dj3d
The Android Open Source Project Nougat
Brought to you by Jflte DevConnection Team
Code:
#include <std_disclaimer.h>
* Your warranty is now void.
* We're not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at us for messing up your device, we will laugh at you.
What is AOSP?
AOSP is Android as Google publish without other modifications. More or less AOSP is the Nexus devices stock rom without gapps. Anyway to get a working system I' ve added some changes from CyanogenMod and Codeaurora.
Please do not ask for features to be added because we're not going to add more to keep this ROM small, fast and pure.
JDCTeam
In alphabetical order:
Known issuesBrought to you by Jflte DevConnection Team
Code:
What is AOSP?
JDCTeam
- Diego Monaco - @alucard_24
- Dimitris Katikaridis - @side
- Franck Rohée - @franzyroy
- Ray Deley - @gadget!
- Jim Silverlock - @Jimsilver73
- José Adolfo Galdámez - @josegalre
- Marco Zanin - @-+BB+-
- Matthew Booth - @MattBooth
- Mattia D'Alleva - @AntaresOne
- Mike Atkins - @FernBch
- Oliver - @angelcalibur
- Paul Harris - @hawkerpaul
- Paul Keith - @javelinanddart
- Simeon Ivanov - @smstiv
- Stefano Meroni - @smeroni68
- Yannis - @SkL*
- ANT+ (not supported)
- You will tell us
Download
ROM builds are hosted on RomHut
Here' s the download link: Download AOSP-JF-7.0 - JDCTeam_jdc_jflte-7.1-20161117-BETA.zip
TWRP Recovery v3.0.0-0 with F2FS support (JDC Themed): RomHut
Installation
TWRP Recovery v3.0.0-0 with F2FS support (JDC Themed) is suggested for installation
Device variants supported:In this first alpha we support only international variants, cdma won't work, don't try to flash it, i already know what' s the problem but i need a little bit of time for fix it
AT&T and Verizon users: since your bootloader is locked, you must be on the UCUAMDB or UCUAMDL bootloader if you own an AT&T phone, otherwise if Verizon you must be on the VRUAMDK bootloader in order to use this ROM. Do getprop ro.bootloader in Terminal Emulator or through ADB shell to find out which bootloader you have
First time or clean install:
- Download the ROM from the link above
- Download GApps package for Nougat 7.0
- Download ThemeReady GApps package for N arm
- Put the zip files on your SDCard
- Reboot in Recovery
- Wipe Data / Factory Reset
- Optional: convert to F2FS
- Select "Install zip from SDCard"
- Choose AOSP ROM zip file
- Choose GApps zip file
- Choose TBO GApps zip file (needed for complete theming of some Gapps with OMS overlays)
- Flash
- Reboot system
- Download updated build from the link above
- If you do not have the Gapps package, download here
- If you desire theming also gapps, download ThemeReady GApps package for N arm
- Reboot in TWRP Recovery
- Wipe /cache and dalvik-cache
- Flash
- Reboot system
First boot after install/update takes a while, wait at least 5 minutes for it to boot.
To convert cache, data and system partitions to F2FS look in post below.
Quote:
General notes
- Rom is pre-rooted and has SuperSU v2.76 integrated
- Theming: rom has from this build the new SUBSTRATUM THEME ENGINE. Use the integrated Substratum app to apply OMS overlays (OverlaysManagerService).
- Theming: to apply OMS overlays to some apps, you need also to flash TBO GoogleApps-ThemeReady-LP-MM-N-v21.4.zip right after your Gapps package from recovery. This means to be clear: ROM + GAPPS + TBO
- We use 5.1 blobs for radio interface. Update your phone to latest Baseband and Bootloader available for your variant (must be a version 5.0 official Baseband)
Sources
GitHub
Social
Google+: JDCTeam Community
YouTube: JDCTeam TV
Credits
- JDCTeam
- CyanogenMod
- CodeAurora
- TeamSubstratum
- Sony devs (OMS)
- gkkovacs - JDCTeam-Build01
- azuziel - JDCTeam-Build02
- Team Codefire - JDCTeam-Build03
XDA
AOSP 7.0.0 for Samsung Galaxy S4 (Qualcomm variants), ROM for the Samsung Galaxy S4
Contributors
-+BB+-, smeroni68, AntaresOne, alucard_24, MattBooth, angelcalibur, franzyroy, hawkerpaul, javelinanddart, Jimsilver73, side, smstiv, josegalre
Source Code: AOSP-JF-MM · GitHub
ROM OS Version: 7.x Nougat
ROM Kernel: Linux 3.4.x
Based On: AOSP
Version Information
Status: Alpha
orginal beitrag [JDCTeam][7.0.0][1 September][OMS-Substratum] The Android Open Source Project NRD90M
