I9505 [ROM][7.1.2_r36] Resurrection Remix 5.8.5 FINAL Rel 40 [Rootless]
  • 412 Antworten
- Release 28 -
RR-N-v5.8.3-20170707-jfltexx-Official-Changelog.txt
Major changes and fixes:
  • SmartBar: make button longpress delay configurable.
  • Add support for pulsing battery icon when charging.
  • SEpolicies re-jigged for July security updates.
  • Kernel changes for fs, lan/wifi/net, bugs.
  • Fauxsound added to kernel. Use with kernel tweak app - EXKM, KA, etc.
  • Disable ultrasound driver.
  • Jelly: lots of various changes.
  • Add LTE support for China Telecom Macau.
  • Power_profile: more compatible with 'N'.
  • Gallery2: Fix crash after returning from albums in wallpaper picker.
  • Fix potential KeyguardMonitor FC on unlock.
  • Enable some more power menu actions - Settings and Lock Now.
  • WallpaperPicker: Update for wallpaper API changes.
  • ActivityStarter: Fix protected app intents.
  • SystemUI: Make play queue toggle more visible.
  • Volume Panel: Fix Bluetooth music stream icon when muted.
  • Add support for the .opus file format.
  • Fix button size not refreshing after a dpi change.
  • Media arrows: hide them on keyguard bouncer.
  • Hide disabled lockscreen blur from search index.
  • Revert "Settings: Fix internal storage summary for non-emulated storage".
  • Fix automatic hotspot turn off summary.
  • Add more sensitive numbers.
  • Add Virgin Media Ireland to APN's.
  • CameraService: Fix cameraId type of onDeviceStatusChanged.
  • AdvancedDisplay: Refactor.
  • Gallery2: Fix views overlap.
  • Copy power_profile to /system/etc/.
  • Try allow GMS saving?
  • Eleven: request record audio permission for visualizer.
  • MediaProvider: Fix failure in android.provider.cts.MediaStore_FilesTest.
  • Gallery2: Fix thumbnails of new edit photos display wrongly in Documents.
  • Music: Fix force closed when plug out the SD card while music is playing.
  • MediaProvider: Fix SQLiteDiskIOException.
  • Disable SetupWraith, the ATV SUW.
  • Fix System Navigation fp switch.
  • Fix Phone Service crash on MSIM devices as Guest user.
  • SystemUI: force a clock update if the screen is turned back on.
  • SystemUI: disable statusbar time refresh when screen off.
  • SystemUI: CPU Info: show CPU temp if supported.
  • Frameworks: Fix Null Pointer Issue.
  • Settings: Fragment cleanups.
  • SystemUI: Fix task lock & freeform buttons placement.
  • SymbolComparator operator() is missing const.
  • Hack to make YouTube 4K videos work. Don't expect anything but low bit-rate files to be anything like playable.
  • PowerProfile: allow reading from a file instead of resource.
  • When updating a split app, copy compiled files from base.apk only.
  • QS Tile: increase DEFAULT_MAX_BOUND to 6.
  • Fix service cannot start when service removed from restartList.
  • Binder: Log details of pending exception.
  • Binder: Be forceful about a forceful exit.
  • Battery icon: Improve theme compatibility.
  • Fix ArraySet crash.
  • Adopt lockscreen shortcut hint from AOSP.
  • Hwcomposer: Fix regression in hwc_sync.
  • Increase Max Small qs tiles to 9.
  • Overlay: Disable debouncing of the light sensor.
  • Overlay: Disable dreams by default.
  • Enforce wideband audio config for calls.
  • Liblights: Fix fast blinking notification LEDs.
  • Pixel Launcher updated to latest 'O'.
  • RR and LOS code grabbed 00:30 Friday 7th July GMT.
  • July Google security updates applied.
Reaktionen: kiwikh und Buzzy1984
Frage: ein magisk update welches über/als ZIP installiert wird, muss ich da wipen bzw verliere ich dadurch Daten?
Du solltest nach dem Flashvorgang nur den Cache wipen. Das reicht völlig. Aber besser ist wenn du vor dem flashen ein Nandroid Backup machst. Nur für alle Fälle.
Daten verlierst du dadurch keine.
Hehe, joa sicher ists. Dann werde ich das mal tun und anschließend Flashen. Danke
Moin, die Zip für das Magisk Update wird direkt nach dem Download installiert, danach ein Neustart machen. TWRP musste ich nicht nutzen um Magidk zu aktuallisieren.
