[ROM][I9505][4.4.4] *29.12.14* Slim Kat 9 [FINAL]
  • 2.353 Antworten
Juhu, eine neue Woche!
("Weekly" beta 1.5.)
2013-12-11 | settings: google please cleanup your translations....Settings cleanup [Lars Greiss]
2013-12-11 | settings: allow to disable quicksettings [Lars Greiss]
2013-12-11 | settings: add and pimp several help/reset dialogs [Lars Greiss]
2013-12-11 | QS: music tile update on Uri change [Lars Greiss]
2013-12-11 | Keyguard: google please cleanup your translations....Keyguard cleanup [Lars Greiss]
2013-12-11 | fb: remove WifiDisplayTile [Lars Greiss]
2013-12-11 | fb: google please cleanup your translations.....systemUI cleanup [Lars Greiss]
2013-12-11 | fb: google please cleanup your translations....fb cleanup [Lars Greiss]
2013-12-11 | fb: allow to recreate statusbar, navbar and notification drawer [Lars Greiss]
2013-12-11 | fb: allow to disable quicksettings [Lars Greiss]
2013-12-10 | settings: refactor QuietHours code [Lars Greiss]
2013-12-10 | Rework thumbnail handling [fun]
2013-12-10 | Quiet Hours Ringer (3/3) [Jubakuba]
2013-12-10 | MiniThumbFile: Fix image/bitmap retrieval [Ricardo Cerqueira]
2013-12-10 | m7-common: remove GPU params [Ethan Chen]
2013-12-10 | m7-common: camera: clean up code style [Ethan Chen]
2013-12-10 | libqdutils::Replace USE_MDP3 with getMDPVersion() method. [Ramakant Singh]
2013-12-10 | libcopybit: Add missing return statement [RonGokhale]
2013-12-10 | hardware/qcom/media: Fix for AACEncoder CTS test failure [Shashi Kumar]
2013-12-10 | hardware/qcom/media: Add AC3/EAC3 support [Chaithanya Krishna Bacharaju]
2013-12-10 | display: fix display hal building for 7x27a under aosp [RonGokhale]
2013-12-10 | display: bring back support for mr0 adreno blobs [RonGokhale]
2013-12-10 | common: if we are building genlock, then the genlock headers need to be included [cybojenix]
2013-12-10 | Call to equals() comparing different types (FindBugs) [László Dávid]
2013-12-10 | Add p700 to vendorsetup [Tudor Sirb]
2013-12-09 | update for camera hal blob [Dan Pasanen]
2013-12-09 | SystemUI: fix wrong statusbar background. [Kyrylo Mikos]
2013-12-09 | Satisfy my OCD - reformat [Nicholas Flintham]
2013-12-09 | Revert "ueventd: Add bootdevice symlink" [Nicholas Flintham]
2013-12-09 | Revert "init: Add vendor-specific initialization hooks" [Nicholas Flintham]
2013-12-09 | Re-order Board Flags [Nicholas Flintham]
2013-12-09 | Quiet Hours Ringer (2/3) [Jubakuba]
2013-12-09 | Quiet Hours Ringer (1/3) [Lars Greiss]
2013-12-09 | Provide permission for graphics to set service.bootanim.exit prop [Giulio Cervera]
2013-12-09 | init: Set the "ro.boot.emmc" property [Steve Kondik]
2013-12-09 | init: Fix some more mergefails [Ricardo Cerqueira]
2013-12-09 | init: Fix serial number display for semc msm7x30 devices [Michael Bestas]
2013-12-09 | init: Do not build logo.c when initlogo is disabled [Marcin Chojnacki]
2013-12-09 | init: define BOARD_CHARGING_CMDLINE parameters [Ethan Chen]
2013-12-09 | init: Check for symlinks with lstat() not open() [Andrew Dodd]
2013-12-09 | init: Bring back support for arbitrary chargermode cmdlines [Ricardo Cerqueira]
2013-12-09 | Init: Allow building of init that is compatible with second init boot [dhacker29]
2013-12-09 | init: Allow basic environment variable expansion in env assignment [David Ng]
2013-12-09 | init: Add option to disable the initlogo [Steve Kondik]
2013-12-09 | init: Add "export_rc" command to export env from a specified file [David Ng]
