[ROM][I9505] 4.2.2 - S4 Google Edition - Final-v1 - Feel the Experience of Nexus
  • 1.087 Antworten
jamal2362
jamal2362
Working:
Alles Funktioniert!
Bugs:
Keine Bugs vorhanden!
Screenshots:
Changelog:
(21.07.2013) Final-v1
•Based: Stock Google Kernel :3.4.0-837695 - se.infra@S0210-16 #1
•New lib/mudules
•Fixed Wi-Fi for some user ..
•Some Speed fixes
(17.07.2013) Final
•Added H+ Support
•Added 4 Way Reboot
•Fix Sim Unlock - Press Power and click "Unlock Simcard"
-Thanks[MENTION=4354408]broodplank1337[/MENTION]
OLD:
(14.07.2013) v16
•Change I9505 to I9505G ......
•Fixed Nfcnci.apk .....
•Google Wallet is completly Fixed...
(13.07.2013) v15
•Back to ausdim kernel v7
•Fix MTP and PTP
•Fix Wallet
•Fix NFC Pay
(12.07.2013) v14
•Kernel Based: 3.4.52 - Linaro broodKernel Google Edtition v1.2 (O3)
Changes:
-Undervolted CPU
-Voltage VDD Sysfs support
-Fixed Rotation (Thanks to Ausdim)
-Compiled with new Linaro toolchain
-New InstaVOLT version edited for custom vdd_levels path
-LPM Mode is fixed for some user or all....
•Cleanup lines in the framework
•New Libs added....
(10.07.2013) v13
•Fixed 4G Speed
•New Google Maps 7.0 - Better/Smoother UI
•Removed 1 Script for Performance
•Renew all Frameworks !
•SuperSU and SU binary updated to 1.41
(09.07.2013) v12
•Fixed 3G/LTE/4G
(09.07.2013) v11
•openvpn support
•powersaving tweaks
•cleanups
•fix zipalign
•reduce boot time
•Fixed scrolling ......scrolling is smooth :)
•Better Speeds on 3g/4g
•Performance Tuning to 1 - Faster Rom!
•Wifi Supplicant Scan Interval to 180 - battery saving!!
•Video Streaming Tweak
•Improve the sensitivity of the touch screen
•Wifi speedup :)
•Based Ausdims v4 Kernel!!
(08.07.2013) v10
•init.d scripts removed - not working
•Better Battery life and hold long :)
•Video recording tuned
•Set picture at 100 % quality on shot and preview in gallery.....
•Build.prop tweaked
•Boot faster - little system tweak
•New Torch from AOSP 4.2.2......
(08.07.2013) v9
•Updated Linux kernel to latest 3.4.52 - ausdims v4 kernel!
•Disable Gentle Fair Sleepers
•Disable rooting restrictions
•Disable all debuggers (better battery life)
•Rom tweaks.....
•Very good battery life , stable , clean and fast!
•Cleanups....
•Torch added!
•Newest GPU Driver included :)
(06.07.2013) v8
•New broodKernel-GE-O2+ - Google Edition - 3.4.51 - Linaro Build!
•Better gpu driver .....
•Better Kernel Tweaked .....
(05.07.2013) v7
•Fixed Battery drain myself in Kernel !
•Included Spripts for Speed up the Phone!
•init.d scripts Activated...
•update updater-script
•update Build.prop
•include sqlite3 , zipalign , nano sript !!
•More....
(01.07.2013) v6
•Fixed Samsung Camera support..TheLastStands camera mod is not working !
Download mine in Post 7!
•Many speed bugs fixed....
•Add Google+
•Fix Battery drain again !!
(30.06.2013) v5
•Update ausdim Kernel to v3..
•Updater-script edited....
•Kernel makes phone cold !!!
(30.06.2013) v4
•Update ausdim Kernel to v2..
•Build.prop clean up ..
•Rom is cleanup ...csc floder and some is cleaning .....