Was meint ihr? Wird es mal wieder Zeit für ein Update? Ok, hier bekommt ihr euer Update :) :)
  • Magisk 13.3
  • Magisk Manager 5.1.1
  • DeskClock 5.1 (4015683)
  • Pixel Launcher ODR-4023749
  • Google Wallpaper 1.1.153125266
  • Adreno blobs updated
  • Kernel: Buffcore 0.017.
  • Lots of fixes, focused on stability, networking esp.
  • Msm framebuffer: fixed bug where RGBA and ARGB were inverted.
  • Additions: Governors: ADAPTIVE, ASSWAX, BADASS, BIOSHOCK, CONSERVATIVE, DANCEDANCE, INTERACTIVE, KTOONSERVATIVE, NIGHTMARE, ONDEMAND, PERFORMANCE, POWERSAVE, SMARTASSH3, USERSPACE, WHEATLEY.
  • Additions: IO schedulers: FIOPS, TRIPNDROID, ZEN.
  • Additions: Hotplug: INTELLIPLUG.
  • Additions: Filesystem: ExFAT.
  • ScreenCap : Add jpeg support.
  • Configurable Keyguard alpha and Keyguard Bouncer alpha.
  • RecentsView: Hiding membar, memtext and fab on drag start.
  • SystemUI: Fix Notification Background Color Issue.
  • Secril-client: Fix RIL client token management in SendOemRequestHookRaw().
  • Gallery: Fix potential crash.
  • Gallery2: Switch to navigationbar from support libs.
  • Configuration of lights hardware buttons fixed so now only come on when buttons pressed, not when screen pressed.
  • Jelly changes.
  • Pin camera app for faster start up.
  • Smartbar longpress delay:make it more configurable.
  • Settings: make hw keys light up user configurable.
  • RR and LOS data grabbed at 01:30 GMT, Thursday 20th July.
  • Android 7.1.1_r24 - July Security update.
Reaktionen: joe_sixpack, m505, Ev0s0nic und 2 andere
- In-test release candidate for Release 30 -​
  • Single tap tile add - Allow user to add/remove QS with one click
  • Drop-down data switch through Cellular tile.
  • Settings:remove Selinux Switch. Controversial, I know. But no-one should need it these days.
  • Left in landscape navbar API
  • CarrierConfig - Fix up incorrect domestic roaming and non-roaming cases
  • Fling logo on pulse: add transparency instead of hiding it
  • Fling: if KB is showing, double tap right/left to move text cursor
  • mixer_paths: add incall recording paths. maybe. or maybe not. don't blame me if it don't work.
  • Grant netmgrd proper unix perms
  • Thermal: try reverting some older config
  • Sensor block per-package. Sounds like nothing. But it's good. Stops "certain apps" getting access to certain sensors. Saving power, for the use of.
  • Update flags for edge gesture service from AOSPA
  • Performance: Interactive governor tweaked <thanks to @63ck0>.
  • Hotplugging: MPdecision removed. AutoSMP added.
  • Introduce pocket bridge, pocket lock, pocket judge, Accidental Touch
  • PIE 3.0
  • Fix FC when adding duplicate shortcuts
  • Hide sRGB toggle in developer options
  • enable Panic Detection mode
  • Allow untrusted_apps to read usb power supply stats
  • Allow to disable battery light when in DND mode
  • Store value of lockscreen media art
  • disable spectrum for now
  • animate screen lights
  • do not build SamsungDoze for the moment
  • Revert "Change adreno blobs"
  • SEpolicies - re-implemented Substratum related.
  • DeskClock: revert to version 5.0.1. Newer version probably cause issues when themed.
  • Jelly, Gallery, OmniSwitch - lots of changes
  • Kernel: Buffcore 0.24.
  • Intelliplug removed. AutoSMP added. Add Power Efficient work queues, set TripNdroid as default scheduler.
  • RR and LOS data grabbed at 09:38 GMT, Thursday 10th August.
  • Android 7.1.1_r29 - August Security update.
  • Resurrection Remix 5.8.4
Reaktionen: joe_sixpack, Buzzy1984 und Nufan
Und schon das update getestet?
Bisher noch nicht - werde es aber erst am Wochenende installieren können. Da ist es nämlich nicht so tragisch, weil ich zu Haus immer alles griffbereit habe (inkl. Notfall-Images, Strom und unlimitierten Internet). Unterwegs ist das doch etwas blöd, wenn man nur noch mit der Kies-Systemwiederherstellung weiterkommt und dann alles über Mobilfunk oder irgendeinen Public Hotspot sowie einer Powerbank machen darf...
Ja das stimmt wohl. Habe die letzten updates noch nicht installiert und ich bin da oft vorsichtig [emoji14]
Akku befüllen, ROM sowie Gapps herunterladen, komplettes Backup im Recovery machen und ab die Post.
