[ROM][I9505][4.4.4] *12.06.2014* S4 Google Edition - Stable-R2
  • 1.226 Antworten
jamal2362
jamal2362
Working:
Alles Funktioniert!
Bugs:
Keine :thumbsup:
Screenshots:
Changelog:
Code:
 (12.06.2014) Stable-R1
•Kernel Update: 09.06.2014 Thanks @ktoonsez
•Kernel Update will fixed some bugs and IRDA.
•Replaced platform.xml with that from the Nexus 5 Stock ROM
-ROM Link: [url=http://forum.xda-developers.com/showthread.php?t=2622831][ROM] |4.4.4| |KTU84P| Nexus 5 Untouched Sto… | Google Nexus 5 | xda-developers[/url]
 (10.06.2014) Final-R3.1
•Changed some Files..
 (07.06.2014) Final-R3.0
•Re-edit Completly ROM
 (06.06.2014) Final-R2.5
•Fixed Updater-script
•Make Newer TWPR and Newer CWM Recovery fully Compatible
•Recovery wipe /format System automatic
 (05.06.2014) Final-R2.0
•Update to 4.4.3 from a clean System Dump
•Update Kernel to the Latest
•Update SuperSU to the Latest
-All is Working !!!
 (02.02.2014) Final-R1.2
•Removed Aroma Installer
•Set Ktoonsez kernel as default.... Voted User...
•Updater-script Updated
•Build.prop Updated
•Fixed Menu/Back unlock, when you on Lockscreen
-Thx to the user for find it
 (14.01.2014) Final-R1.1
•Aroma redesign by me
•Update Alucard Kernel to the Latest
•ROM Name edited ... too much "R" Release
-Reduce The R5 to R1.1 , next will R1.2 ,R1.3 etc....
 (12.01.2014) Final-R5
•Included Aroma Installer
•Update completly Updater-script
•Little Bug fixes
•You can Choose your Favorite Kernel on Aroma
- Alucard Kernel
- Ktoonsez Kernel
 (08.01.2014) Final-R4
•Ktoonsez Kernel Updated
•Update Updater-script
•Fixed false Rotated Pictures on Gallery
•Fixed Delete Pictures from ExtSD - Thanks @broodplank1337
 (05.01.2014) Final-R3
•Fixed Write/Read R/W
•Fixed Some /bin files
•Fixed Charging LED
•Delete FileManager - You can download your favorite on Play Store
•Delete KTweaker - You can flash the KTweaker zip on my Mods..
•ROM are Completly Stock
 (04.01.2014) Final-R2
•Fixed Dual-Boot support
•Fixed Toolbox in system/bin for Dual-Boot
•Cleaned completly Build.prop
 (02.01.2014) Final-R1
•Update Kernel to 3.4.75
•Some little Bugs fixes
•Fixed the buggy Bootanimation
•Install Apk's from ExtSD are Fixed
 (01.01.2014) Final
Happy New Year Special
•New Kernel: 3.4.72--KT-SGS4-KK4.4-TWGE-INTL-12.30.2013
•Finaly Fixed Random Reboot - Credit: BEST THANKS FOR THE FIX TO @ktoonsez
•Speed Charge activated - Very FAST!
•BT / Bluetooth fixed
 (28.12.2013) RC2
•New Kernel: 3.4.0-Alucard-V2.4.3l-GE-EUR-KK4.4-SGIV-PWR-CORE+
•Fixed Random Reboot (i hope)
•Updated SuperSU
•Edited updater-script
 (26.12.2013) RC1
•Reduce Random Reboots - Full Wipe required
•Delete some Touchwizz Lib's
•Fixed some Things
•ExFat Support ?
•Phone are Faster !!!
 (19.12.2013) v11
•libGLESv3 Application are Fixed
•Return to Stock Google Edition 4.4.2 Cam
•symlink fixes
•FC's are Completly Fixed...
  (16.12.2013) v10
•Gapps FC's are Fixed
•Gallery Picture Quality are Fixed
•Zipalign, sqlite3, run-parts, nano, bash
•New Busybox in the Rom
•Little Bug Fixes...
•Faster
•Whatsapp works on ART
 (14.12.2013) v7.0
•New ROM base 4.4.2 - KOT49H
•Faux123 r2 Kernel - Dec 1
•Fixed Grey bars on Power Menu
•Fixed gallery picture remove
•Fixed Completly Camera and Gallery
•Fixed Completly ExtSDCard
 (07.12.2013) v6.0-OTA
•Fixed force close when assigning contact portrait
•Fixed HDR
•Fixed 2MP Front Camera
•Fixed black Statusbar in lockscreen
•Statusbar in lockscreen are transparent
 (06.12.2013) v5.0
•Update completly Updater-script ...
