I9505 [ROM][5.1.1] AntaresOne & Alucard24's optimized CM12.1 [Stable]
  • 2.097 Antworten
Ok, Backup ist fertig, dann mal los :D
Denk Link für den Kernel hat Claymore vor kurzem im offiziellen CM12.1 Thread gepostet.
Neeeeee, alao Dirty ging bei mir auch und Tastatur und Bluetooth ging auch
Dann hattest du glück ;) bei mir ging es nicht. Grad beim ROM wechsel sollte man clean installieren
Naja, es ist ja kein ROM Wechsel im klassischen Sinne, vielleicht ging es deswegen gut :)
Es ist gestern endlich die stable v3 erschienen.
Changelog V3:
  • Device:
    • Added back FFMPEG codecs
    • Added eMMC trim at each boot (log file is saved for each boot in /cache/trim.log)
    • Added our custom init script
    • Custom Doze service (Settings->Gesture)
    • Fixed MMS
    • Fixed 2G data connection
    • Fstab: put f2fs above ext4
    • General RIL updates
    • Moved dancing LED to LEDify
    • Realtime CPU/GPU maximum frequency & RAM status in About phone (2/2)
    • Reverted to new consumerIR send command timing
    • Updated fingerprint for some models
    • Updated media codecs
    • Updated power management at boot
    • Updated RIL properties for I9505G
  • Kernel
    • Linux kernel 3.4.109
    • A lot of code updates & fixes including general code from Linux kernel 3.10
    • Added back kexec-hardboot patch (if this ROM is installed as primary, now secondary ROMs in MultiROM will boot)
    • Added KMS and UKMS from Linux kernel 3.10
    • Added VENO TCP protocol
    • Added ZRAM and enabled with 256MB (as default for ex. battery, battery and defaut STweaks profiles, 512MB for performance and ex. performance)
    • Changes and fixes on LMK
    • Changes on OOM control, less battery usage
    • CPU governors tuning/code cleaning
    • Increased maximum on call & standby freqs to 1350.000 KHz (fixed slow InCallUI while in deep sleep)
    • IPC: ported code from 3.10 kernel
    • Optimized alucard, darkness, nightmare and ondemand CPU governors
    • Various ramdisk optimizations & updates
  • ROM
    • Android 5.1.1_r24
    • Archidroid v4.1
    • Built with GCC 4.9.4
    • Improved build environment
    • Bionic: reworked the whole branch:
      • A lot of improvements and more optimizations for ARM-Cortex-A15/Krait CPU
      • Implemented pty.h
      • Removed unused/not needed optimizations
      • Lots of cleaning
    • Aapt:
      • default apk compression to 0 ratio (improved speed & memory usage)
      • don't compress qmg, wbp and arsc assets
    • Added battery saver Quick Settings tile
    • Added JDC LEDify:
      • Can be managed by the Toolbox app (below)
      • Patterns up to now:
        • JDCTeam dancing rainbox (default)
        • Hearbeat blue
        • Heartbeat green
        • Heartbeat red
        • Nexus-like
        • Nexus-like reversed
        • Police blue/red
        • Samsung default
    • Added JDC Toolbox app, wrote from scratch:
      • Manage LEDify settings (user-customizable notification LED at boot, prebuilt patterns)
      • Manage the IR LED driver (easy way to make any IR app work)
    • Added live lockscreen support & previews
    • Added show volume to tile chooser
    • Added volume boosted ringtones
    • Allow disabling the privacy guard notification
    • Audioflinger: do not build with -Os anymore
    • Correctly import wget binary needed by some STweaks features
    • Fixed remaining stagefright security issues & fixed some possible overflows
    • Fixed encryption for F2FS
    • Fixed ipv6 tethering
    • Format script:
      • Added ART cache & /cache autoclean
      • Added kernel settings autoclean, enabled when required like this build)
      • Power on notification LED for debug purposes (blue if installing on /system, red if installing in MultiROM as secondary)
    • Framework: various multimedia updates
    • Improved SystemUI circle battery
    • Include Android security patch level in Settings
    • Libpng: small fixes from Marshmallow
    • New JDCTeam ASCII art
    • New bootanimation! Big thanks to @ovaxivanov
    • Personalized SetupWizard UI
    • Revamped Device Info in Settings:
      • Added device hardware info (under "Common"):
      • CPU info (number of cores, realtime maximum frequency for each core)
      • GPU info (model, realtime maximum frequency)
      • Realtime RAM status (size, used, free)
      • SoC info (manufacturer, model)
      • Added ROM logo with team members below
      • Added "ROM Thread" which links the user to ROM's thread on XDA (under "More")
      • Device-related infos moved under "Common"
      • ROM & kernel infos moved under "ROM"
      • Issue report & JDCTeam on G+ moved under "More"
      • Updated some strings
    • Removed dancing LED (there's LEDify now)
    • Reverted CM changes for BFQIO and cgroups
    • Show icon of app associated with the toast notification
    • Support for faster brightness response to light changes
    • SystemUI: various updates & fixes, use new lockscreen music visualizer from Eleven
    • Telephony: many framework updates & improvements
    • Updated & fixed some APNs
    • Updated system icon to material
    • Updated Webview to v46.0.2490.76
    • Various SELinux updates
    • Various other code updates (CM upstream merged 18 August~today)
Clean install is strongly suggested, especially if you are on 17/08 build.
