[ROM][i9505][4.2.2][PA3.15][AOKP-MR1][CM10.1]P.A.C True All in 1 ROM[v22.4.0][HALO]
  • 291 Antworten
Scoty
Scoty
Ikone
1.852
Can't settle on a rom... Like one rom, but wish it had features of another... Well look no further...
PACman is a unique rom.
We have picked the best features from CM10, Aokp and PA and combined them in a single rom so you get the experience you deserve
To enjoy the features of every available project without the hassle of flashing regularly.
The Rom is rock stable for an average user but keep in mind the Rom is in WIP stage so expect some minor hickups but we are trying our best to resolve these issues
This is built entirely from source so its not a port, which in my opinion makes it a little more stable as its been made specifically for this device...
Features
* CM10.1 * AOKP - mako_jb-mr1_build-1 * Paranoid Android 3.15 *
I've decided to keep this rom simple and I've not added all the extras some other roms have added, because in my eyes keeping it simple keeps it more stable... If you want all those extras you can readily find them and flash them after the rom... but if you've flashed the extras don't complain in the thread about things not working....
Changelog:
PACman v22.4.0
HALO added
Device files bought inline with Cyanogen naming....
Rom Stats added
Updated all CM commits to RC4
Updated PA commits
Fix Pie & Tablet Date View
Update AOKP Ribbons
Fix 3-dot Menu Button
Status 7 Error fixed - thanks to victorator
Was nicht funktioniert?
WiFi, beheben kann man das aber wie folgt
Öffne denn Terminal Emulator... dieser ist beim Rom dabei
Schreibe
su
und bestättige die Root Rechte welche angefordert werden danach
rm /data/.cid.info
exit
exit
Danach sollte Wifi wieder funktionieren.
Leider muss man dies nach jeden Reboot wieder machen!!
Now as we all know by now, the early versions of CWM and TWRP are a little buggy and the rom can be a nightmare to flash so if you get a status 7 error, just reboot into recovery and try again, it does work because I'm using it on mine (yes I actually have the device!!)
1. Download rom und die Gapps
2. Kopiere beides auf das Handy
3. Wichtig die neuesten Gapps 4.2.x verwenden
4. Factory Wipe/Data Reset, Wipe Cache und Wipe Dalvik Cache, danach unter Mount noch System formatieren
5. Installiere das Rom
6. Installiere Gapps
7. Danach denn Cache Wipen
8. Starte das Handy neu
9. Fertig
Official Gapps
PA Gapps
Inverted Gapps
XDA Thread
Top !!
Endlich geht es vorwärts!!
Könnte man wenigstens die Installation Anleitung auf deutsch machen.
Weil sonst kann man sich solche Rom Vorstellungen sparen.
Ist nicht böse gemeint, aber fällt mir immer mehr auf.
Hat jemand die Rom schon am laufen und kann berichten?
die ROM wird es so oder so schwer haben - ohne WLAN get ja hier in Germany recht wenig. Und der "Umweg" lässt sich wohl kaum in eine Batch abarbeiten.
Diverse Leute im XDA Forum berichten sie hätten keine Probleme mit WLAN. Ist bestimmt ne gute ROM.
Im XDA gibts auch ne reine AOKP-ROM.
Gesendet von meinem GT-P7510 mit Tapatalk 2
Welche denn? Die ist doch schon älter oder?
Gesendet von meinem GT-I9505 mit Tapatalk 2
OT: Vom 13.5. Heisst "AOKP unofficial Nightlies OTA Updates"
Vielleicht teste ich morgen als diese PACMAN Rom.
Die ist nicht so dolle....
Habe das wichtigste so weit übersetzt.
Reaktionen: pill
es läuft super, das einzige problem ist die kamera.
sie startet nicht, "Gelerie" wurde beendet.:huh:
Welsche Gapps benutzt ihr????
Neue Version ist da.
Hat jemand die neue schon getestet ?
Würde auch gern wissen, ob die neue die Bugs behoben hat?
Steht alles im XDA-Thread.
Code:
Version 4.3:
1-Merges Latest AOKP and CM changes
2-Added AOKP Ribbons
3-Added StayAwake Toggle
4-Fix hot reboots
5-Fix Navigation Bar layout on Phablet UI
6-Fix Per-App-Color System (Thanks to Bajee11)
7-Fix SOD on lockscreen while on lockscreen (PAC Rom)
8-Add Permissions Manager
9-DARK ReVolt is extended to Calendar, Keyboard and E-Mail
10-Hidden StatusBar Pulldown Feature
11-Fix Pie Toggle (Thanks to Bajee11)
12-General fixes and memory leak fixes
13-Added feature from CM Camera
14-Add initial Support for Oppo Find5, Samsung Galaxy S4(jfltetmo and jfltecan) & HTC one
15-Fixed SystemUI crashes
16-Fixed FC on Tablet UI mode in Lockscreen (Thanks to DaxMaxx)
17-Modular BackUP tool added
18-Added build info in flashing
Changelog is von revolt......
Im XDA-Thread gibts ne neue Version mit WiFi-Fix.
Unterstüzt dieses Rom 64gb Karten?
Wifi ist laut XDA immernoch da.
Welches Format wird von AOKP Roms unterstützt für 64Gb Karten? ExFat scheint nicht zu klappen.
Fifaheld
postmaster
Fifaheld
Darks
Darks
Fifaheld
Fifaheld
Fifaheld