•Fixed Wallpaper in Framework-res.apk
•Build.prop cleaning and a little change valvue - Makes the Phone faster....
•Performance Tuning in Build.prop
•Fixed some Speed issues in ART
•Fixed Video Record on ART
•Fixed Permission
•Removed all Crap Samsung bloadware
•Removed CSC Support ..its not more needed :)
•Set picture and video at 100 % quality on shot, record and preview in gallery.....
 (01.12.2013) v4.0
•Fixed ART
I have misstake on the v3.0 ,sry :/
 (01.12.2013) v3.0
•ExtSD write permission are Fixed
•3G/H icon are fixed
•Included Busybox
•Dalvik VW Changes in Build.prop
•Random Reboots are fixed... @Faux123 Thx
•New Kernel:jgedlte-faux123-GE-KK44-014m_r2 Thanks @Faux123 for your Kernel :)
 (30.11.2013) v2.0
•Settings--->Security ---> FC's is Fixed
•Settings--->More...---> VPN is Fixed
•Deinstall Apps are Fixed
•ExtSD Fixed
•Rom are Prerooted with latest SuperSU v1.80
•Added Qualcomm optimized Dalvik + Bionic - More Speed at All
•New Kernel : @Ktoonsez big thanks for him :)
@yener90 big thanks going to him for the Fix Solution for FC's :)
The Rom are works with new and old Bootloader ...
 (26.11.2013) v1.0
•Initial Release
Reaktionen: linuxazubi, ibli, blue007 und 27 andere
das mit den Reboots ist echt krass , kann mein Phone nicht mal 20 min liegen lassen ohne das Rebootet , gibts schon irgendeine lösung vielleicht ?
Grüße
Ich kann es wirklich nicht nachvollziehen.... Ich habe die V2 seit 8 Uhr und bis jetzt kein reboot gehabt....! FULL Wipe vor der Installation gemacht!
Na endlich geht es los :) sind die restarts wirklich so schlimm wenn man einen full wipe macht?
hab n full gemacht das Teil rebootet dauernd, besonders beim Laden und telen
So mittlerweile ist es 19 uhr und immer noch kein reboot... ;-) hab ich einfach Glück oder macht ihr was falsch....?
meine externe sd card wird irgendwie nicht erkannt! bei Titanium Backup steht "besteht kein Zugriff"
Danke! Ich warte aber noch ein bisschen denke ich. ^^
Dito. Apps deinstallieren oder sim unlock wäre mir egal. Aber dank Rufbereitschaft sind reboots n nogo:(
Gesendet von meinem GT-I9505G mit der Android-Hilfe.de App
Gegen die Reboots beim Laden half mir, in den Entwickleroptionen einzustellen dass das Display immer aktiv ist beim Laden. Wenn man dann nicht sperrt hat es sich nicht rebootet.
Hilft jetzt zwar nur beim Laden und nur bedingt, aber wenigstens etwas.
Allerdings bisher nur bei der Version 1.0 getestet damals.
Ich bin mal gespannt auf v3.0 - bei xda Devs gehts ja ziemlich rund, der Thread hier scheint fast ausgestorben :(
Reaktionen: Extrawelt92
v3.0 ist draußen .....ließt die Changelog und die Buglist :p
full wipe !
Reaktionen: OPC_300, Extrawelt92 und GalaxyMax90
moin,
ist das nur diese Datei
I9505_-_Official_Google_Edition_4.4_by_Jamal2367_v3.0.zip
in dem Video auf xda werden zwei Dateien installiert????
Dave
Wie sieht es bzgl Akku Laufzeit aus? Kann da jmd berichten?
Wie sieht es mit whatsapp aus wenn Art an ist liegt das an whatsapp oder an was?
Dann versuch ich mal mein Glück:D
Läuft es jetzt rund? Bin noch auf der Originalen 4.2 und die Macht nur Probleme deshalb will ich mal diese Rom testen.
v4.0 kommt in 10 minuten mit ART fixed .......ich habe einen fehler in der build.prop in der v3 gemacht und dann ging art nicht mehr ...
Laufen alle wichtigen Apps unter ART? Also Facebook, Whatsapp etc?
Also hier rennt sie bis jetzt. keinerlei Problemchen, nun mal weiterbeobachten:winki:
