[ROM][i9505][4.4.4] *20.10.14* SlimSaberKat [unofficial SlimKat build] *eingestellt*
  • 150 Antworten
beicuxhaven
beicuxhaven
Ehrenmitglied
10.437
Unofficial build - SaberMod toolchain 4.8.4
Fast, smooth and stable
Also, SlimKat als Vorlage genommen, und und und
hier der Oritext, da ich das nicht übersetzen kann:
SlimSaberKat is build from SlimKat source with SaberMod 4.8.4 compiler and lots of build optimisations like O3, strict aliasing and many more to make the ROM even faster and smoother. If you want to see all optimization flags set for building this ROM, have a look a look at this commit, line 71-73.
Mittlerweile ist der Dev, aufgrund von Probleme durch die Nutzung des AluCard Kernel, wieder davon ab.
  • Built for speed using SaberMod 4.8.4 toolchain and build optimizations
  • Backup and restore script for Xposed binaries when doing an upgrade
  • Modified gps.conf, for faster GPS fix
  • Reverted "UNOFFICIAL Builds are for Developers and Testers!" commit to remove debug info and keep inline with official version
  • Added SlimSaberKat version to the "About phone"screen
  • Option to answer call with hardware HOME button
  • Changed default screen DPI to 420 (will only affect clean installs)
  • New bootanimation thanks to @DJDobermann
  • removed 5 second delay to open apps after pressing home button
  • SlimOTA working for SlimSaberKat, will work for every new release
  • mobile settings on main settings page
  • network stats to statusbar
  • status bar activity indicators for mobile data and wifi
  • Lockscreen notifications
  • AOKP custom system animations
  • Volume panel background color && transparency
  • Removed network stats activity arrows from status bar
  • Make double tap gesture configurable
  • Set transmission priority for a2dp media channel to high
Interesting links
slimroms.net - The official webpage where you find everything you need to know about SlimRoms.
Official S4 SlimKat thread
Alucard kernel thread
Alucard kernel settings thread
Offizieller SlimKat Kernel
XDA Thread
Contributors
kantjer
ROM OS Version: 4.4.x KitKat
ROM Kernel: Linux 3.4.x
Based On: SlimKat (AOSP)
Version Information
Status: Beta
Current Beta Version: 5.2 weekly
Beta Release Date: 2014-05-23
Created 2014-05-23
Last Updated 2014-05-24
Reaktionen: arjen robben, Janeo, andi2398 und eine weitere Person
Also wenn die Verlinkungen überhaupt stimmen, dann ist die neuste Version vom 19.05.2014 ?
Haben wir einen Changelog?
Nach einem FullWipe mit anschließender Installation der 5.4 incl. der GApps_minimal 5.4 gab es erst mal Probleme mit dem Nova-Launcher. Nachdem ich meine Nova-Settings importierte war angeblich kein Platz mehr auf dem (leeren) Startbildschirm. Erstmal egal.
Einige Kacheln im QS-Drawer ließen sich nicht umplatzieren (in der Konfiguration schon, im Ergebnis aber nicht). Auch kein akutes Problem.
Das NoGo war dann allerdings, daß der Akku von 60% auf 15% in der Nacht fiel, ohne jede Tätigkeit (normalerweise sind es unter SlimKat/Alu max. 0.5%/h). Da ich derzeit keine Zeit habe, den Problemen auf den Grund zu gehen, back to SlimKat.
Sehr witzig, dass es eigentlich eine Slim ist, war mir schon klar, mein Freund :cool2:
Mich hätte nur interessiert, was er, falls überhaupt, geändert hat. Ich muss nämlich sagen, ich stelle keinen Unterschied zur Slim fest. Weder Geschwindigkeit noch Smoothness etc...
Reaktionen: tobiasth
War ja irgendwie klar ... ;)
Reaktionen: beicuxhaven
Hallo!
Ich hab's gestern Nachmittag mal geflasht - so als "Vergleich" zum Originalen Slim Kat. Bisher bin ich davon eher begeistert - Akku-Verbrauch im Standby ist ein Traum ( was ich trotz mehrerer Versuche mit dem AluCard-Kernel nicht sagen konnte).
Mal sehen, ob sich das hier weiterentwickelt oder nur 'ne Eintagsfliege bleibt (was zumindest meiner Meinung nach recht schade wäre)!
Viele Grüße
Ja, also hier sind wir jetzt natürlich auch auf 5.6
SlimSaberKat 5.6 is ready for download.
SlimTeam also released gapps 5.6
Besides the official Slim updates this build also includes:
Kernel-Alucard-V2.6.7g For 4.4 AOSP
proper exFAT fix (thanks to @fusionjack for his commit's)
backup and restore script for Xposed binaries is included (works starting the next update you flash after flashing this)
Das ist also die ROM die JustArchi's o3 flags drinnen hat? Wollte ich mal ausprobieren, dachte nur ich müsste selbst eine ROM bauen dafür, was ich nicht kann :thumbsup:
Mal gucken, was SlimSaberKat mit dem Akku anstellt... (ich bin in Experimentierlaune.)
Bisher im Gegensatz zu SlimKat keine Hänger und kein Flackern.
dein Akku flackert? :D
Nee, der Bildschirm.
Bei mir flackert und hängt nichts.....
Bei mir unter SlimSaber auch nicht mehr... ;)
SlimKat :p
