I9505 [ROM][6.0.x] Resurrection Remix v5.7.4][OFFICIAL]
  • 191 Antworten
Was heißt bitte Alte Version? Synergy scheint echt die einzige 6er Rom zu sein die das Wlan Problem nicht hat
Alte Version mein ich Resurrection_Remix_LP_v5.5.9 :winki:
Danke, gibt schon das nächste Build:
ResurrectionRemix-M-v5.6.6-20160402-jfltexx.zip
Werds mal flashen :scared:
#ResurrectionRemix - v5.6.6 - 20160401
The Changelog
- SystemUI: Restart System UI on theme Change and NP color switch
- LLS: Add LiveLockScreenController
- Update RR logos
- SystemUI : Fix Network Traffic Colors Not updating
- SystemUI: Fix headsup stuck after theme change and recreate statusbar
- [SQUASHED]Mass Revert of CM's Qs Drag Panel
- FWBase : Port & Improve CPU boosting Hooks && Interface
- Fix headsup blacklist and whitelist
- SystemUI :[Squashed] Fixed Leaks and Observers
- SystemUI: Reduce Load On ContentObservers
- SystemUI: Optimizations and cleanups
- ix metrics density comparisons
- GlobalActions: Set the initial status of airplane mode toggle
- SystemUI: Change demo mode time of day.
- Prompt permission dialog for status bar weather
- Should use scan flag, or it will not scan device.
- base: pipe all IME hints regardless of IME notification state/settings
- SystemUI: Fix Notification panel NPE
- Qs: Improve Themes Tile
- [ThemesTile] Sort themes
- Port ThemesTile to new CMTE api
- Compile app theme in background
- Cast Tile: only scan while in detail view
- SystemUI: more consistent visualizer logic
- Fling : Gallery icon support
- camera2 legacy: Allow HDR processing to take a while
- Cleanup Ls Weather Layout
- Revert "MediaScanner behavior on boot
- Add Resurrection ringtone v2
- Hack to remove black bar on custom lockscreen wallpaper
- Themes: Fail theme install if common resources fail
- SystemUI: stop hiding hotspot & color inversion tiles
- For more info Track Github Activities
- Translations updates
Und wie läuft sie so? Was gibt es zum Wlan Bug zu sagen?
Tja, watt soll ich sagen.................... läuft recht gut, allerdings der Wlan Bug ist immer noch vorhanden :mad:
Wieso bekommen die das nicht in den Griff :cursing:................ schade !!!
Reaktionen: Fifaheld
Da lassen sich die Leute die dafür Zuständig sind immer schön Zeit für eine Neue Version und dann wird man doch Entäuscht
Obwohl es jetzt ja schon einige Roms gibt, die das in den Griff bekommen haben.
Hab mal das Resurrection Rom mit dem Synergy-Kernel probiert.............. leider bleibt er im Boot Bildschirm hängen :crying:
Einige? Mir ist bisher nur Synergy bekammt....
Hab mal das [ROM][6.0.1] Optimized CyanogenMod 13 [Build_by_JDCTeam] ausprobiert, da hatte ich zwecks Wlan auch keine Probleme !
[doublepost=1459682342,1459678161][/doublepost]Commando zurück............. habs gerade nochmals ausprobiert................. Wlan geht im Standby aus, auch beim Optimized CyanogenMod 13 :cursing:
In der neuen Version (5.6.7.) besteht der Wlan Bug leider immer noch :-(
Vielen Dank das du es weiterhin versuchst. Schade :(
Morgen zusammen,
Also ich habe die Rom, Version 5.6.8, seit gestern drauf und kann diesen WLAN bug leider nicht nachvollziehen. Bei mir läuft bisher alles rund und alles so wie es soll...
[emoji4]
Hallo habe Version 5.7.0
Ob WLAN Im Standby geht weiß ich nicht aber Mobile Daten gehen gar nicht, da kommt ne Meldung im Netz anmelden usw obwohl die APN richtig sind.... Naja hat jemand eine Version wo das läuft?
Probier ich gleich mal aufm S3 LTE ob da Mobile Daten gehen, da läuft nur 5.6.8 oder so mal schauen,
bitte um hilfe!!!!
Lösch doch mal die APNs und setze es neu auf !
Komisch, ich hatte da nie ein Problem mit...
Wurde denn alles gewipt?
Ansonsten wie Prime Evil schon sagt: Einfach alles nochmal neu aufsetzen, hatte es auch schon mal dass ich zweimal flashen musste.
Wenn der Wlan Bug behoben ist wird etwas anderes nicht mehr einwandfrei gehen. Das ist CM beim S4 eine Hassverwandtschaft. Deshalb kommt es auf mein Honor 5x auch nicht drauf, da bleibt alles Standard.
An unexpected error has occurred. Auf der Downloadseite...
chrieb am 20.08.2016 um 12:08 Uhr
Hallo Leute, Wollte das Resurrection remix 5.7.1 und anschliessend AGapp 6.0.1 auf meinem S4 Gt I9505 installieren, wie oben beschrieben.>Fehlermeldung: Installation aborted (Status 7). Habs versucht mit CWM und TWRP allerdings immer die gleiche Fehlermeldung. Derzeitiges OS: Android 5.0.1 Basisbandversion: I9505XXUHOB7 Kann mir da jemand helfen? Danke im Voraus
Du musst die neueste TWRP verwenden.
Fifaheld
postmaster
Fifaheld
Darks
Darks
BenLue
element1975
element1975
