[ROM][i9505][4.4.2][KOT49H] *26.12.13* SuperNexus 4.0 Build 1
  • 1 Antworten
beicuxhaven
beicuxhaven
Ehrenmitglied
10.437
  • Android 4.4.2 KitKat (KOT49H - Android-4.4.2_r1)
  • Latest CM Kernel
  • All KitKat features and apps (Nothing excluded from AOSP)
  • No Visual Changes!
  • Stock KitKat look and feel
  • This will turn your Samsung Galaxy S4 into a Nexus 5
HDR not working (on all 4.4.2 Roms here)
IR not worked..
VOIP not worked and the screen is rotated to 180 grad
  • Deodexed
  • Rooted (Super SU)
  • BusyBox Installed
  • No 3rd Party App
  • ZERO Bloatware
  • Android Source Code vastly improved and optimised (i.e. Bionic, Dalvik, Webkit, Framework, libcore, SQlite etc - Thanks to CAF)
  • Init.d Support
  • Rsync Support
  • UserInit Support
  • Bash & Nano Support
  • Native SIP/VOIP Support
  • OpenSSH Support (ssh, sshd, scp, stfp)
  • HSPA+ Support
  • OpenVPN Support
  • Ad-Hoc Network Support
  • exFAT and NTFS-3G support
  • EXT4 File System Optimisations
  • Large APN & SPN List
  • SELinux enabled
  • Framework Features:
    -Extended Power Menu (Reboot, Recovery, Download & Screenshot Options)
    -Tweaked Animation Values Of Progress Spinners (Silky Smooth Loading Spinners)
    -Options for switching between USB Mass Storage and MTP/PTP (On Specific Devices)
  • Browser Features:-
    -Increased Maximum Tab limit from 16 to 64
    -Option To Close All Tabs With One-Click
    -Allowed Any Type Of File To Be Downloaded
  • Phone Features:-
    -Noise Suppression
  • Miscellaneous Features:
    -Allowed Installation Of Apps From Unknown Sources By Default
    -Disabled Data Roaming By Default
    -Removed Google's Software Updates Option from Settings
    -Enabled Gesture Input By default
    -Emoji Enabled by default
    -Hardware Information of the device (Settings>About Device>Hardware Information)
  • CWM Touch 6.0.3.2+ oder aktuellster TWRP
  • (if you have a metadata error when flashing, you're using the wrong recovery!)
Erstinstallation SuperNexus 4.0 oder von einer anderen ROM kommend:
- Copy Google Apps and SuperNexus ROM into your internal SD Card
- Boot into Recovery (Volume up + Home + Power)
- DO A DATA WIPE / FACTORY RESET (otherwise your device will be stuck at boot)
- Flash SuperNexus ROM
- Flash Google Apps package
- Reboot your device
Upgrade der SuperNexus 4.0:
- Copy Google Apps and SuperNexus ROM to your internal SD Card
- Boot into Recovery(Volume up + Home + Power)
- Wipe Cache
- Wipe Dalvik-cache (Under Advanced -> Wipe Dalvik-Cache)
Downloads
Latest Build:
Google Apps:Google Apps KK 20131209 MD5: 775dccce3b7d468638b09a5a756f988b
  • DigitalOcean (Website)
  • Simon Brunton (Graphic Designer - Website)
  • Google
  • CyanogenMod Team
  • Teamhacksung
  • Codeworkx
  • Xplodwild
  • Nebkat
  • Espenfjo
  • Pawtip
  • Chainfire
  • Thanks to all those who donated
Reaktionen: tobiasth
Hatte es auf meinem s2 und es war der Hammer!!! Habe leider nur wenig zeit aber wenn ......... dann ist mein s4 fälling!!! ;-)
Gesendet von meinem GT-I9505 mit der Android-Hilfe.de App
Fifaheld
postmaster
Fifaheld
Fifaheld
Fifaheld
Fifaheld
Darks
Darks