2013-12-09 | init: add detection of charging mode [Prashant Somashekar]
2013-12-09 | init: Add an emmc-specific configuration file [Steve Kondik]
2013-12-09 | framework: fix screenshot and rotation animation for devices with abnormal hw rotation [Tom Giordano]
2013-12-09 | fb: slightly adjust navigationring background drawable size [Lars Greiss]
2013-12-09 | fb: refactor QuietHours code [Lars Greiss]
2013-12-09 | fb: navigationbar use always slimactions and add contentdescription [Lars Greiss]
2013-12-09 | fb: fix possible NPE on back button transition [Lars Greiss]
2013-12-09 | Create a new location for /data policy files [William Roberts]
2013-12-09 | Change setsebool syntax to be consistent with other init built-ins. [Stephen Smalley]
2013-12-09 | Allow a device to define the max number of service groups in init.h [dhacker29]
2013-12-09 | Add support for socket security context specification. [Stephen Smalley]
2013-12-09 | Add support for -R (recurse) to init chown builtin. [Stephen Smalley]
2013-12-09 | Add persist.mac_enforcing_mode property [Bob Craig]
2013-12-08 | video: kyro: fix incorrect sizes when copying to userspace [Sasha Levin]
2013-12-08 | Sprint MWI Quirk: Show message wait indicator notifications [Ricardo Cerqueira]
2013-12-08 | Slim : Disable some overlays we don't support yet [Nicholas Flintham]
2013-12-08 | Settings: Remove Setting From Tablets [Jubakuba]
2013-12-08 | Settings: Display Rotation (All Devices) [Jubakuba]
2013-12-08 | Revert "Harden against transiently unavailable backup transports" [Lars Greiss]
2013-12-08 | Revert "Handle backup transport registration dynamically" [Lars Greiss]
2013-12-08 | Revert "base: App crash when select suggestion's length more than specified." [Lars Greiss]
2013-12-08 | random32: fix off-by-one in seeding requirement [Daniel Borkmann]
2013-12-08 | push to 1.4 [Lars Greiss]
2013-12-08 | push to 1.3 [Lars Greiss]
2013-12-08 | Port network mode toggle from CM10 [Pawit Pornkitprasan]
2013-12-08 | {pktgen, xfrm} Update IPv4 header total len and checksum after tranformation [fan.du]
2013-12-08 | Phone: Sprint MWI Quirk: Phantom message wait indicator workaround [nullghost]
2013-12-08 | packet: fix use after free race in send path when dev is released [Daniel Borkmann]
2013-12-08 | overlay: use overlays based on mcc and mnc. [jared caliendo]
2013-12-08 | overlays mode to services_telephony [cordell]
2013-12-04 | Hello 4.4 (HEAD, m/kk4.4-caf, github/kk4.4) [cordell]
2013-12-09 | d2/jf re-enable cancel_auto_focus (HEAD, m/kk4.4-caf, github/kk4.4) [Dave Daynard]
2013-12-08 | nfsd: use "init_net" for portmapper [Stanislav Kinsbursky]
2013-12-08 | net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST [Shawn Landden]
2013-12-08 | net: rework recvmsg handler msg_name and msg_namelen logic [Hannes Frederic Sowa]
2013-12-08 | net: Fix "ip rule delete table 256" [Andreas Henriksson]
2013-12-08 | net: core: Always propagate flag changes to interfaces [Vlad Yasevich]
2013-12-08 | net: clamp ->msg_namelen instead of returning an error [Dan Carpenter]
2013-12-08 | net: add BUG_ON if kernel advertises msg_namelen > sizeof(struct sockaddr_storage) [Hannes Frederic Sowa]
2013-12-08 | mmc: block: fix a bug of error handling in MMC driver [KOBAYASHI Yo****ake]
2013-12-08 | Make ImageView drawable update more efficient in some cases. [Danny Baumann]
