I9505 [ROM][6.0.x] Synergy's CyanogenMod 13.0 [Unofficial ROM & Kernel]
  • 27 Antworten
Cloud
Cloud
Senior-Moderator
Teammitglied
20.038
Unofficial Synergy´s CM13 für Samsung Galaxy S4 (Qualcomm)
Build by Synergy @ XDA
Version Information
Bugs
  • Bluetooth Audio funktioniert mit manchen Geräten nicht richtig
  • Sollte sich LTE beim Boot nicht aktivieren lassen -> einmal APN wechseln und wieder zurück
  • Wifi Standby Bug behoben !!!!! (Kernel)
Features
ROM:
  • Using the CyanogenMod 13 Nightly base
  • Built with the UBER GCC 4.9.x Toolchain
  • Compiled with optimized compiler flags by @Arter97
  • Add ability to hide SU icon in statusbar, off by default (Settings > Status Bar)
  • Add switch to enable full-screen recents (Settings > Developers Options)
  • Added Quick Unlock for PIN Lockscreens
  • Tweaked Ambient Display schedule
  • Display the current app being optimized during boot
  • Smoother Upload/Download status bar animation
  • Improve scrolling and scrolling cache
  • Sped up framework animations slightly
  • Update stock audio to the Nexus 5 factory image audio
  • Added SuperSU to Settings menu, if installed
  • Developer Options should be enabled by default
  • Allow MultiWindow option to be shown in userdebug builds
  • Slightly tweaked ART and bionic repos thanks to @Arter97
  • Updated jemalloc and SQLite repos thanks to @Arter97
  • AdAway v3.1 included
  • Marshmallow bootanimation included from here
  • Added default Nexus 6P wallpaper, removed default live wallpapers
Kernel:
  • Updated to the linux 3.4.110 kernel base
  • Built with UBER GCC 5.2.x Toolchain
  • Intelli-plug Hotplug, MPDecision disabled
  • Intelli-plug
  • Added Sweep2Sleep. Sweep from above the Back button across to above the Menu button to put screen to sleep.
  • Sensors: Add SM-S975L and SGH-S970G to variants list
  • Updated Interactive CPU Governor from @temasek's Hlte kernel
  • Updated CPU boost driver from @temasek's Hlte kernel
  • ROW I/O Scheduler set by default
  • CPU Voltage Control
  • Dynamic Fsync toggle (disabled by default)
  • Power Efficient Workqueues for powersaving
  • Enabled SCHED_AUTOGROUP for better multitasking
  • Westwood TCP congestion algorithm enabled by default
  • Reduced bcmdhd wakelocks
  • Modified Ramdisk
  • Many more various tweaks that can be found here
Downloads
Installation
Bitte nur installieren, wenn ihr wisst, was ihr tut.
Jeder ist für sich und eventuelle Schäden, die durchaus möglich sind, selbst verantwortlich.
Durch das Flashen erlischt deine Herstellergarantie! (KNOX Warranty Void 0x1).
  • Data und Cache Partitionen können bei Bedarf in F2FS konvertiert werden. (empfohlen)
  • Wenn ihr von einer anderen ROM kommt -> FullWipe
  • Wenn ihr von einer CM12/CM12.1 ROM kommt -> FullWipe
  • Wenn ihr von einer CM13 Build kommt -> FullWipe
  • Backup, Backup, Backup! Bevor ihr flasht immer ein Backup des aktuellen funktionierenden Systems erstellen
Neuinstallation der ROM
  1. ROM zip und passende GApps runterladen
  2. Alle zip-Files auf die externe SD-Karte packen
  3. Neustart ins Recovery
  4. Advance Wipe " /System /Data /Cache /Dalvik /Internal Storage "
  5. Bei Bedarf Partitionen zu F2FS konvertieren
  6. Wähle "Install zip from SDcard"
  7. Installiere ROM zip file
  8. Installiere GApps zip file
  9. System neustarten
Update einer bereits installierten Synergy-ROM
  1. Aktuelle ROM-Version und passende GApps runterladen
  4. Advanced Wipe " /System /Cache /Dalvik Cache " [/system bei Bedarf]
  5. Wähle "Install zip from SDcard"
  6. Installiere ROM zip file
  7. Installiere GApps zip file (Nur wenn /system gewiped wurde)
  8. Advanced Wipe " /Cache /Dalvik Cache "
Der erste Bootvorgang kann nach dem installieren/updaten bis zu 5 Minuten dauern. Also Geduld.
"Features" ist 1:1 von Synergy´s Thread in XDA übernommen und wird von Zeit zu Zeit aktualisiert!
Solltet ihr Fehler entdecken oder etwas wissen das in den Startpost gehört -> PN an mich!
Anmerkung der Moderation:
Fragen und Diskussionen zum Kernel kommen bitte nach hier.
https://www.android-hilfe.de/index.php?threads//
Danke
Bearbeitet von: COB93 - Grund: Ergänzt
Reaktionen: COB93 und Denker1972
Feb 28 Build
Hi guys,
I've been very busy lately occupying myself with other things. I wanted to re-do the kernel with this release because I wasn't happy with the last one. Going back to simplicity again, and removing what could possibly affect the new variants' sensors. I've also moved away from the tuned Interactive and brought it back, near inline with stock CM. I would've released this sooner but I experienced some bad battery drains, even during calls and I wasn't sure if it was the ROM/Kernel, or Google Play Services, so please be on the lookout for that and have a Nandroid ready. I ordered parts for a pretty beast computer to replace my MacBook Pro and to host a virtual server for me to build with. I also bought an S7 Edge, it's waiting at home right now and I'm very excited to use it! I'll still build for the S4 for as long as possible, though.
