Add support for RTAC version 1.1 [Ben Romberger]
2014-01-26 | ASoC: msm: Add support for gapless audio playback [Ravi Kumar Alamanda]
2014-01-26 | ASoC: msm: Add support for ASM loopback [Damir Didjusto]
2014-01-26 | ASoC: msm: Add playback support for AC3/EC3 in compress driver [Mingming Yin]
2014-01-26 | ASoC: Compress: Check and set pcm_new driver op [Ravi Kumar Alamanda]
2014-01-26 | ALSA: pcm: check for integer overflow during multiplication [Phani Kumar Uppalapati]
2014-01-26 | ALSA: core: Fix crash by avoiding appl_ptr crossing 32-bit boundary [Laxminath Kasam]
2014-01-26 | ALSA: compress: Memset timestamp structure to zero. [Krishnankutty Kolathappilly]
2014-01-26 | [2/2] Settings: Slims Hardware Key Rebinding [jyates]
2014-01-26 | [2/2] Settings: Make menu unlock configurable [jyates]
2014-01-26 | [2/2] settings: Add support for ADB over network [maxwen]
2014-01-26 | [1/2] Slims Hardware Key Rebinding [jyates]
2014-01-26 | [1/2] FB: Make menu unlock configurable [jyates]
2014-01-26 | [1/2] base: Add support for ADB over network [maxwen]
2014-01-25 | Return: Custom Carrier Label [1/2] [Muhammed Nazim]
2014-01-25 | build: use the system's ccache by default [Anthony King]
2014-01-25 | apps/Settings: translation - RU [gwindlord]
2014-01-25 | Add CPU & RAM info. [Muhammed Nazim]
2014-01-24 | policy_hal: remove unused function isVirtualInputDevice [Mingming Yin]
2014-01-24 | policy_hal: Fix to route the call to proper device [Helen Zeng]
2014-01-24 | mpq8092: Porting audio HAL changes [Dhananjay Kumar]
2014-01-24 | Mms: CS Translation - taken original slim_strings and translated [Keany]
2014-01-26 | Settings: add better dialog handling for adb over network (HEAD, m/kk4.4-caf, github/kk4.4) [Lars Greiss]
2014-01-24 | hal: remove assertion for unsupported sound card [Mingming Yin]
2014-01-24 | hal: Fix voice call with QUAD MIC [Vidyakumar Athota]
2014-01-24 | hal: Fix slowtalk key value type [Vidyakumar Athota]
2014-01-24 | hal: fix set_parameter() returning -2 error [Shiv Maliyappanahalli]
2014-01-24 | hal: fix incorrectly updated copyrights for source files [Shiv Maliyappanahalli]
2014-01-24 | hal: Disable gapless offload playback by default. [Krishnankutty Kolathappilly]
2014-01-24 |   hal: Correct pcm device ID for QCHAT session [Venkata Narendra Kumar Gutta]
2014-01-24 | hal: Add support for Volume Boost [Ben Romberger]
2014-01-24 | hal: Add property to configure the compress offload fragment size. [Krishnankutty Kolathappilly]
2014-01-24 | hal: Add audio support for 8092 [Aviral Gupta]
2014-01-24 | Fix custom platform abstraciton after merge [dhacker29]
2014-01-24 | d2-common: add hardware softkey to overlay [nicklovell23]
2014-01-24 | Avoid to create duplicate filename for misc devices. [singhome_lee]
2014-01-24 | audio: Re-arrange member var initializations [Haynes Mathew George]
2014-01-24 | audio: msm8660: Use msm_ion header [Steve Kondik]
2014-01-24 | audio: mpq: Add WMA, PCM and MP2 format for tunnel decode [Dhananjay Kumar]
2014-01-24 | audio: Add support for 8974 Voice2 [Vicky Sehrawat]
2014-01-24 | apps/Settings: translation - RU [gwindlord]
