trillian2002
Ich möchte euch hier meine Lieblings Rom auf dem S3 vorstellen.
Screenshots
Achtung!!!
Das ist keine offizielle Version vom Slim Team sondern eine Portierung vom XDA User deathnotice01 für das internationale i9505.
Features:
The Real Dark Slim
Notification drawer Shortcuts
Full hardware key rebinding!
Keyboard rotation
SlimCenter
Alle Features gibt es HIER
Download
Download ROM
Download Addons
Installation
Von einer anderen ROM kommend:
- Rom Zip und Addons Zip auf SD Karte laden
- Reboot ins recovery
- Full wipe und /system manuell formatieren (in CWM unter Mounts and Storage)
- ROM Zip installieren (Kein Status 7 Error da Format Zeile entfernt)
- Gapps/Addons/Extras Zip installieren (Slim_gapps MUSS installiert werden!!!!)
- Reboot!
Changelog
July 15, 2013 - build 7.2
- blobs updated
- upstream
- All "Master Key" exploit patches published by google integrated + additional - security fixes
- Gapps update: Google Music, Google Play Services, move google Now to system app
- App update in app download section google+
- Enhance support for secure google voice messaging
- Storage Settings: Allow user to trigger a volume rescan
- Backup: Use native google backup system to backup profile feature
- Updated Translations
June 22, 2013 - build 6.8
- Nova launcher update
- Add statusbar Quick Peek
- Fix theme provider crashing for none primary user
- Fix QS icon picker
- Fix touch key duration always on
- Upstream to DashClock
- Expanded profiles (power menu)
- Lockscreen: Fix Widget disabled
- Updated MAP code from upstream
- LCD density backup on dirty flash (working then for all flashes after first weekly flash)
- Add back CFIS support
- Exynos 4/Sklia otimizations
- Massive reduced observer footprint across various Slim features
- Permit Home button wake to be configurable
- Jit optimizations
- MMS: Prevent FC in low memory conditions
- Add Settings shortcut to Interface Settings Activity
- Fix: hebr (iw) dialer drawable
- Squashed changes to frameworks av from caf
- A lot small fixes and optimizations
June 20, 2013
- Initial Release for I9505
Quelle: [ROM][4.2.2][Unofficial]SlimBean ROM [JFLTEXX][build 7.2][Jul 15][WEEKLIES] - xda-developers
Screenshots
Achtung!!!
Features:
The Real Dark Slim
Keyboard rotation
SlimCenter
Download
Download ROM
Download Addons
Installation
- Reboot!
Changelog
- blobs updated
- upstream
- Jit optimizations
June 20, 2013