2013-12-08 | m7-common: verizon: enable mms content disposition field [David Hays]
2013-12-08 | m7-common: move Phone overlays to Telephony [Ethan Chen]
2013-12-08 | m7-common: clean up overlay [Ethan Chen]
2013-12-08 | jf: use flo adreno blobs [Dan Pasanen]
2013-12-08 | jf: moving camera wrapper to msm8960-common [Dan Pasanen]
2013-12-08 | isdnloop: use strlcpy() instead of strcpy() [Dan Carpenter]
2013-12-08 | ipv6: use rt6_get_dflt_router to get default router in rt6_route_rcv [Duan Jiong]
2013-12-08 | ipv6: fix possible seqlock deadlock in ip6_finish_output2 [Hannes Frederic Sowa]
2013-12-08 | ipv6: fix leaking uninitialized port number of offender sockaddr [Hannes Frederic Sowa]
2013-12-08 | ipv4: fix possible seqlock deadlock [Eric Dumazet]
2013-12-08 | iommu/vt-d: Fixed interaction of VFIO_IOMMU_MAP_DMA with IOMMU address limits [Julian Stecklina]
2013-12-08 | inet: prevent leakage of uninitialized memory to user in recv syscalls [Hannes Frederic Sowa]
2013-12-08 | inet: fix possible seqlock deadlocks [Eric Dumazet]
2013-12-08 | inet: fix addr_len/msg->msg_namelen assignment in recv_error and rxpmtu functions [Hannes Frederic Sowa]
2013-12-08 | hwc: remove unblanking fb from openframebufferdevice [Baldev Sahu]
2013-12-08 | hwc: Add support for Secure display [Ramkumar Radhakrishnan]
2013-12-08 | HID: picolcd_core: validate output report details [Kees Cook]
2013-12-08 | Fix 'vibrate outgoing' behaviour. [Danny Baumann]
2013-12-08 | Fix SSN option being shown twice. [Danny Baumann]
2013-12-08 | Fix notification cutoff at slim dpi [Muhammed Nazim]
2013-12-08 | Fix build for Aries There is no need for a ifeq for herring here. It was necessary ifneq to exclude it, but now since it has s5pc110 flag that is enough. [Josue Rivera]
2013-12-06 | cpufreq: Add a sync limit to cpu-boost (HEAD, m/kk4.4-caf, github/kk4.4) [Rohit Gupta]
2013-12-08 | Fix a bootloop problem when /data/system/usagestats/usage-history.xml is empty. This often occurs after an incomplete reboot/shutdown or battery pull. [oubeichen]
2013-12-08 | elevator: acquire q->sysfs_lock in elevator_change() [Tomoki Sekiyama]
2013-12-08 | dm: fix truncated status strings [Mikulas Patocka]
2013-12-08 | dashplayer: Reject https dash urls [Surajit Podder]
2013-12-08 | Make the error for touch boost as a debug flag. Needed to shut up the logspam whenever not using a stock hotplug driver (HEAD, m/kk4.4-caf, github/kk4.4) [Josue Rivera]
2013-12-08 | macloader: Add another murata MAC [Andrew Dodd]
2013-12-08 | d2/jf: vendor-ize the camera blob [Dan Pasanen]
2013-12-08 | connector: improved unaligned access error fix [Chris Metcalf]
2013-12-08 | Cleanup: get rid of getCurrentCall() method. [Danny Baumann]
2013-12-08 | bridge: flush br's address entry in fdb when remove the bridge dev [Ding Tianhong]
2013-12-08 | bonding: fix two race conditions in bond_store_updelay/downdelay [Nikolay Aleksandrov]
2013-12-08 | bonding: don't permit to use ARP monitoring in 802.3ad mode [Veaceslav Falico]
2013-12-08 | blk-core: Fix memory corruption if blkcg_init_queue fails [Mikulas Patocka]
2013-12-08 | atm: idt77252: fix dev refcnt leak [Ying Xue]
2013-12-08 | af_packet: block BH in prb_shutdown_retire_blk_timer() [Veaceslav Falico]
2013-12-08 | add correct manifest branch [Lars Greiss]
2013-12-08 | 6lowpan: Uncompression of traffic class field was incorrect [Jukka Rissanen]
Laut XDA noch Probleme beim Reboot vorhanden, könnte aber an AOSP liegen.
