[ROM][i9505][4.4.4]*27.06.14* Sonic Open Kang Project *EINGESTELLT*
  • 60 Antworten
beicuxhaven
beicuxhaven
Ehrenmitglied
10.437
picture.php
SOKP ist hauptsächlich für User gedacht, die viel Wert auf Multitaskin, Speed, Audio und Videoqualität und dabei ein Maximum an Einstellungsmöglichkeiten / Theming wollen. Das alles mit Bordmitteln. Das Ganze kommt mit
Real True-HD DTS Sound, brilliantem HD Display und Optimierungen für Video & Images daher...
Das lässt die ROM auf 245 MB anwachsen..
Cyanogen Mod 11.00 Based.
Option to Hide Notification Lables
Notification Transparency
Contextual Notification Panel Header
Notification Power Widgets with changeable background and icon colors
Tiles layout customization with quick pull-down,smart pull down,quick collapse.,background and icon color options
Status Bar Customizations like Battery icon,Clock and Date,Status Bar colors
Network Traffic Meter
Signal Text Color,Hide Signal Bar option
Custom Carrier Lable
Double Tap to sleep Option
Breathing Sms Notification
Breathing missed cal notifications
Breathing voice-mail Notification
Customizable Low battery warning
Limit the notification sound of each application
Screen on Notification Light(enable/disable)
Custom System Animations
CRT Animation
List view Animation
Toast Animation
IME Animations
Multiuser Support in lock-screen security
screen lock options
Lock screen themes for rings and elements
Customizable Slider Targets and Shortcuts with Eight slider Targets
Lock Screen widgets with maximize and minimization option
Phone encryption
Lock Screen Notification Access control
Lock Screen Notifications
Customizable Lock Screen Icons
Lock-screen Power menu
Transparent & Blur Lock-screen
Lock Icon Torch
Halo floating Notifications
Customizable Power menu with lots of options
Advanced Display control Configure your screen colors
Chameleon OS Active Display
Gesture Navigations
Chameleon OS Gesture Every where
Customizable Navigation bar with Navigation Rings'
Custom Progress bar make your own color full progress bar
Slim PIE control
Chameleon OS Identicons
Recent View customization can chose stock or Slim recent view with memory indicators,clear all button
Customizable recent panel color
Build Prop mods enable disable option menu
INIT.D mods enable disable option menu
System Application remover
LCD Density Changer
Wake lock Blocker
Suspend Action When screen goes off
Scrolling Animations
Disable full-screen keyboard option
Recent ram Bar with customizations
Media Scanner Behavior Controller
Option To Disable FC Notifications
Default App grip option
Dual Pane options
Do not disturb option
Show notification count
Kil app back button with customizable timeout values
High end graphic effects option
Dark SOKP UI
App Permission Options
Advanced Kernel Tweaker Instead of Performance control with lot option to control CPU & GPU
GPS Location Fix
Build Prop Editor
Seeder Entropy Generator
X-Posed Framework
Per Application DPI
HyBrid UI>>>Phablet And Phone UI
Omni Duel Split Screen
Unlimited Floating Multi window
Network Connection Manager
Status Bar Battery Bar
Status Bar Brightness slider
Cast Screen
Screen Recorder with Audio option
Adoptive Back light
Privacy Guard
Sony Xperia Z2 application like Sketch (Pen Supported),Tasks,Converter ,Car launcher.
option to use a fully themable MMS packages. You can access from mms - settings - theme settings
Superuser fully embedded into the build and accessed from settings menu
Enable/disable wake up on charge option
insane amount of edits/tweaks/fixes to make this ROM absolutely fly
option to disable/enable vibrate on expand for notifications alerts
Numerous other options hiding throughout the Rom......will updated when i remember more
X-Reality Engine Personally Ported from Xperia Z2 To En-chase True HD Display
Pure HD Theater Mode Video Rendering Enabled with High end graphic effects option
Latest Sony Walkman Player From Xperia Z2 With Clear Audio+
Latest Sony Movies & Album From Xperia Z2
Digital Dolby Ported From HWAUIE ACSEND P6 k3v2oem1
Unique DTS HD Audio System Designed By Me For True HD Sound.......Feel Your Ears Blessed.
Audio FX Widget As Standalone Equalizer For Music ,Video,Gaming Sound.
RECOVERY TWRP: Wipe Cache / Factory Reset
Install ROM
Install Gapps
Wipe Cache Partition
Wipe Dalvik Cache
Reboot
XDA Thread
Reaktionen: Mo Jito, pill, abemann und 5 andere
Okay, passe die Farbe an...Moment bitte
Der ursprüngliche Beitrag von 14:31 Uhr wurde um 14:32 Uhr ergänzt:
Erledigt..
