[ROM][I9300][KK 4.4.2] *12-03-2014* Fusion-Boeffla KitKat r2.0.6[SLIMPIE][GCC4.8]
  • 853 Antworten
heavymetall66
heavymetall66
Dauer-User
245
ein großes Dankeschön an den Eröffner dieses Threads @störte für seine hervorragende Vorarbeit und umfassenden Support !
Es ist ein toller MIX aus den besten Features verschiedener Entwickler und so ist es nur eine logische Konsequenz dieses ROM zu promoten :D
Zuerst einmal der Link von XDA
[ROM]Fusion-Boeffla KitKat 4.4.2_r2.0.6[SLIMPIE][GCC4.8][12-03-2014] - xda-developers
Recents Rambar
Navigationbar by slimroms
AppSidebar (Chaos)
Networks Traffic meter (Chaos)
TRDS 3.0 (Awesome Thanks SLIM)
AOKP Weather
MediaScanner behavior on boot
Show CPU Info
Show Clear all button + location
Low battery warning
Less frequent notification sounds
Screen on notification
Lockscreen by slimroms = 8 Sliderziele einstellbar
Power Menu by slimroms
Keyboard: Auto keyboard rotation
Customizable PowerWidget (Thnx to DerTeufel)
CRT Animations
AOKP Custom system animations
Listview animations
Keyboard animations
Scroll animations
Smooth Progressbar animations
HALO
Gesture anywhere (Chaos)
Identicons (Chaos)
Wakelock Blocker
Suspend actions
Build.prop modder
Init.d configurator
Double tab to sleep gesture on statusbar
Gesture Lockscreen (Chaos)
Flip animation on clicking a qs tile
Keyboard: Volume key cursor control
QuietHours AutoSMS && Bypass Alarm
Notification drawer shorcuts
Notification drawer and qs background transparency
Advanced display
Contextual notification panel header (Omni)
Center clock and more (Slim)
Screen-On notification light
Keyboard: Option to disable fullscreen keyboard
Statusbar brightness slider
Option to disable qs by removing all tiles
Option to choose custom lockscreen handle
Quiet Hours Ringer
SlimPIE
Double tap to sleep features
Active display (Chaos)
Lockscreen notifications
and many more.......
Changelog 2.0.6
Added density changer on-the-fly and reverted the previous density changer
Clock font styles fixed
Added slim recents
Added slim recents trds support
Made slim recents optional
Added Notification reminders interval, also fixes and improvement
CM themes fixed (Now Working perfectly)
Recreate statusbar on theme change
TRDS fixes and improvements
Speed-up booting on multi core devices
Fix memory leak in systemui
Added dirty region
Bluetooth improvements and fixes
Audio improvements and fixes
Strings clean-up
Smart PullDown to SlimActions
Notification Reminder New Layout && Fixes
Recents to SlimActions Shortcuts
Google Recents (Mr. Jingles - when you fully wiped everything off from recents, you'll have mr. jingles jiggling for you!)
Added HTC Reflection Effect to default recents
Framework: Fix graphics corruption caused by HWUI caches
AppOps: New ops, features, and modes.
Latest cm changes merged
And many many more
Changelog 2.0.4
Audio: Fix Titel System Klingelton enthält chaotisch Meta-
Audio: Stellen slient bleiben Eigentum nach Klingelmodus
Mitteilung gesperrt Puffer, wenn es zu erwerben Grafiken Puffer ausfällt
Neue App iPhoney UI mit Farbtafelträger
anzeigen Info Anbieter Schöpfung, wenn kein Eigentümer ist für UserTile eingestellt
anzeigen Standardprofilnamen, wenn kein Profil vorhanden
SystemUI: Schalten Sie das Debugging
UserTile: Prüfen Sie, ob Profil hat ein Foto
Benachrichtigung Reminders (SlimRoms)
XuiMod: Toast Animationen (Thnx codex-corp für den Hafen) Siehe Fusionbox @ System Animationen
Revert "-Frameworks: Hoffnung systemui verbessert Akkulaufzeit "
neu implementiert AppOpps von CM-10.2
Fix rejigger WifiService so appops nicht gapps brechen startupwizard
Fix erlauben / ablehnen Zählen
entfernt pa-Version und AOKP Version von Geräteinfo-Einstellungen
ActiveDisplay Rework Interface (Omni)
Aktualisiert Bildschirm sperren und sysbar pie Bilder
Hinzugefügt Quick Access Ribbon-Funktion
Festspeicherleck in den Einstellungen
Fix Lockscreen Wallpaper
zusammengeführt neuesten CyanogenMod Änderungen
und Fehlerbehebungen und Verbesserungen tru-out den gesamten Build-
Changelog 2.0.3
Rom compiled with linaro SaberMod 4.8 for more performance and better battery life.