2014-01-23 | vendor: remove e610 support [Anthony King]
2014-01-23 | Prima 3.2.7.27 [Dave Daynard]
2014-01-23 | Make VZW volume for CONFIG_MACH_M2 only [Dave Daynard]
2014-01-23 | m7-common: Update media libraries [Ethan Chen]
2014-01-18 | Update gps for ls980 and vs980 (HEAD, m/kk4.4-caf, github/kk4.4) [arcardinal]
2014-01-26 | welcome RC1 (HEAD, m/kk4.4-caf, github/kk4.4) [Lars Greiss]
2014-01-23 | m7-common: correctly sort libCB [Ethan Chen]
2014-01-23 | jf-common: add hardware softkey to overlay [Brian Hall]
2014-01-23 | hwc: Update rotator object handling in error cases [Saurabh Shah]
2014-01-23 | hwc: Reset layer-to-rotator map and fences on configuration failure [Saurabh Shah]2014-01-20 | Revert "synaptics: remove logo2menu, sweep2wake, etc" (HEAD, m/kk4.4-caf, github/kk4.4) [Nicholas Flintham]
2014-01-23 | hwc: mdpcomp: Make all pipes available if a frame fails [Saurabh Shah]
2014-01-23 | hal: set gapless metadata for compress  offload playback [Krishnankutty Kolathappilly]
2014-01-23 | hwc: remove displaying unused pipe in dump if set overlay fails (HEAD, m/kk4.4-caf, github/kk4.4) [Baldev Sahu]
2014-01-23 | hal: pass set parameters call to listen hal [Kiran Kandi]
2014-01-23 | hal: fix for surround sound recording [Mingming Yin]
2014-01-23 | hal: Detect sound card dynamically [Apoorv Raghuvanshi]
2014-01-23 | hal: Avoid duplicate primary outputs [Haynes Mathew George]
2014-01-23 | audio: hal: Fix to use correct EC_REF_RX [Laxminath Kasam]
2014-01-23 | apexq/express: Fix USB disconnect not detected on CDP port [Dave Daynard]
2014-01-22 | Settings: CS translation [Keany]
2014-01-22 | Return: Custom Carrier Label [2/2] [Muhammed Nazim]
2014-01-22 | d2: re-enable bluetooth lpm [Dan Pasanen]
2014-01-22 | d2-common: fix up modem links [Dave Daynard]
2014-01-21 | Settings: ES translations [Carlos Solano]
2014-01-21 | Reintroduce hardware key overlay [Nicholas Flintham]
2014-01-21 | InCallUI: Fix build error [Pawit Pornkitprasan]2014-01-24 | Mms: reload default drawable if it changed during the instance [Lars Greiss]
2014-01-21 | DashClock: some TRDS adjustments [Lars Greiss]
2014-01-21 | DashClock: make actionbar consisten with KitKat theme and fix [Lars Greiss]
2014-01-21 | DashClock: disable backgroundcolor preference if opacity = 0 [Lars Greiss]
2014-01-21 | DashClock: add src api paths back [Lars Greiss]
2014-01-21 | DashClock: add preference theme to NextAlarmSettingsActivity [Lars Greiss]
2014-01-21 | DashClock: add background color choice + add more colors for text then just white & black [Lars Greiss]
2014-01-21 | d2: use commonized defconfig [Dan Pasanen]
2014-01-21 | cpufreq: ondemand: fix timer-related list corruption in store_powersave_bias() [Osvaldo Banuelos]
2014-01-21 | cpufreq: Fix policy getting stuck when user & kernel min/max don't overlap [Saravana Kannan]
2014-01-20 | Update regulatory change to all virtual interface for the phy [Vinay Krishna Eranna]
2014-01-20 | Update build all branches script [ktoonsez]
2014-01-20 | subsystem: Add extra checks to make sure subsys_domain and iommu_domain are NOT NULL [ktoonsez]