Reaktionen: tobiasth
Jetzt noch das schwarze aus den Download Links rausnehmen, dann passt es :)
Reaktionen: beicuxhaven
Wäre ja mal ein Test wert, wenn die Download Links Funktionieren würden!
So ihr lieben. Ich hoffe nun ist es korrekt.
Reaktionen: sventehf und tobiasth
Download link geht noch nicht :-(
Der in der Mitte ging. Egal, jetzt funzt es.
Reaktionen: abemann
und wie ist das Rom? hats wer getestet?
Ich finde die Rom echt gut, super viele Einstellungen. Der Akkuverbrauch niedrig. (1%/Std über Nacht) Und ich habe noch keine fehler gefunden.
Ich kann mich nicht in der normalen E-Mail App nicht anmelden. Daten habe ich schon gelöscht. App per TB deinstalliert und neu installiert. Aber immer noch das Problem. Hat das sonst wer? Oder jemand ne Lösung für mich?
Gesendet von meinem GT-I9505 mit der Android-Hilfe.de App
Ich habe die seit ein paar Tagen laufen. Soweit ist alles in Ordnung, außer:
1.) Nach Umstellen der Recent Apps-Übersicht auf die Slim Version kann ich nicht mehr auf die normale zurück. System UI bringt beim aufrufen der Recents reproduzierbar FC.
Edit: Die Funktion "Show rambar memory in GB" sollte wohl lieber deaktiviert werden, dann klappt es auch mit der Recents Apps-Übersicht. ;-)
2.) Bearbeiten von Fotos über die Galerie sorgt für einen der Galerie-App.
3.) Swipen mit der Standard-Tastatur funktioniert nicht. Tipp: Stock-Xperia-Tastatur besorgen.
4.) Der Prozess Exchange-Dienste wird in unregelmäßigen Abständen per FC beendet.
Insgesamt ist der Akku-Verbrauch in Ordnung, kann aber m.E. nicht mit Stock-ROMs mithalten. Grundsätzlich sehr alltagstauglich mit vielen Funktionen, die selbst einer AOSP-Optik ein bisschen Pepp mit auf den Weg geben.
Der ursprüngliche Beitrag von 22:36 Uhr wurde um 22:39 Uhr ergänzt:
kriskros schrieb:
Ich kann mich nicht in der normalen E-Mail App nicht anmelden.... [/SIZE]
Was heißt, nicht anmelden? Schon einmal versucht die Einrichtung per Hand zu machen? Vielleicht ist dein TB-Backup fehlerhaft?
Versuchst du IMAP oder Exchange oder POP zu verwenden? Wann und wo tritt der Fehler auf? Fehlermeldung?
Ob das an der ROM liegt, kann ich nicht sagen. Ich habe die SlimKat drauf und kann es da auch nicht.
Email funktionert bei mir ohne Probleme
Grundsätzlich ist ja bekannt, dass Kitkat Probleme mit Exchange hat. Alle daraus resultierenden Fehler wären somit nicht ROM-spezifisch sondern ein Google-Problem.
gibt es fotos ? möchte gerne das theme sehen.. kann mich nicht entscheiden.. es gibt so viele themes, rom oder stockrom ist mir wurst :D das theme muss mir einfach gefallen!
wäre suuper net wenn jemand fotos hochladen könnte ...
und wenn es unintressant ist und wie stock aussieht dann einfach schlicht so sagen..
Bitte Kein Witze hier! ;) :D
Es ist Stock, mit der Möglichkeit auf ein Blacktheme umzustellen. Dabei werden dann schlicht und ergreifend alle dunkelgrauen Hintergründe schwarz. Der Rest bleibt wie gehabt. Gravitybox und allgemein das Xposed Framework sind ins System integriert - so kannst du dir deine Oberfläche einfach selbst basteln, wie sie dir am besten gefällt.
Reaktionen: BBF-Android und abemann
Ansonsten wirf mal einen Blick in den originalen Thread auf XDA. Dort findest du Bilder...
die Rom ist ja mal der Ober Hammer, Hammer genial mit Wahnsinn Bootanimation und Möglichkeiten.so macht cm mal wieder Spass! danke
Ist aber nicht besser als die Slim.
Fifaheld
postmaster
der_Kief
COB93
COB93
dj3d
Poppenspaeler
Poppenspaeler