Kernel compiled with linaro SaberMod 4.7.4.
Compiled with GCC optimization level -O3.
Compiled with strict-aliasing compiler optimization.
Added ARMv7 and Cortex-A9 optimized string handling routines for more smoothness and more memory optimization.
Fixed notification led pulse
Added volume panel time-out
Lots of changes and improvements to Keyguard
Added Multi user support
Removed second PIE
New notification header images
QS Tiles style: Alpha sliders for color picker options
SmoothProgressBar: Add reset option
Fix QuietHour start time
Build.prop Mods: Do some prereq's before showing options
Some memory leaks fixed
Cleanups
Merged latest cm changes
and many many more...
Changelog 2.0.2
AOSP 4.4.2_r2 (KVT49L)
Added second pie controls FusionPIE (with adjustable trigger area's).
Volume steps (Thanks Beanstalk)
Volume panel timeout (omni)
LS Notifications: Add "Show all notif" NavBar Button
Notification: Lockscreen Notifications: dismiss all button, improve animations, cleanup
Overhaul keyguard - Fixes and improvements lockscreen blur, LS Notifications,See trough and more
Big update translations by cm
lots of fixes and improvements tru the entire build
latest cm changes merged
and many more..
Sorry dont have time now to write a large changelog(Have a party to goto tonight) will update later or
check github for the latest changes..
Fast Changelog 2.0.1
Fix LS Notifications: custom background color
Squashed multiple cm translations commits
EdgeGestureService give abbility to reduce the left and right trigger height if IME shows up
TRDS Fix possible UI freeze on auto mode change
SlimPie give user ability to reduce trigger heights if IME keyboard shows
Fix icons overflowing status bar view in center clock and date layout
Start the PowerSaver service if activated
MultiWindow: Fix NullPointerException
MutliWindow: notify split view if layout changed
HALO notification should open in floating window mode
MultiWindow : prevent multiwindow if halo enabled
Added MultiWindow …
Added Open source google dialer and more
Reverted Add Dialer suggestions and reverse lookup
Clean up the AOSP tablet icon mess
Fix navbar and pie icons for tablets and RTL
Slim Actions to Shortcuts
Fix: Make sure to turn off led after pulse
Added user protection and pie/navbar toggle to SlimActions
Fix qs and notification shade toggle on expanded desktop
Added new SlimPie (thnx slim)
Add EdgeGesture service. …
Revert forward port SlimPIE
Browser: Update desktop UA string to match Chrome 30
Browser: Always show the action bar overflow
And many many more...
!!!You Need To Do A Clean Install!!... Otherwise you will get issues due massive changes in the source code!!!!
Changelog r 2.0.0
SlimPie And Navbar fixes (This also fixes the different colors issue in the navigationbar)
Reverted Add in-the-spot user preference dialog feature as it broke, quick pulldown and smart pulldown features of quicksettings
Down sized fusion_logo's
Settings: LightSettingsDialog: update led on text change
Latest cm source
Download:
https://shared.com/l873s3dcgn?s=l
Gapps:
Zippyshare.com - FusionRom-Gapps-4.4.2_Signed.zip
Es wird ein Full wipe empfohlen wenn man von einer anderen Rom kommt
1st Time Installing Fusion rom
1. Rom von den Links laden
und die Rom auf der internen Sd speichern
2. In recovery mach einen full wipe :
WIPE DATA/FACTORY RESET
[FORMAT SYSTEM
3. Instalier die rom.zip
4. Reboot
5. Installier Gapps
6. Reboot
Wenn Fusion rom schon drauf ist.
1. zip von den Links runterladen
und auf der internen Sd speichern
2. Die Zip in Recovery installieren
3. Reboot
Für alle Änderungen an Euren Geräten seid Ihr selbst verantwortlich, weder Android-Hilfe, XDA oder ich übernehmen hierfür die Verantwortung
heavymetall66 hat dieses Thema von störte übernommen.
Reaktionen: zaffaste, 1000Foxi, Mechanoid1 und 8 andere
Moin,
hab sie auch mal drauf gemacht, weil ich mit der Goa Rom doch einige blöde fehler habe.
