I9505 [ROM][6.0.x] The Android Open Source Project [Build_by_JDCTeam]
  • 60 Antworten
Läuft gut??
Wie komm ich SN meine externe SD,Bilder sind in der gallery aber wie kann ich Daten von extern SD auf interne schieben?
Finde ganz schön akku drain in der Rom....
Download
Changelog
20160208 - Beta 5
MD5 - 5f3a8b2a554ad89f7aef31bc0e3df985
  • Kernel
    • General code update
    • Netd/wifi: updates and fixes
    • Added support for SGH-S970G and SM-S975L
    • IR: fixed phone hotboot, crash, reboot using IR-Blaster
  • ROM
    • RIL: fixed emergency call
    • RIL: fixed a couple of permission denials (QMUXD)
    • Telephony: small improvements
    • RIL: more updates for lp ril
    • RIL: fixed NO SIM when phone is in Airplane mode and the SIM is inserted
    • AOSP Settings: Updated translations
    • Bluetooth/Stagefright: other small fixes
    • RIL: fixed network search
    • Bluetooth: fixed reboot when user starts a call when the screen is off and the magnetic cover il closed
    • Bluetooth: fixed call not working/bt share FC after the phone is reconnected to a bt device
    • Audio policy: fixes for bt calls
    • Telephony: remove multiple default dialers support
    • Updated APNs
    • Audio/av: more fixes for qcom legacy devices
    • wifi: small improvements
    • bt: merged updates/fixes from upstream
    • bt: fix connection with BLE devices
    • av: fixed some overflows (from upstream)
    • Telephony/Dialer/InCallUI/base: upates and fixes for IMS
    • base: small fixes from upstream
    • Display-qcom: fixes for video playback and KW issues
    • Improved APN selection
    • Media-qcom: removed drm library + fixes for video playback
    • wifi: set country code to ALL
    • core: updates from upstream
    • TEST: libhardware_legacy: ported some changes merged/pending on aosp upstream
    • av: allow media server to disconnect the camera even if the camera is unlocked (should fix the camera bug "Camera Error, Camera is unable to initialize.")
    • Update sources to Android 6.0.1 release 13
    • Bluetooth: fixed 48k sample rate
    • Telephony: fixes for some sims/carriers
    • Base - apps/Bluetooth: other small improvements for bt
Hat die Rom schon jemand getestet?
Bin gerade am installieren!
Bei mir lief die Beta 5 eine Woche problemlos. BT funktioniert, keine WiFi Aussetzer, alles gut :)
Reaktionen: 66er
Akkulaufzeit ist Top! Performance Probleme bei Games genauso vorhanden wie bei CM13. Laut Antutu ca 1/3 weniger Multicore Leistung.
Es muss eine SMS App und ein Dateimanager nachinstalliert werden. Die Desigen von CM können nicht verwendet werden. Bluetooth läuft super und der Wifi Bug von CM ist hier nicht vorhanden.
Wo gibt es eigentlich den Datei Manager der bei CM dabei ist? Habe mich mittlerweile sehr dran gewöhnt. Wenn er da fehlt würde ich ihn gerne da nachinstallieren dann. Welche SMS App würdest du empfehlen zum nachinstallieren?
Du kannst den Dateimanager von CM kopieren und bei AOSP 6 wieder einfügen (unter /system/app/CMFileManager), er funktioniert aber viel gestestet habe ich nicht. Im Playstore gibt es die originale sms app.
Wird mit Google nicht eine SMS App installiert?
Kommt auf die Gapps an. Ich nutze nur nano
Build vom 10.2 ist online!!!
Jemand drauf?
Das ist die Beta 5 die Audianer hier erwähnte. In dem Fall. Ja, hatt oder hatte jemand drauf. Audianer....
Ich hab sie seit Ende Januar drauf und bin mega zufrieden.
Gibt es schon Anzeichen wann die nächste Beta (in dem Fall wohl Beta 6) kommt?
Warum? Die Beta 5 ist sehr stabil. Ich weiß nich von nichts.
monatlich wird es mit sicherheit updates geben. allein wegen der android sicherheitsebene.
Reaktionen: Fifaheld
Das hört sich doch schon mal gut an :)
Der erste Kam ja wohl im November raus und bis Februar gab es 5. Dann kommt es fast hin mit Monatlich
Ist das normal das man im Taskmanager nicht mehr alle Prozesse auf einmal killen kann sondern alle einzeln wegwischen muss?
Fifaheld
postmaster
dj3d
Poppenspaeler
Poppenspaeler
Nufan
Nufan