2014-01-20 | Stop charging from obeying Fade mode [ktoonsez]
2014-01-20 | Settings: fix Display settings FC on manta or devices without crt mode effect [Lars Greiss]
2014-01-20 | set default cdma subscription to RUIM [nicklovell23]
2014-01-26 | Add back Hardware Key overlay (HEAD, m/kk4.4-caf, github/kk4.4) [Muhammed Nazim]
2014-01-21 | defconfig is now commnized in d2-common (HEAD, m/kk4.4-caf, github/kk4.4) [Dan Pasanen]
2014-01-20 | scm: Rewrite scm_call funcs and ML4 merges [ktoonsez]
2014-01-20 | Rotator getting stuck leading to fence timeout [Justin Philip]
2014-01-20 | Revert "defconfig: disable msm-dcvs governor from CM for KT" [ktoonsez]
2014-01-20 | Remove over-riding config items [ktoonsez]
2014-01-20 | perf_event_msm_krait_l2 sync with ML4 [ktoonsez]
2014-01-20 | P2P: Use negotiated channel from invitation for persistent GO [Vinay Krishna Eranna]
2014-01-20 | P2P: Use group formation timeout on persistent group GO [Jouni Malinen]
2014-01-20 | P2P: Short scan wait to speed up the group re-invocation [Rashmi Ramanna]
2014-01-20 | P2P: Avoid frequency conflict due to blocking of lower 5GHz channels [Vinay Krishna Eranna]
2014-01-20 | msm: msm_bus: More checks to insure pdata and bus driver vars are not in error and NO NULL [ktoonsez]
2014-01-20 | msm: Kconfig: Fix the defconfig warnings for 8974 [Subbaraman Narayanamurthy]
2014-01-20 | msm:camera: Disable/enable VFE write masters properly during overflow [Alok Kediya]
2014-01-20 | Move kernel to new home [Muhammed Nazim]
2014-01-26 | jf-common: correct overlay for menu unlock (HEAD, m/kk4.4-caf, github/kk4.4) [jyates]
2014-01-20 | m7-common: Add CPU input boost settings [Ethan Chen]
2014-01-26 | g2: add optimization (HEAD, m/kk4.4-caf, github/kk4.4) [houst0nn]
2014-01-20 | Linux 3.4.77 [ktoonsez]
2014-01-20 | Linux 3.4.76 [ktoonsez]
2014-01-20 | libm: sync with upstream freebsd (HEAD, m/kk4.4-caf, github/kk4.4) [synergydev]
2014-01-20 | LEDs: Add bit shift option to give more control on led slope operation.  Also changed dutymax to 30 and dutymid to 15 to create a more even slope on slope up and slope down. [ktoonsez]
2014-01-20 | LED control from kernel: started with vladnosferatu and invano implementation + control over on and off length and step1, 2, 3, 4 control [ktoonsez]
2014-01-20 | ktoonservativeq: Remove unnecessary call to set_music_playing_statekt() while setting disable_hotplugging_media parameter [ktoonsez]
2014-01-20 | ktoonservativeq: Fix locking of disable_hotplugging_media_override variable in true state [ktoonsez]
2014-01-20 | ktoonservativeq: Add disable hotplugging setting while playing media [ktoonsez]
2014-01-20 | Keyguard: do not show maximized on simpin and several fixes [Lars Greiss]
2014-01-20 | jf: bcmdhd: filter multicast during sleep [abmantis]
2014-01-20 | Interworking: Report STATUS:sp_type even if domain is not configured [Jouni Malinen]
2014-01-20 | Interworking: Reject BSS based on disallow_aps [Jouni Malinen]
2014-01-20 | Interworking: Do not reconnect if already connected [Jouni Malinen]
2014-01-20 | Interworking: Avoid duplicated network blocks [Jouni Malinen]