Auf s4 habe ich es noch nicht, aber auf dem Alpha, s4 mini (beide dirty), s3 sowie seit eben auf s5 mini (clean nach stockromflash) läuft 5.8.4 sehr geschmeidig :biggrin:
Reaktionen: SaschaKH
Nutze die RR schon einige Zeit, auch diese Version habe ich einfach drüber installliert und keine Probleme bis jetzt.
Reaktionen: Nufan
Hallo,bin auch mal wieder da, und auch eine Frage. Ich hatte das cosmic Rom drauf und habe mir dann mal die RR 5.8.4 installiert.hat auch alles geklappt.Wollte mir jetzt mal 5.8.3 installieren, komme immer bis zur Kontowiederherstellung und dann kommt System-UI wurde beendet.Habe schon mindestens 4mal neu geflasht, immer das selbe..?? Cosmic Rom rauf geht.?? kann da einer was zu sagen?? m.f.g. Habe mir mal das CR Droid installiert und läuft auch.
Ich bekomme Magisk nicht richtig zum laufen. Öffne ich den Magisk Manager sehe ich nur, dass Magisk nicht installiert ist.
Habe dann SuperSU geflascht aber leider konnte Magisk trotzdem nicht installiert werden.
Magisk zu flashen hat leider auch nicht funktioniert, dann startet das Gerät gar nicht mehr. :/
twrp-3-1-1
Bearbeitet von: Onslaught - Grund: Bild gespoilert. - Gruß Onslaught
Spontan: Liegt wohl an TWRP. Nimm mal Version 3.1.0.0
@Quadratball Lade dir diese 2 Sachen runter: tiny.cc/latestmagisk ( Bitte in die Adresszeile deines Browsers kopiren ) und https://github.com/topjohnwu/MagiskManager/releases/download/v5.1.1/MagiskManager-v5.1.1.apk
Das ist Magisk ( Wird per TWRP geflasht ) Ist in der RR aber schon vorhanden, also nicht nötig nochmals zu flashen.
Das zweite ist die Magisk Manager App als apk Datei ( diese MUSS als App sidelooad installiert werden.
( Hierzu unter Einstellungen - Sicherheit den Punkt " unbekannte Herkunft " antippen und bestätigen.
Dann mit dem Dateiexplorer die Magisk Manager.apk istallieren und dann Magisk starten.
Fertig... Viel Spass und Erfolg.
[doublepost=1503245511,1503245346][/doublepost]Du kannst die APP Magisk Manager aber auch in Magisk runterladen, einfach unten auf " Herunterladen " drücken.
Welches TWRP hast du denn am laufen @Buzzy1984 ?
SuperSu gehört nicht hier hinein, wenn du Magisk möchtest:
SuperSu unroot, Magisk unroot, Magisk 13.3 neu installieren oder CleanInstall, wenn Magisk nicht funktioniert noch einmal Magisk unroot.zip und neu flashen, jeweils Cache/Dalvik löschen. Dann weitersehen.
@Nufan Moin, habe die TWRP 3.1.1.0 am laufen und alles super.
Reaktionen: Nufan
Release 31.1:
  • Magisk manager missing on first install issue fixed
  • Magisk 13.6 beta (1360).
  • Rom now pre-odexed <thx Belgas14>.
  • Samsung Doze reinstated <ambient mode returns, Paulo's prayers are answered>.
  • "Panic detection mode" exorsised from rom - it was evil.
  • "Weather providers" built in now as no longer available from playstore.
  • Spectrum still disabled... maybe next version?
  • GMS optimization ability removed.
  • RR and LOS data grabbed at 10:32 GMT, Friday 25th August.
Reaktionen: djhooker und Buzzy1984
Hallo, erst mal sorry das ich mich nur wegen einer Frage melde. Hab hier im Thread viel gesucht und im Original XDA Thread aber keine Lösung gefunden.
Hatte von euch schon jemand das Problem das nach der Installation von R30 (war vorher auf CM12) der interne Speicher anscheinend nicht richtig erkannt wird und die SD Karte komisch gemountet?
Grundsätzlich ist mir erst kein Problem aufgefallen bis ich versucht habe Apps aus dem Playstore zu installieren. Was leider nicht geht.
Ich kann zum Beispiel auch keine Dateien über den Browser runterladen. Oder Bilder die ich per Whatsapp empfange können nicht gespeichert werden.
Vielleicht hatte ja schon einer das Problem und hat eine Idee.
MfG Robin
Fifaheld
postmaster
Fifaheld
Darks
Darks
Prime Evil
djhooker
djhooker
