[ROM][AOSP][JB][4.3][JSS15J] SuperNexus 3.0 - jfltexx- Build 1 [16-08-13]
  • 0 Antworten
r0b
r0b
Ehrenmitglied
4.348
System Details:
  • Android 4.3 Jelly Bean (JSS15J - Android-4.3_r2.1)
  • Neuster CM Kernel
  • Alle Jelly Bean Features und Apps
  • Keine Visuellen Veränderungen
  • Stock Jelly Bean Aussehen und Gefühl
  • Diese ROM verändert dein Samsung Galaxy S4 in ein Nexus 4
ROM Features:
  • Fully Deodexed
  • Zipaligned APKs
  • Rooted (Super SU)
  • BusyBox Installed
  • No 3rd Party App
  • ZERO Bloatware
  • Android Source Code vastly improved and optimized (i.e. Bionic, Dalvik, Webkit, Framework, libcore, SQlite etc)
  • Official JellyBean bootanimation
  • Init.d Support
  • Rsync Support
  • UserInit Support
  • Bash & Nano Support
  • Native SIP/VOIP Support
  • OpenSSH Support (ssh, sshd, scp, stfp)
  • HSPA+ Support
  • OpenVPN Support
  • Ad-Hoc Network Support
  • exFAT and NTFS-3G support
  • EXT4 File System Optimizations
  • Large APN & SPN List
  • SELinux enabled
  • Framework Features:
    -Extended Power Menu (Reboot, Recovery, Download & Screenshot Options)
    -Improved Scrolling Cache
    -Tweaked Animation Values Of Progress Spinners (Silky Smooth Loading Spinners)
    -Enabled Rotation Lock Tile in Quick Settings for Phones (Previously was only enabled on Tablets)
    -Increased Lockscreen Widget limit from 5 to 9
    -Options for switching between USB Mass Storage and MTP/PTP (On Specific Devices)
  • Browser Features:-
    -Increased Maximum Tab limit from 16 to 64
    -Incognito Tab Option (When long pressed on an URL)
    -Option To Close All Tabs With One-Click
    -Allowed Any Type Of File To Be Downloaded
    -HTML5 WebSockets
  • Phone Features:-
    -Noise Suppression
  • Miscellaneous Features:
    -Allowed Installation Of Apps From Unknown Sources By Default
    -Disabled Data Roaming By Default
    -Dialer auto-complete enabled by default (Stock T9 dialer)
    -Removed Google's Software Updates Option from Settings
    -Enabled Gesture Input By default
    -Hardware Information of the device (Settings>About Device>Hardware Information)
Known Issues
  • Should be in the same state as CM-10.2
  • Found one? Report it.
Screenshots:
Requirements:
  • Custom Recovery (ClockworkMod Recovery is recommended - Don't use Philz recovery, it doesn't display the bootanimation)
Instructions
Wenn du das erstma mal SuperNexus 3.0 installieren willst:
- Kopiere Google Apps und SuperNexus ROM auf deine interne SD Karte
- Boote in den Recoverymodus (Volume up + Home + Power)
- Führe ein DATA WIPE / FACTORY RESET durch (ansonsten startet das S4 nicht)
- Flashe SuperNexus ROM
- Flashe Google Apps'
- Starte das S4 neu
- Viel Spaß
Von einer älteren SuperNexus ROM auf die Version 3.0 Updaten:
- Copy Google Apps and SuperNexus ROM to your internal SD Card
- Boot into Recovery(Volume up + Home + Power)
- Wipe Cache
- Wipe Dalvik-cache (Under Avanced -> Wipe Dalvik-Cache)
- Flash SuperNexus ROM
- Flash Google Apps' package
- Reboot your device
Downloads
Latest Build:
Google Apps:
Changelog:
Code:
[B]SuperNexus 3.0 Build 1 (15-08-13):[/B]
[LIST]
[*] Initial build
[/LIST]
Quelle: [ROM][AOSP][JB][4.3][JSS15J] SuperNexus 3.0 - jfltexx- Build 1 [16-08-13] - xda-developers
Fifaheld
postmaster
Nufan
Nufan
Fifaheld
Fifaheld
Fifaheld
