Fifaheld
Dauer-User
- 386
- Themenstarter
- #21
Kleine Änderung. Titel Thema angepasst da neue Version veröffentlicht
Changelog:
20170120 / (20-January-2017)
MD5 for aroma build - 4caf50d8ec345e25815c30c5210539fe
MD5 for non-aroma build - 08cd79f2277580ab639057849333e5ca
- Upstream merge until 20-Jan-2016
- Update stock kernel to 20-Jan-2016
- LineageOS
- Revision r9
- Reconstruct the way that ROM is provided
- Kernel and ramdisk big updates
- STweaks is updated
- Refresh Snap preview after photo shoot
- Edits on Doze
- Substratum support
- Edit SMS Limit and restrictions
- Wallpaper
- Several device edits(affects partitions)
- Updated Snap camera
- Completely remove CMStats and its drain
- Stop some logcat spams
- Disable LiveDisplay by default
- SuperSU to 2.79 SR3
- Give persistent SU access to system apps
- Fix WiFi Hotspot
- Enable Google Assistant
- Add an advanced Google Play Services killer(Default) 'Stweaks/OTHER tab"
- SystemUI:Remove 'x' sign from signal icon
- Update Wallpaper app
- Update ES file manager app
- Updated bootanimation
- Updated WebView
- Add ability to download flashables from Opt-LineageOS menu
- Give the proper permissions to your browser
- Many transitions from CM to LineageOS
- Fix SuperSU related logcat spam
- Add membar to OptLineage tweaks
- Set back button kill timeout to 500ms
- Increase timeout to compile GMS core
- Add ability to restrict app data/wifi usage
- LineageOS official bootanimation
- Add CPU info overlay at developer options
- Add mattgyver to Test Team
- bluetooth:Allow HFP protocol
- Edit Straight Talk APN
- Enable Blur feature
- Add unlink volumes feature
Some notes about the new build....
- F2FS is known to cause issues when we use SuperSU.I hardly suggest to use ext4 for all partitions
- On the first boot u may have some browser and music FCs...not constantly though.Select the option to mute the notification until next reboot.
So ,give all the permissions to those apps and reboot when u setup ur device
On the next reboot you wont have such issues.- The folder link contains 2 ZIP files.1 is the aroma 1 is the NON aroma build for those who got issues with it.
Non-aroma build contains :
- Alucard kernel
- CM File manager
- No Nexus apps
- No SuperSU
- AOSP camera only
- Optimized LineageOS settings has got options to download all the aroma installer packages.To do that ,simply click on the desired package.
To make this work,u must have already give the proper permissions to your browser.You can download any package ,even if you installed aroma zip- Dont you want to make a fully clean install ? no problem.BUT.keep in mind that dirty install will keep ur old kernel changes even i made changes to kernel.
So
- if u really want to make a dirty install and keep your kernel settings,simply flash the zip over the old one.(optional:delete system and dalvik before that )
- if u really want to make a dirty install with the new kernel settings,delete the folder /data/.b--b/ from twrps file manager and then flash the rom as situation 1)
- The late reboot time is a known issue on s4 with nougat roms.