ROM:
  • Cherry-picked Bluetooth related fixes from JDCTeam’s AOSP 6.0 ROM. It’s less broken, but still broken.
  • Sync with CM up until this weekend
Kernel:
  • Ramdisk: Re-tune Interactive, no longer super power saving and should no longer lag during games/app installation
  • Reverted Interactive and CPU boost commits
  • Removed LMK ADJ RBTree
  • Added jfltetf* variants to the flash barriers
  • Kernel re-haul. Back to CM13 base and added:
    • Intelli_plug
    • Dynamic Fsync (Disabled by default)
    • Simple GPU Gov (Enabled by default)
    • FauxSound
    • Faux123 improvements
    • Power efficient workqueues
    • Arter97 improvements
    • S970 & S975 Sensor compatibility
    • WiFi improvements
    • sweep2sleep
    • GZIP Compression
SynergyCM13.0-20160228-jfltecdma-fd4ed30bbd.zip
SynergyCM13.0-20160228-jfltegsm-0762a7ad9d.zip
SynergyCM13-jflte-kernel-20160228.zip
I've been very scatterbrained lately, so if I missed something I should've added in this build, I apologize
Reaktionen: Cloud
@nugu : beschreib bitte mal genau wie du vorgegangen bist
Ich habe die Rom auf die externe SD gepackt.
Bin ins Recovery -> habe Cache und Dalvik Cache gelöscht
Dann habe ich dir Rom installiert.
Dann hat er mich gefragt ob ich Cache+Dalvik Cache löschen möchte - das habe ich bestätigt.
Und nun startet mein Handy jedesmal neu nachdem er die Insallation aller Apps abgeschlossen hat.
Du hast etwas wichtiges überlesen...Wipe mal /system auch und dann nicht nur die ROM, sondern auch die Gapps installieren. Und achte darauf, dass es die selben wie bei der erstinstallation sind. Also wenn du beim ersten mal nano genommen hast, dann jetzt wieder
achso, weil in der Anleitung steht, nur wenn /system gewiped wurde.
ok, soll ich einfach nur die Gapps flashen und dann sollte es gehen? Oder soll ich nun anders vorgehen?
Danke! :)
Mach so:
1 ROM und Gapps auf die SD Karte
2 wipe system cache und dalvik
3 flash rom und gapps
4 wipe cache und dalvik
5 reboot
Nach dem ersten mal "Apps Optimieren" kann es sein, dass er selber einmal neustartet.
Du nutzt schon TWRP ab 2.8.7.2 oder?
Der 3.0.0.0 TWRP geht auch ohne Probleme nur so am Rande [emoji2]
Danke!
Ich komme zwar wieder ins System, jedoch habe ich nur einen Blackscreen mit einer Fehlermeldung "Setup-Assistent" wurde beendet, das kann ich mit OK bestätigen, jedesmal wenn ich auf OK tippe kommt die gleiche Meldung wieder, Whatsapp etc läuft anscheinend alles im Hintergrund weiter... :(
Der Lock Screen sieht normal aus
Neustart bringt nichts :/
Oke das ist komisch. Spiel mal dein Backup wieder ein! Ich werde heute Abend bei mir das update testen und dann berichten
OK, danke dir! Ich hab nur ein Backup von der Stockrom, die kann ich eh ganz normal wiederherstellen, wenn ich vorher dalvik, cache, system etc gelöscht habe?
Beim wiederherstellen wird automatisch die jeweilige partition gewiped
Ok, ich werd einfach wieder die vorherige CM flashen :) Danke!!
Update hat bei mir funktioniert!
bei mir auch
Moin ich habe mir gestern diese Version auf mein s4 geflasht davor hatte ich die cm 12.1 drauf jetzt die eigentliche Frage. Ich habe die SD Karte als internen Speicher gewählt kann man da keine Daten wie Musik drauf schieben? Im Datei Explorer zeigt es mir nur den normalen internen Speicher an. Was kann man da machen?
Richtig, die SD Karte ist jetzt der Interne Speicher.
Ich an deiner Stelle würde die SD Karte als Wechselmedium formatieren.
Test kernels
Hey guys,
I know with my last kernel rebase I took away some features some of you enjoyed. So I brought back some, and a little more, for those of you who who really like my kernel. I also decided to add a kernel that OC'd by default because I was inspired by my S7 Edge to match all the clock speeds, and now my S4 performs right behind my S7E! Of course, use the OC kernel at your own risk since it is CPU OC'd to 2.1 GHz and GPU OC'd to 600 MHz.
Common changes:
  • Merge CAF 3.4.110
  • Update FSync
  • Add CPUFreq limiter, nothing user facing here, so you probably won't see this
  • CPU Voltage tables! 600mV-1450mV
OC Kernel only
  • Added CPU clock freqs: 1944MHz, 1998MHz, 2052MHz, and 2106MHz
  • Changed GPU clock freqs to: 128MHz, 200MHz, 360MHz, and 600MHz
  • Disabled Adaptive Low Memory Killer
  • Disabled Intelli-plug, enabled MPDecision
  • Tuned Interactive
SynergyCM13-jflte-kernel-20160302-stock.zip
SynergyCM13-jflte-kernel-20160302-OC.zip ((Make nandroids!!!))
Die Version vom 28.02.16 macht bei mir scheinbar Probleme. Unverhofft geht das Display nicht mehr an und die LED blinkt gelblich. Es hilft dann nur noch Akku entfernen. Ich habe jetzt wieder die Version vom 15.02. auf mein S4 getan mal gucken ob da das gleiche passiert.