Sie gefällt mir soweit ganz gut. gewohntes bild von Dragon halt ;)
Mal schauen werde sie heute mal drauf lassen und testen^^
Mach ich auch gerade. Habe bisher nur ein Problem. Muss mein WhatsApp Plus nach system/app pushen um es zu installieren. Normales installieren klappt komischerweise nicht.
Mir fehlt ein wenig das bekannte grüne Dragon Theme
stimmt da muss ich dir recht geben. naja es ist ja auch erstmal die v1 und man kann abwarten was noch so schönes kommt ;)
Dragon war ja immer für Überraschungen gut.
Habe den OP mal angepasst und Links eingefügt
Moin
Störte bin gerade bei überlegen ob ich umsteigen soll momentan hab Goa drauf. Heute Schafe ich nicht muss gleich arbeiten gehen. Kannst schreiben wie der Rom läuft. Was für ein Kernel nutzt du.Danke im voraus:D:)
Wie gesagt habe sie jetzt erst fertig. Aber sie schaut sehr gut aus. Habe sie mir auf 240dpi eingestellt. Das Theme ist Dragon like. Im Moment habe ich den integrierten Kernel drauf.
Ich hatte gestern mal die Hyperdroid AOXP drauf und da wurde mir der PSN_pureCM-v2.1_I9300_AutoOC-signed.zip empfohlen
Zu finden ist er hier
Bin am überlegen ob ich es erstmal bei dem Standard Kernel belasse.
Reaktionen: janosik
Habe mir gerade mal alles durchgelesen. Na ja die Probleme scheinen ja nicht alle zu haben.
Schade ist nur das Dragon nicht so oft online ist. Ich habe ihm mal eine PM geschickt. Mal sehen. Ich bin immer noch der Meinung das sie es wert ist getestet zu werden.
Ja ist sie auch, aber die Probleme mit Titanium Backup gehen gar nicht oder Probleme beim installieren von Apps.
Habe sie auch getestet, aber wegen den genannten Gründen bin ich erstmal zur Carbon gewechselt. Bis Dragon ein Update bringt.
Mit TB hatte ich nur Probleme mit Apps die von Samsung waren soweit ich mich erinner. Ansonsten nur WhatsApp + aber das Problem gibt es auch bei der Chaos Sammy Rom
Mal sehen wie es weiter geht.
Ich habe mal die <Rom eben getestet. Konnte aber leider meine Apps mit TB nicht wiederherstellen. Schade.
Ist ja komisch das es solche Unterschiede bei den TB restore gibt. Bei mir waren es nur Allshare und Polaris Office
Der ursprüngliche Beitrag von 18:58 Uhr wurde um 19:49 Uhr ergänzt:
Habe Kontakt mit Dragon gehabt via PM. Wollte sicherstellen das es für ihn ok ist hier seine Rom vorzustellen und zu linken.
V2 kommt in kürze
Reaktionen: playsat
Fusion Rom V2.0 Uploading!!
Changelog V2.0:
Latest CM source merged
Latest SlimRom source merged
Added Blacklist Feature
Added Custom Quicksettings tile
Removed old PIE Control and added Slim PIE Controls
Added Auto hide Statusbar when no notifications are present
Added Camera sound toggle
Memory leak fixes
Added New Gapps (Thanks to Slim)
Added Aroma installer with kitchen - Transition effects - Inverted Apps - Boot animations - Launchers - Kernels - Modems - Recovery's
Lots of fixes and improvements
and many more...
OP aktualisiert. Links werden zugefügt wenn die Rom ist up.
Update
V2 online. Link in Op
Moin
Störte kannst schon was sagen über den Rom. Wie läuft der bei dir.
Sie läuft eigentlich sehr gut.
Das einzige Problem ist , das TB schlecht installiert werden kann. Nicht einmal vom Store ging es. Habe die APP dann vom Hersteller runter geladen und installiert. Das Whatsapp plus Problem besteht auch noch. Aber wenn alles drauf ist ,läuft sie sehr gut und flüssig.
Ich hatte sie mit full wipe geflashed. Vielleicht ist es besser sie über die Version 1 zu flashen. Das soll ja gehen.
Dragonized
Reaktionen: janosik
Moin
V3 in Anmarsch soll heute online sein:D
Reaktionen: störte
Auch grad gelesen. Bin noch mit mopped unterwegs
Dragonized
Dragonized
Ein nach einem Fullwipe geflashtes Rom ist sicher besser/fehlerfreier als nach gar keinem Wipe ;)
Hi
Welchen Kernel nutzt ihr mit dieser Rom ?