2014-01-20 | Interworking: Add support for multiple home FQDNs [Jouni Malinen]
2014-01-20 | Include Extended Capabilities element based on scan results [Arif Hussain]
2014-01-20 | hostapd: Wait for channel list update after country code change [Jouni Malinen]
2014-01-20 | hostapd: Filter channel list updated events after country code change [Abhishek Singh]
2014-01-20 | grp3d_low_vectors: Bump MBPS to 1700 for low vectors [ktoonsez]
2014-01-20 | gfx3d_fs_data: Change reset_rate 27000000 from 1800000.  Remove 1800000 from clk_tbl_gfx3d.  Increase log length for msm_rpm [ktoonsez]
2014-01-20 | frameworks: translation - RU [gwindlord]
2014-01-20 | Fix up Linux 3.4.77 merge error [ktoonsez]
2014-01-20 | Fixed touch feedback, broken in an earlier commit Fixed clock metrics for tablets [Antonio Mendes Silva]
2014-01-20 | diag: Reduce error message frequency [Katish Paran]
2014-01-20 | defconfig: disable msm-dcvs governor from CM for KT [ktoonsez]
2014-01-20 | defconfig: disable msm-dcvs governor [Alexander Martinz]
2014-01-20 | dcvs: Set msm_dcvs_enabled = 0 when msm_dcvs_scm_init() fails adn be sure to return early when msm_dcvs_enabled == 0 [ktoonsez]
2014-01-20 | d2: fix continuous auto focus [Dave Daynard]
2014-01-20 | d2-common: update init [Dave Daynard]
2014-01-20 | d2-common: enable background scan [Dave Daynard]
2014-01-20 | d2-common: dex-opt to cache [Dave Daynard]
2014-01-20 | cpufreq: Some general re-write to make freq changes smoother and more efficient [ktoonsez]
2014-01-19 | Browser: Fix browser force close (HEAD, m/kk4.4-caf, github/kk4.4) [adhiti]
2014-01-21 | DashClock: Fix menu overflow button on dslv [Lars Greiss]
2014-01-20 | cpufreq: ondemand:kernel NULL pointer dereference at dbs_check_cpu [Swetha Chikkaboraiah]
2014-01-20 | cpufreq: ondemand:Fix NULL check for dbs_info->cur_policy [Swetha Chikkaboraiah]
2014-01-26 | Linux 3.4.77 (HEAD, m/kk4.4-caf, github/kk4.4) [houst0nn]
2014-01-20 | cpufreq: ondemand: Fix locking in store_powersave_bias [Matt Wagantall]
2014-01-20 | cpufreq: ktoonservativeq: Added super_conservative tunable, 1 = enabled, 0 means disabled.  This item will be used to keep the CPU and hotplugging waaaaaay down saving a good amount of battery [ktoonsez]
2014-01-20 | apps/DashClock: translation - RU [gwindlord]
2014-01-20 | apexqtmo: set default governor to interactive [Dave Daynard]
2014-01-20 | Android: Implement SETBAND for scan requests [Jouni Malinen]
2014-01-26 | Telephony: Modify code to check that PUK code length is always 8. (HEAD, m/kk4.4-caf, github/kk4.4-caf) [Rakesh Pallerla]
2014-01-20 | Add min/max Mhz option and disable hotplug for ktoonservativeq while you are charging on Wireless Charger [ktoonsez]
2014-01-20 | Added text density option [Antonio Mendes Silva]
2014-01-20 | Added separator between extensions [Antonio Mendes Silva]
2014-01-20 | Added condensed font option [Antonio Mendes Silva]
2014-01-24 | Dialer: CS translation (HEAD, m/kk4.4-caf, github/kk4.4) [Keany]
2014-01-19 | apps/Gallery2: translation - RU (HEAD, m/kk4.4-caf, github/kk4.4) [gwindlord]