Reaktionen: tobiasth
+ neue Gapps!
Reaktionen: Rosa Elefant
Wo isn der Unterschied zwischen AIO und minimal?
Ah, nun, es ist ein ungefährer Anhaltspunkt. Das meiste ist Bloatware. Danke.
Hui, ist ja schon 4.4.2 :D
Build 1.6 online! ;)
Seid dem Update bekomme ich kein Netz mehr !
Hab ihr auch das Problem ?
nope, funktioniert alles prima ...
mit CWM 6.0.4.4 geflasht, alter bootloader ...
von was auf was hast du ein update gemacht?
welche cwm verwendest du?
welches modem hast du aktuell oben?
Kann (sollte) man von Android 4.2.2 TW auf die Nightly wechseln, oder braucht man ein neueres Modem?
TW ist TW ... das ist halt so eine Einstellungsfrage ;)
Es sind halt ein paar Samsungfunktionen nicht vorhanden unter AOSP, das sollte jedem klar sein.
Das mit dem Modem kann ich dir nicht ganz genau sagen, es gibt viele die meinen man braucht für 4.3 mindestens ein 4.3 Modem, also alles neuer MJ* (glaub ich) ... aber bei mir geht auch das MI8 wunderbar. Derzeit hab ich das MKF oben.
Guten Morgen,
gibt es noch keine GApps Für die 1.6 ???
die für 1.5 sind die aktuellen ....
aber die sind ja für 4.4.1. Die 1.6 ist aber 4.4.2.
Kann man die dann trotzdem nehmen???
ja ...
Alles klar. Danke für die schnelle Antwort.
tobiasth ich hab eine andere baseband laufen und zwar noch die I9505XXXUEMJ5.
Hab jetzt Netz aber ich werde trozdem mal deine Baseband drauf flashen.
Ich meinte die Frage eher technisch. Ich will die nicht funktionierenden Samsungfunktionen gar nicht haben. :flapper:
Dann lasse ich es mal so, wie's ist... MI8 ist "Auslieferungszustand"?
neee, MI8 ist irgendwas mittendrin, welches ganz gut war!
irgendwas mit MEA oder so ist "Auslieferungszustand" um den Dreh ... ;)
Der ursprüngliche Beitrag von 12:30 Uhr wurde um 12:33 Uhr ergänzt:
Ach so meinst du das ... wie gesagt, das ist unterschiedlich! Bei dem Einen gehts ohne Probleme, bei dem Anderen muss ein 4.3 Modem her, damit es läuft. Meist geht dann das WLAN oder Internet nicht. Ich hab es auch noch nicht durchschaut warum das so ist. Ich hatte bisher keinerlei Probleme.
Ich bin ja eher der Meinung das liegt an der verwendeten Recovery ;) daher einfach CWM 6.0.4.4 verwenden ..... :rolleyes2:
Der ursprüngliche Beitrag von 12:33 Uhr wurde um 12:34 Uhr ergänzt:
Ach ja .... Slim Kat Beta Build 1.6 läuft Spitze! :D
Hm, mal rumprobieren dann. :)
Fifaheld
postmaster
Fifaheld
Fifaheld
Fifaheld
Fifaheld
Darks
Darks