•Fix Battery drain !
•Removed all samsung apk's and google+
•Tweak up updater-script its stabler .....
•No CSC is needed!!
•Included Busybox ....
•Rom is Stable...!
(29.06.2013) v3
•Fixed Hangouts... for some user...
•Build.prop clean up ...Rom is booting in 20 sec...
•Removed the Samsungs bloadware ~20mb
•Ausdim kernel based....show v2 in changelog...
•csc.apk removed its unsoppoted on this rom ...
•Tweak up Build.prop its stabler .....
(29.06.2013) v2
•Fixed Hangouts , Google Keep , Google+ , Youtube...
•Ausdim's 3.4.0-Google-Edition - Kernel included!
•Pre-Rooted - Latest SuperSU and su binary included!
•Updater-script is based of Omega and cm10.1...
•Cleanup updater-script...
•MTP , Exfat fixed...
•WiFi fixed...
•FileManager included...
(28.06.2013) v1
•initial release
[/CODE]
Mods für das Rom:
Reaktionen: Freddy Krüger, Schotter, d407974 und 2 andere
Ich würde sagen diese Rom ist Deodexed und wie ich das so sehe läuft alles, werde ich mal ausprobieren und schauen wie sie so läuft.
Erfahrungsberichte sind sehr erwünscht^^
Ich flashe es in der nächsten Stunde, dann schreib ich kurz mal ein anfängliches Feedback
Reaktionen: Volker22, xGalaxyx, Serioussnape und eine weitere Person
Hat sie schon jemand am laufen? Geht alles? Ist sie gerootet?
Danke!
Anstatt hier immer zu fragen ob alles geht wäre es mal gut es selber zu testen. So langsam nerven diese Fragen hier.
Reaktionen: Lockotock :), Volker22, boxpeter und eine weitere Person
Einfach wie beschrieben flashen? oder braucht man einen bestimmten Kernel?
Ja wie beschrieben flashen, Kernel ist enthalten. Sonst würde es ja auch dabeistehen, dass Du noch einen sep. Kernel brauchst.
Hat alles geklappt, aber ab der PIN Eingabe hängt es. Geh grade zurück zur P.A.C..
Wtf Oo Als ich mein Backup aufspielen will kommt die Meldung "Error while flashing Boot Image" ? Kann mir jemand helfen?
Hast Du jetzt evtl. ein anderes Recovery als beim Backup drauf? Ansonsten vielleicht mal das Recovery neu installieren und nochmal probieren...
Nein, habe schon immer PhilZ, aber da ich ja "sooo vorsichtig" bin, habe ich ein 2. Backup.. wenn ich das allerdings aufspiele geht es bei "Reboot System Now" automatisch in den Download Modus?! :mad2:
download leider defekt
Hat bei mir auch das erste mal bei der PIN eingabe gehangen, Akku raus, rein. Und es lief.
Bis jetzt geht alles.
Allerdings fehlen mir die coolen Tweaks, a la Cyanogen Mod etwas.
Kamera funktionierte auch erst beim 4. Anlauf.
Reaktionen: xGalaxyx
Hm, im moment kann ich leider nichts tun, da ich nur im Recovery rumhänge-.-
Weiß wirklich nicht was ich jetzt tun soll..
Edit: Wie's aussieht geht's wohl doch, so wie du beschrieben hast! Vielen Dank!
Reaktionen: Marcstefan
@Marcstefan du hast deine links vertauscht....;) der erste ist deoxed und zweiter odexed
Das Scover scheint ja noch bei beiden Versionen zu funktionieren. Wie sieht es mit der Annahme bzw. dem Abweisen von Gesprächen aus, wenn das Cover geschlossen ist. Kann das mal bitte jemand testen? (Ich weiß nicht ob das die "Air View" Funktionalität benötigt)
Fifaheld
postmaster
Fifaheld
Darks
Darks
BenLue
element1975
element1975