Reaktionen: d407974, djfelix, Mr_H und eine weitere Person
Hat sie schon wer getestet?
Ich werd sie auf meinem Alltags S4 auch nicht testen. Wenn ich Zeit hab kommts auf das Bastel S4 zum Performace, Akku und Stabilitätstest. Aber derzeit läuft die Nightly mit Hulk einfach zu gut
Reaktionen: djfelix
Ich werde sie übers Wochenende mal runterziehen und testen, bei mir läuft die V2 alltagstauglich stabil mit ungefähr 3 Tagen Akku-Laufzeit (allerdings nur'n paar Nachrichten über WhatsApp sowie einige Telefonate).
Über Akku-Probleme kann ich mich nicht beklagen, mit Standort Dauer-An, WLAN ortsabhängig (Automagic) und 'ner Menge Apps kann ich im Schnitt zwischen 2 & 4 Tagen leben, ohne zwischendurch nachzuladen. Wenn mir jeman mal verrät, wie man einen Sreenshot macht, änge ich aug gern ein Bild rein...
Viele Grüße
BTW: der Akku ist jetzt fast 2 Jahre alt, mein Handy allerdings erst 3 Wochen (Gerätetausch wg. defektem UMST/LTE-Modul).
Volume down + Powerbutton
Geht einfacher, unter Einstellungen - Tasten - Ein-/Aus-Taste nachschauen ob ein Haken bei Bildschirmfoto vorhanden ist, wenn ja, dann einfach Power Taste ne kurze Zeit gedrückt halten und auf Bildschirmfoto klicken.
Werde die v3 ebenfalls ausprobieren, beim ersten Fehler bin ich dann endgültig weg von Optimized.
Hallo, hab die v3 drauf, sieht bis jetzt ganz gut aus, aber jedes mal nach einem Neustart kommt gogle play Dienst wurde beendet.
Welche gapps habt ihr genommen ?
Gruß Olli
Ich hatte bei der Optimized immer folgende genutzt:
Slim_zero_gapps.BETA.5.1.build.0.x-20150612
Steht auch in meiner Signatur der Link... Habe ich noch nicht geändert, obwohl ich wieder zurück zur normalen Nightly bin...
Damit hatte ich keine Probleme....
Also ich habe sie seit heute Mittag problemlos am Laufen. Fullwipe und open Gapps.
Läuft bei mir auch ganz gut, nur funktioniert Adaway nicht richtig. Habe der App Root Zugriff erlaubt und es lädt und aktiviert die Hostsdatei auch ganz normal aber leider ist selbst nach neustart immer noch Werbung in Apps vorhanden, in denen vorher mit Adaway keine war.
Was ist da los? Ist die Hostsdatei noch am selben Ort? Oder liegt es nur an daran, dass die Werbung in der App nicht blockiert wird?
Nenne mir mal eine Beispiel App bitte, dann teste ich es mal bei mir. Ich weiß leider nicht, wo sonst Werbung angezeigt werden müsste.
Ich habe es unten in der Prime Guide App entdeckt. Dort stehen andere App Vorschläge. Kann aber auch sein, dass Adaway in der App die Werbung nicht (mehr) richtig blockt.
Edit: In anderen Apps z.B. WeatherPro Free oder TuneIn wird keine Werbung angezeigt (falls dort überhaupt Werbung vorhanden ist).
Ist jetzt kein direkter Bug aber die Google Suchleiste wird in der Übersicht der zuletzt geöffneten Apps nur Angezeigt, wenn Apps dort vorhanden sind.
Also, hab jetzt schon mehrmals neu geflasht inc. Wipe Cache, Dalvik, System und Data Partition.
Einmal Kamera wird beendet, oder beim nächsten mal Bluetooth wird beendet und dann auch mal Play Dienste wurden beendet.
Nach jedem mal flashen kommt ein anderer Fehler.
Habs mit den gapps open_gapps vom 23.10.15 versucht.
Ich hab jetzt mittlerweile ein Backup zurückgespielt.
Falls ich mich für die normale Nightly von CM12.1 entscheide, welche gapps und evtl. Kernel und welche Nightly ist da empfehlenswert ?
Olli
Fifaheld
postmaster
Fifaheld
Gumpinger
Fifaheld
Nufan
Nufan