2014-01-20 | Add dynamic fsync to see if it gains anything, so far not much at all [ktoonsez]
2014-01-20 | Add dev version of verizon. [ktoonsez]
2014-01-20 | Add an assload of tcp congestion controllers [ktoonsez]
2014-01-20 | acpuclock-8960ab; Update from ML4 [ktoonsez]
2014-01-19 | Updated Settings Hun Translations [klasszsrac]
2014-01-19 | timerfd: support CLOCK_BOOTTIME clock [Greg Hackmann]
2014-01-19 | timerfd: add alarm timers [Todd Poynor]
2014-01-19 | Sync libnfc-brcm.conf with latest release 4.4 release [Florent Guichard]
2014-01-19 | Squash revert of two mmc commits [Evan McClain]
2014-01-19 | Settings: fix permission screen does not come up [Lars Greiss]
2014-01-19 | Settings: Favorite Contact Tile (2/2) [Jubakuba]
2014-01-19 | Revert "Revert "msm: msm_fb: Do not use ION_IOMMU_UNMAP_DELAYED flag."" [Dave Daynard]
2014-01-19 | Revert "HACK: time: Disable alarmtimer" [Dave Daynard]
2014-01-19 | Revert "d2: add support for variant defconfigs" [Dan Pasanen]
2014-01-19 | Revert "ApexQ: cap at 1458 MHZ" [Dave Daynard]
2014-01-19 | Return: Smart Pulldown [2/2] [Muhammed Nazim]
2014-01-19 | Return: Smart Pulldown [1/2] [Muhammed Nazim]
2014-01-19 | Return: Expandable Volume Overlay [Muhammed Nazim]
2014-01-19 | Return: Always show battery on Keyguard [2/2] [Muhammed Nazim]
2014-01-19 | Return: Always show battery on Keyguard [1/2] [Muhammed Nazim]
2014-01-19 | remove p51xx devices [cordell]
2014-01-19 | Remove harmful attempts to be helpful in pthread_mutex functions. [Elliott Hughes]
2014-01-19 | Re-enable earlysuspend for MDP driver [Steve Kondik]
2014-01-19 | QuickSettings : Quick Collapse [2/2] [Muhammed Nazim]
2014-01-19 | QuickSettings : Quick Collapse [1/2] [Muhammed Nazim]
Dieses "super_conservative" sollte man direkt mal ausprobieren. :D
Reaktionen: adl und Steveria
Es ist und bleibt RC (Release Candidate) 1 ... nicht Final, nicht Stable, nichts sonstiges ...
Aber es ist die "RC 1 von SlimKat mit der Versionsnummer Weekly 2.5", nicht die "RC 1 der Weekly 2.5".
Welcher Kernel ist denn diesmal mit dabei?
Frage nur weil ich die KT Tweak App von KT Kernel nicht in dem App Ordner finde.
Immer noch KT, so weit ich sehe.
Kann man ohne Probleme den alucard flashen
Ja, warum nicht?
Finde sie hätten ja mal die neuste Version inkl app vom KT verbauen können!die neue Version hat nämlich keine bugs und error Meldungen mehr in der app!
Kann man ja problemlos selber flashen, macht nicht viel Arbeit. Wobei ich keine Probleme hatte mit der App
Nach einigen Stunden intensiven Testens der super_conservative-Einstellung: Ingress laggt :D, Nova immer noch flüssig, deutliche Akkuersparnis nicht feststellbar. Aber vielleicht kommt das noch.
Hallo, ich hatte die Rom geflasht lief alles sehr gut , nur hatte ich keine Internetanzeige neben dem Batteriesymbol. Ich hatte aber eine Internet verbindung. Vielleicht kann mir jemand helfen, was ich machen müsste das ich eine Anzeige habe.:confused2:
Internetanzeige? Mobiles Netz oder WLAN?
@ Rosa Elefant
Es fehlt die Anzeige für mobiles Netz
Fifaheld
postmaster
Fifaheld
Fifaheld
Fifaheld
Fifaheld
Darks
Darks
